02-15-2019, 07:21 AM | #1 |
Rep 2
Steering wheel buttons not working
I have a 2014 BMW 320I and lately it seems that all the Steering wheels buttons not working properly:
Volume up/down buttons nor cruise control etc. If I honk on the horn couple of times they will all work then after a while the same problem... Anyone seen this problem or have an idea on what to do. |
02-15-2019, 05:49 PM | #3 |
Rep 1,953
Drives: 2013 328i xDrive
Well those controls work with harnesses attached to the controls, so it's either the harness, the buttons themselves or the connecting ports in the wheel itself.
05-14-2019, 08:20 PM | #4 |
Rep 6
Hi, I have a 328i Sport 2013 with same issue. If I turn the wheel 90deg it works, but after return to normal position after 2-3sec it stops working. Have to remove steering wheel and check connections?
12-13-2019, 01:19 AM | #6 |
Rep 3
Hi!
I have same issue on my F30 without M steering wheel. When I rotate the wheel sometimes buttons are not working then start to work again. Which cable did you check it ? Did you remove the airbag or steering wheel ? I' ll appreciate your help. Thanks |
