04-24-2018, 04:17 PM | #1 |
Rep 1,953
Drives: 2013 328i xDrive
Jack and Jack Stands
Hey all, is there any low profile jack and jack stands you guys could recommend to buy from a Canadian source? Also, should I be looking for 3 ton, or is a lower one okay? Do I need 4 jack stands in case I want to do work myself like swapping the downpipe or exhaust?
04-24-2018, 05:25 PM | #2 | |
Rep 348
Can't tell you the price but you can get it from Prema Canada as well(www.premacanada.com), just scroll all the way to the bottom left and type in your Postal Code, it will find the nearest dealer and provide you with a number to call. Just call and order, they will deliver. As for jack stands, sorry can't help you there. I made wooden ramps and using a cheap one at work that was left behind by a coworker. I've been holding back looking for a good one as well. The F30's weight about 3600 lbs, 2 tons is 4000 lbs. You don't need a jack/jack stand rated for the entire vehicle as you're only supporting the weight of a corner/half of the car but having a bigger one will definitely help you feel better working under the car lol. Just leave the jack under the car when you're using the jackstands as a safety measure or just stick a wheel under your side skirt |
04-24-2018, 05:26 PM | #3 |
Rep 348
Here's the link to the stand for Prema - http://www.premacanada.ca/ame-14980.html
Kailec594.50 |
04-24-2018, 05:49 PM | #4 | |
Rep 1,953
04-24-2018, 06:38 PM | #5 |
Rep 172
Check princess auto, they will have sale on their 3-ton low profile. Mind's going on 10 years.
Costco also has one that tends to go on sale a couple times a year. |
04-25-2018, 06:35 PM | #6 | |
Rep 225
No problems at all. Don't have any jack stands though. |
04-25-2018, 08:41 PM | #7 |
Rep 1,953
04-25-2018, 08:57 PM | #8 | |
Rep 225
Black jack 3 Tonne. |
04-26-2018, 12:10 AM | #9 |
Rep 1,953
04-26-2018, 11:25 AM | #10 |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
I bought this jack for my lowered S13 (240SX) on coilovers back in 2011; it goes down to 3.5" which is hard to find on other jacks; I still use it to date with the BMS jack pad on my F30 which isn't lowered but is RWD so it's low enough.
I also use it on my mom's 2015 VW Tuareg (corners) and other smaller vehicles so capacity isn't issue IMO. My only complaint is the rubber padding on the jack pad sheered off a while back; other than that it's been really reliable with zero maintenance. Jack (I have the older version though) http://www.canadiantire.ca/en/pdp/mo...0021p.html#srp BMS jack pad for BMWs: https://www.n54tuning.com/bmw-jack-pad.html
2016 Estoril Blue II 340i M Sport | ///MPPSK | 6MT | RWD | Fully Loaded
BM3 Stage 2+ 93 | B58TU HPFP | VRSF v2 Catted Downpipe | 550i Clutch |
04-26-2018, 02:04 PM | #11 | |
Rep 1,953
04-26-2018, 03:10 PM | #12 | ||
Rep 1,055
04-26-2018, 09:22 PM | #13 |
Rep 1,953
04-27-2018, 07:33 AM | #14 | |
Rep 1,055
This picture should give you an idea how it works... you have one of the plastic pieces at each jacking point under the rockers of your car (2 on each side). The BMS jack pad adaptor fits in it so your jack has a flat surface to lift from. [IMG]https://images-na.ssl-images-amazon....L._SL1000_.jpg[/IMG]
04-30-2018, 12:17 AM | #15 | |
Rep 1,953
04-30-2018, 12:45 AM | #16 | |
Rep 1,523
just buy this and be done with. |
04-30-2018, 10:42 AM | #17 | ||
Rep 1,055
04-30-2018, 10:49 AM | #18 |
Rep 348
Yeah, if you want to lift all 4 corners you'll need 4 pads... However, I just made mines out of 97¢ hockey pucks and a hack saw lol. Didn't think it was that easy to cut the pucks but you can simply hold them under a vise and just hack saw away. I had time and a case of pucks.
04-30-2018, 10:53 AM | #19 | |||
Rep 1,953
04-30-2018, 11:00 AM | #20 | |
Rep 1,055
This is a good video if you plan on putting your car on 4 stands... https://www.youtube.com/watch?v=ISHpkxt4cEw
04-30-2018, 11:06 AM | #21 |
Rep 348
Just checked, prema sells the esco stands @ $120 for a pair, you can make the pads yourself.
http://www.bimmerfest.com/forums/att...5&d=1285214235 http://www.bimmerfest.com/forums/att...6&d=1285214235 |
04-30-2018, 12:56 PM | #22 | |
Rep 1,953
