BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N20, N26, B46, B48 Turbo Engine / Drivetrain / Exhaust Modifications > Car sputters under moderate throttle (HPFP issue?)
      12-20-2019, 01:29 PM   #1
Cpatel
Drives: N26 328i
Around last week, under heavy to moderate acceleration, the car sputters/lags. No CEL is thrown and when I read codes using bootmod3 I don't see any misfire codes or anything like that.
I've been reading around and it may look like a HPFP issue.
Can anyone chime in on this?
      12-21-2019, 09:22 AM   #2
rjd_F30
rjd_F30's Avatar
Drives: 2013 335i 6MT
I used to have a similar issue after flashes and adaptation resets, and it has since gone away. In my case, I think it was an adaptations issue, as it hasn't happened after I've driven enough to let the car adapt.
      12-25-2019, 01:21 AM   #3
D041987
Big Turbo Boys N Girls
D041987's Avatar
Drives: 2012 328I 6speed
This usually is a typical sign of bad plugs. Check your gap on the plugs and/or replace if you are over 70K. Plugs should be done every 40K to 50K MAX. Coils should be changed out around 90K to 100K.
Are you tuned?
If tuned for stage 1. Gap the plugs to .025 -.026
If tuned for stage 2. Gap the plugs to .022 -.023
2012 F30: G25-660 Bottom Mount Mani+ DP+ Intake, CSF FMIC, VRSF CP, Walbro 450 LPFP, PR Injection with AIC 4, S63TU Injectors, Tuned with BM3, ZF Race 4 Puck and Non SSA Pressure plate, Catless, 3.5" Quad Muffler, Custom Valved Bilstein B8 + H&R SS. Max 456 WHP - 452 WTRQ. Currently tuned down to 434 WHP and 362 WTRQ to save the rods.
      12-27-2019, 09:21 AM   #4
rjd_F30
rjd_F30's Avatar
Are you tuned?
That's what I though when I had this issue, so I changed my plugs out and gapped them appropriately and it made no change.
      12-27-2019, 11:43 AM   #5
floridaorange
floridaorange's Avatar
Drives: 2013 bmw 320i xdrive
try unplugging your MAF.
you also might have carbon build up in your throttle housing. look into CRC cleaner.
Stage 2 BM3
Originally Posted by GrussGott View Post
Sounds pizzagatey.
Cpatel39.50
      12-31-2019, 07:27 AM   #6
JoeyF30
Drives: BMW 2013 328i xDrive N26
You need to reset your adaptation, I was like you, plugs coils air filter etc. nothing, I'm getting a BMS Pedal Tuner soon and bypassing the stupid drive by wire + adapt system, it sucks. I need to do this reset at least once a week.
Cpatel39.50
      01-06-2020, 06:51 PM   #7
1N54E92
1N54E92's Avatar
Drives: BSM F30 M-Sport
My car does this , just dropped it off at the shop. Idles fine , revs Fine in Park but when driving , moderate acceleration will make the engine sputter and make “farting” noise
      01-11-2020, 04:04 PM   #8
1N54E92
1N54E92's Avatar
Update : on my car it was the ignition coil which was replaced few months ago . Check your coils
      01-20-2020, 03:41 PM   #9
NicksN20F30
Drives: 2013 BMW 328i xDrive
I had stuttering under the same conditions and did everything others did, coils, plugs, checked everything and also thought it could have been a bad fuel pump/ clogged fuel filter. Ended up changing the trans fluid (I have an 8AT) and it was because bad fluid.
Not sure if you are auto and also what mileage you're at, but if you're past 50k, I'd highly recommend it.
After changing the fluid, all stuttering and hesitations went away. Shop that changed it (German specialist) said that the fluid was very dirty and I'll notice a big difference. He was correct.
BMW claims it's a "lifetime fluid" but ZF (transmission manufacturer) does not say that and advices it should be changed every 50k miles.
Bootmod3 stg. 2
FBO
      01-23-2020, 01:27 PM   #10
Cpatel
Drives: N26 328i
Ok here is an update:
I stopped using Costco and Arco gasoline (91 octane) and I've only been using Chevron, Mobil, or 76 and the entire problem went away.
What does this mean?
      01-23-2020, 02:30 PM   #11
m95roadster
Drives: F30, E90
My car had stuttering/surging issues at 3/4 or full throttle acceleration starting around 5k rpm and above.
Plugs were changed, used different gas and running stock boost. Still had the problem.
A few weeks later I brought the car to the dealer due to a wastegate rattle. They replaced the turbo and HPFP (said it was making noise) and the problem disappeared. I don't know which component fixed the issue, but I'm leaning toward the HPFP.
      01-23-2020, 04:02 PM   #12
WaleeF30
Drives: 2007 BMW 328xi E92
Maybe fuel injectors were dirty.
Try dumping a Techron fuel system cleaner in your tank the next time you need to fill up gas and use 93 octane if available.
      01-30-2020, 04:59 PM   #13
Cpatel
Drives: N26 328i
Update: I was using techron complete fuel system cleaner since the issue started, didn't do much.
Two days ago while I was driving, the car started shaking, drivetrain malfunction notification appeared and the check engine light came on. Read the codes using bootmod3 and it was a misfire on cylinder 4.
Went to a mechanic and it was diagnosed as needing new coils and injectors. This is covered in California under the SULEV warranty and the dealer will fix it for free. Car is in the shop currently. Got a 2019 G20 330i as a loaner. The technology in the car is really nice, the drive is WAYYYYY smoother than the f30. Steering is really nice as well. This car is bone stock and the power deliver is smooth as fuck but on WOT its not the same feel as the f30. Great car though.
