03-10-2015, 10:50 AM | #45 |
Rep 73
Still abit confused. So, correct me if i am wrong. Base 335 stock, msport blue and M car all have the same calipers and brake pads? Different only rotor either 340mm or 370mm?
Mine is 335 stock 4 pots with 340mm rotor. Is it possible to change the rotor only to 370mm? Is there any 2 pieces 340mm rotor replacement? Thanks. |
03-11-2015, 07:03 AM | #46 | |
Rep 10,351
http://f30.bimmerpost.com/forums/sho....php?t=1096751 |
03-17-2015, 06:31 PM | #48 |
Rep 25
I hope this isn't the wrong place for this but when I ran my VIN through the BMW Electronic Parts Catalogue, it says the replacement brakes for my car are M Performance brakes...I simply have a 335i XDrive Sport Line...thoughts?
03-22-2015, 03:38 PM | #49 |
Rep 1,055
Drives: 2016 340i M Sport 6MT+RWD
oceanview My car finally arrived at the dealership and I saw it yesterday; I can confirm that it has 340mm rotors up front as well. It's a 2015 428i GC Sport Line /w M Sport Brakes (2NH/S2NHA - it's the same thing for those who think otherwise).
Unfortunately, I didn't drive it and I can't take delivery for another 1.5 weeks due to a business trip |
05-27-2015, 05:11 PM | #53 |
Rep 1,123
I just went through every post on this thread. Sounds to me the breaking performance between 435i M-Sport Standard brakes and M-Sport blue calipers brakes ($650 option with 19" wheels) is the same.
Can someone comment on this? |
06-01-2015, 11:16 AM | #54 | |
Rep 603
same applies for the S2NHA Option with 370mm rotor in front. The BIG difference however is weight! 370mm Rotor of S2NHA = 16.5 Kilogramms 370mm Rotor of MPerformance Brake = 11.8 Kilogramms So unsprung mass is about 25% less. |
06-01-2015, 11:20 AM | #55 |
Rep 603
Available dimensions for various front and rear rotor are listed in the Excel table I provided:
http://1drv.ms/1FdPZ3B |
06-20-2015, 02:20 AM | #56 | |
Rep 180
06-20-2015, 10:10 AM | #57 | |
Rep 681
Yes, the weight is much lighter for the front M Performance rotore instead of M Sport! Almost 5kg less for each wheel!!! It's only strange that in the rear rotors there's an improvement of only 0,4kg for each wheel... Maybe different materials?
BMW M3 G80 Isle of Man
08-19-2015, 02:02 PM | #58 |
Rep 1
Just in case anyone knows, does the OEM Bembo/M-Sport Brake package come with Goodridge braided brake lines same as a retail Brembo set would? Or is it purely a caliper upgrade with standard hoses?
09-06-2015, 02:18 AM | #61 | |
Rep 681
09-06-2015, 09:52 AM | #62 | |
Rep 603
If you can tell me what weight you messured and for which rotor please, so I will put that into my table.
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
09-06-2015, 07:39 PM | #63 |
Rep 141
Does anyone know what aftermarket pads are there available for the M Sport S2NHA brakes? The only other pads that I can seem find are porterfield's.
2014 BMW 435i xDrive M-Sport "Elphie" | Mineral Grey Metallic | Coral Red Interior | M Performance Package I | Premium Package | ConnectedDrive | bootmod3 OTS Stage 1 93 Octane Tune | M Performance Exhaust | M Performance Stainless Steel Pedal Covers | Dinan Performance Spring Set | Dinan Supplemental Ride Quality | Precision Raceworks N55 Ignition Kit
09-08-2015, 08:30 AM | #64 | |
Rep 681
09-09-2015, 02:21 PM | #66 |
Rep 603
Grazie! I updated my Excel List.
