01-17-2020, 11:49 AM | #23 | |
Rep 694
01-18-2020, 03:11 PM | #24 | |
Rep 29
From service advisor: COMPRESSION TEST RESULT. 1= 190 PSI. 2= 195PSI. 3= 200PSI 4= 200PSI. 5= 200PSI. 6= 200PSI. PISTON TRAVEL. 1= 90MM. 2=90MM 3= 91MM 4=91MM 5=91MM 6=91MM BORE SCOPE PICTURES TAKE 2 PER CYL 5, AND 6 . IS BAD. |
01-19-2020, 10:59 PM | #25 |
Rep 776
Sounds like 5 and 6 may have visual damage. 1 and 2 maybe bent rods.
liudicrous12.50 |
01-20-2020, 12:35 PM | #26 | |
Rep 29
At this point, I don't know what I should do since the inspector seems to just want to close this claim. He and the claims rep both stated that if something does happen later related to this claim, then I would not have to file a separate claim and pay another deductible. Thoughts? |
01-20-2020, 01:43 PM | #27 |
Rep 1,905
did you ask for explanation of cylinder scope pics? What was their response?
compression and piston travel data look ok/consistent. were you able to get any specifics on how future issues are determined to be tied (OR NOR) TO RECENT CLAIM/DAMAGE? |
01-20-2020, 03:08 PM | #28 |
Rep 776
01-20-2020, 04:06 PM | #29 | |
Rep 29
I have requested this but haven't received anything yet. |
01-20-2020, 04:08 PM | #30 |
Rep 29
01-20-2020, 05:06 PM | #31 | |
Rep 1,905
Piston stroke in each cylinder will be identical, but there is a tolerance to any measurement, not certain what that is. Your stroke variance is tad over 1%- you'd need to lookup stroke spec'd to see if that is in or out of tolerance. Might find data at NEWTIS.info website. BMW Dealer techs will have this info and be able to access/explain if numbers represent any problem. Last edited by Wgosma; 01-20-2020 at 05:43 PM.. |
liudicrous12.50 |
01-20-2020, 07:30 PM | #32 | |
Rep 29
01-21-2020, 10:58 AM | #33 | |
Rep 29
He mentioned that the compression test results and piston travel specs are within spec and the piston travel spec is expected to be 89mm. Now, insurance is claiming that this issue is a pre-existing issue... WTF? They are asking me for all of my maintenance records on the vehicle. This is getting ridiculous. |
01-21-2020, 11:29 AM | #34 | |
Rep 1,905
"Progressive doesn't go out until Tuesday and they want to just change the oil. I didn't know this fact until Thursday but the adjuster apparently started the car but didn't tell the dealership. Claims he is an ASE certified tech of 15 years and he doesn't think the engine took any water damage because "it started". On Thursday, I received a call back that the oil change didn't fix anything and the next thing the adjuster wants BMW to do is to change the spark plugs and check the engine for water." Well now, I'm not there to see the car and I'm not a mechanic but geez, the insurance inspector fired up the car before ANY sort of visual inspection / analysis / diagnostics were conducted regards potential water damage? - seems that right there was a MAJOR mis-step and that may well have contributed to or was the direct cause of this so-called 'pre-existing' damage. If I were you, I'd be all over these people at Progressive - the management folks. Best to Document your 'case' (in writing) including specifics provided by BMW and let them know car gets a new motor. Maybe you need to consult an attorney, I've never been in this situation so really can't advise best direction to head aside from taking the issue to Progressive management. Best of luck/Bill |
01-21-2020, 05:44 PM | #35 | |
Rep 29
I am going to give it another day or two and see what insurance says. I have provided them all the documents they requested and the ball is in their court now. Appreciate you and everyone else's input/suggestions. |
01-21-2020, 06:10 PM | #36 |
Rep 1,905
Good luck and keep us posted. These modern engines require relatively little maintenance beyond oil/filter changes. Hard to believe Progressive can find a legit 'out' on this one if your records show proper maintenance.
That insurance tech should not have just fired up the motor right off the bat- I'd be willing to bet that caused some or all the damage. |
01-22-2020, 04:39 PM | #37 |
Rep 3,203
This. The last thing you should ever do if you think an engine has ingested water is attempt to start it. Dumb. I got lucky once with a client and a hyrdolocked older 350Z. We pulled all plugs, rotated the engine with the starter, let it dry out, then put everything back together. Compression numbers were all good, and when i followed up with him a couple of months later he reported no problems. Sometimes (rarely) you can get lucky with a hyrdolocked engine. Sorry OP is having so much trouble here, best of luck in getting this resolved.
01-27-2020, 04:59 PM | #39 |
Rep 29
At this point, still waiting on Progressive. Last Friday, the claims rep (not adjuster) asked for DTC codes/freeze frame data to which the service advisor responded that they don't have any DTC codes or freeze frame data for my vehicle and that my car does not currently have any codes.
This morning, the claims rep e-mailed me asking how fast I was going the day of the claim, how far I traveled in the puddle and if my car sputtered or just shut off completely. Now, waiting for her to respond. Last edited by liudicrous; 01-27-2020 at 05:46 PM.. |
01-27-2020, 05:30 PM | #40 | |
I can haz cheezburger?
6799
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
liudicrous12.50 |
01-27-2020, 05:34 PM | #41 |
Rep 1,905
Messy....Progressive seems be trying to find some way, any way, out of replacing the motor.
liudicrous12.50 |
01-27-2020, 05:47 PM | #42 |
Rep 29
Yep, it's a joke. They tried returning the car twice to me now and I've told them that there's rust in the engine per the pics from the dealership and they have yet to give me a response about that.
01-28-2020, 11:37 AM | #43 |
Rep 694
Time to invoke the appraisal clause my friend. Message me if you need a go to guy to help you.
This is absurd!!! |
liudicrous12.50 |
01-30-2020, 02:53 PM | #44 | |
Rep 29
I asked them two questions and their response is below. 1. How is progressive going to determine if future issues are tied to recent claim/damage? If additional issues do arise, we would need proof of the loss proof that the new issues, if any are consistent with this loss. 2. If there are future issues and tied to the recent claim/damage, will the customer be responsible for paying another deductible? If any additional damages prove to be related to this claim, the customer will not pay another deductible. |
