01-11-2020, 07:05 PM | #1 |
Rep 234
Driving with DSC off
I tried driving my '18 440i xDrive today with DSC off for the first time and I noticed that the throttle response and exhaust note were more aggressive than usual. Is that true or am I imagining things? I typically drive in Comfort mode, Sport every once in a while.
Also, what are the dangers of driving with DSC off, if any? Thanks. |
01-11-2020, 08:04 PM | #2 |
Rep 1,031
Drives: Like a bat out of hell.
I think you can get the same result putting it on Sport + mode.
No danger as long as you can keep control of your vehicle. It's an "expert" mode. Most of the electronics nannies are off except for ABS. It will let you do lots of fun things like drifting as well as stupid other ones. |
01-11-2020, 11:11 PM | #3 |
2JZ-GTE
3038
Rep 3,992
With no LSD and DSC fully off she becomes a handful
01-12-2020, 12:55 AM | #4 |
Rep 1,827
I've been driving with it off a little more lately. (By off, I assume you mean you're holding the DSC button for a few seconds until it says DSC inactive.)
Some things I've noticed, throttle response and shifts are similar if not the same as in Comfort mode, definitely not as quick or aggressive as Sport/Sport+. Steering is more weighted, as it is in Sport/Sport+. I don't have adaptive shocks, so I don't know if there would be any changes to the damper settings. Try this to compare, drive around in Sport+ for a little while, taking note of throttle response and shift speeds (in D, S, and M modes), then while still in Sport+, press and hold the DSC button until it says its inactive. If your car is anything like mine, I think you'll notice the throttle and shifts go back to feeling more like Comfort. I'm assuming that the heightened throttle response in conjunction with no DSC/traction control is a potentially hazardous situation, so they default to Comfort-ish throttle when you turn everything off.
2013 F30 335i RWD ZF Melbourne Red
~Remus Sport Axleback~VRSF Chargepipe~VRSF Catless Downpipe~GPlus FMIC~HR Sport Springs~Active Autowerke OBD Flash Tune Stage 2~ |
01-12-2020, 03:31 AM | #5 | |
Rep 5,997
01-12-2020, 08:54 AM | #6 | ||
Rep 15,858
The following is a part of the description of the 'Modes', when introduced in the F01 7-series. Same applies to most of the 3,4 & 5-series models. (Bold sections of text added by me). Quote:
01-12-2020, 10:03 AM | #7 | |
Rep 234
No, I didn't hold the DSC button for a few seconds. It was just a normal "push" of the button.
01-12-2020, 10:16 AM | #9 |
Rep 234
01-12-2020, 11:05 AM | #10 | ||
Rep 15,858
Typical BMW description of DTC function... Quote:
01-13-2020, 08:09 PM | #11 | |
Rep 4,877
It will let the car spin tires more before the nannies kick in to do throttle cuts. If you take a corner in sport, and get aggressive on the throttle, it will tend to feel non-responsive since the stability control cuts the throttle and brings it back into control. Do the same in sport+ (or DTC on), and it will let the rear kick out under those same conditions (to a certain degree). Hold the DTC button for a couple seconds, then it's 100% off with no nannies. Like mentioned above, you better be in tune with the car since things can get a little out of hand in a hurry. Great for the track, but not really advisable on surface streets. |
01-13-2020, 08:56 PM | #12 |
Rep 3,748
I drove an S14 Silvia for 13 years, yeah NO nannies even ABS. You guys lucky you have traction control, stability control.... imagine what they say about the F40 Ferrari... shit is scary on the street.
Solidjake945.00 RMachuca3d723.50 |
01-14-2020, 08:26 AM | #13 | |
Rep 234
Thanks for this. I wonder why having DTC on affects the exhaust note?
01-15-2020, 08:38 PM | #17 |
Rep 4,724
Sport + still keeps the electronic nannies active, just a little more relaxed.
Current: 2021 M340i xDrive
Previous: '18 340i xDrive; '15 335 xDrive; '14 435i xDrive; '09 335 E92 xDrive |
01-16-2020, 03:28 AM | #18 | |
Rep 5,997
01-16-2020, 09:35 AM | #19 | ||
Rep 4,724
01-16-2020, 02:09 PM | #20 |
Cheapskate
4447
Rep 4,993
DTC on is the same as Sport + but with comfort throttle/steering. You still get the burbles.
01-17-2020, 01:23 PM | #21 |
Rep 234
01-18-2020, 06:13 PM | #22 |
Cheapskate
4447
Rep 4,993
Everything is in comfort. It just allows a little more slip in the wheels.
