05-29-2018, 04:05 PM | #23 |
Rep 25
05-29-2018, 04:07 PM | #24 |
Rep 25
Everything is LED apart from the reverse light.
11-08-2018, 10:11 AM | #25 |
Rep 3
Hi
Could someone please share some light on this, I am in the same boat, fitted the new lci rear lights following the original bmw retrofit pdf instructions, used original oem harness, followed all the correct steps in the instructions from bmw, had my car coded from DD CODING, but still my inner turn blinkers don’t work. Could someone help who have sorted this issue without splicing into the outer blinkers. Much appreciated Thanks |
11-08-2018, 11:01 AM | #26 |
Rep 8,636
Mine was reflashed today, lci lights added to the car by Simon and still had to tweak the coding to get the inners working, but that was it, just coding. Seems strange its not working for some people.
11-12-2018, 08:55 AM | #27 | |
Rep 40
Hi,
Had this retrofit done over the weekend, followed the BMW retrofit PDF exactly to the letter without splicing. Inner blinkers did not work but after 5 mins of coding this morning by following SkyJawa's post on page one (long code list, post 15), the inner blinkers are working as intended. Also coded rear day running lights to stay on. Looks AMAZING! Thank you for all the info on here Quote:
Cheers |
02-14-2019, 04:20 PM | #29 |
Rep 8,636
That list is the esys way, but you should have them all showing if you use advanced mode in Bimmercode
02-14-2019, 04:32 PM | #30 | |
Rep 3
https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.co.uk%2Fulk%2Fitm%2F 283376129721 Says they are plug and play and don’t require coding or the harness, anyone else used non genuine lights ? |
02-15-2019, 02:04 AM | #31 |
Rep 8,636
I don’t know anyone that’s posted on here that has. Two things would bother me, near the bottom of the listing:
“Some cars may need loom harness and coding” But they say plug and play, so which is it! And: “Lamps are unbranded and not CE marked” I think not CE marked makes them illegal for road use (happy to be told I’m wrong), though you’d probably be unlucky to get caught. |
02-16-2019, 08:27 AM | #32 | |
Rep 730
https://www.ebay.co.uk/itm/CLEAR-Tail-light-RearLamp-LED-BMW-3-Series-F30-F80-12-15-Dynamic-Signal-UK-STOCK/273698525938?hash=item3fb9b412f2:g:K9kAAOSwFfJcYsL T:rk:41f:0 If they do work, it could be an easy swap rather than cutting into looms to fit the BMW LCI lights. However, i also noticed this: "Dynamic Swiping Indicators so better then original lamps". I'm guessing that is the Audi style indicators which i'm not a fan of.
F31 2015 BMW 335i - Manual
02-16-2019, 10:25 AM | #33 | |
Rep 3
02-16-2019, 02:00 PM | #34 |
Rep 8,636
You can get away with the existing drip rails but really need the lci ones as the lights sit slightly more proud, oem that is.
