BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Sport plus coding not 2TB
      07-11-2017, 06:48 PM   #1
WajahatM
Drives: 2013 AW F30 335i xDrive
I'm sure how to code for sport plus is somewhere out there, but there are so many threads that only talk about 2TB. For now I'm wondering what codes to actually change to get sport plus. I'm using the Bimmercode app because it has an expert mode that seems pretty good and the developer said that coding for sport plus is possible but not 2TB.
Also is there a thread out there that talks about all the expert coding with Bimmercode, maybe a cheat sheet?
      07-11-2017, 07:58 PM   #2
redbullfan
redbullfan's Avatar
Drives: 2013 335i xDrive Luxury Line
Sport+ mode
ICM/3000 ICMKOD_B_SPORTLENKUNG nicht_aktiv ===> aktiv
KOMBI/3000 FDS_MENUE_TEXT_1/2/3/4 menue_4 ===> menue_3
KOMBI/3000 FDS_MENUE_SIGNAL_1/2/3/4 menue_4 ===> menue_3
Make sure you change the values for all 4 menus
Sport Automatic Transmission
EGS/3000 Applikation -> Sportschalter_alt -> aktiv
EGS/3000 Applikation -> Sportschalter -> aktiv
EGS/3000 Applikation -> LC -> aktiv
2013 335i XDrive Luxury Line
      07-11-2017, 08:24 PM   #3
WajahatM
Thank you very much sir
      07-12-2017, 02:29 AM   #4
adinair94
Drives: f30
Hi,
I had contacted the bimmercode dev as well regarding that, you cant use the expert mode in the ICM module yet, so it wouldnt be possible to code sport+ right now. Hopefully the dev adds this feature soon
      07-12-2017, 10:58 AM   #5
WajahatM
Yea I figured as much, I was messing around like an hour ago and couldn't expert code the ICM. Thanks for the code anyways, have it on a piece of paper in my car for when the app update comes it.
      07-12-2017, 03:05 PM   #6
redbullfan
redbullfan's Avatar
Hi,
Why don't you guys use esys??
      07-12-2017, 09:19 PM   #7
WajahatM
Bimmercode is really simple to use and the features I wanted were super easy to code, literally just toggle a switch and code. I might use esys but I actually have to learn then.
      07-13-2017, 01:43 AM   #8
adinair94
Drives: f30
Well I dont use esys since i believe you need the enet cable. I already had a wifi obd2 adapter lying around so bimmercode works with that.
Do those adapters work with esys too?
      05-10-2018, 05:00 PM   #9
Nd0udoinwork
Drives: Red 328i XDrive
Sport+ mode
all i get in the first step is verbaut or nicht_verbaut which one do i choose
      05-11-2018, 11:21 AM   #10
rflagg
Drives: F31
Verbaut.
      05-11-2018, 11:28 AM   #11
jgoens
jgoens's Avatar
3651
Drives: 2013 335i msport
No. You need to physically hook the car up to a computer.
      08-20-2018, 10:41 PM   #12
the_vermi
Drives: 2013 528i
Is the process for enabling Sport+ the same on the F10?
I have set ICM/3000 ICMKOD_B_SPORTLENKUNG to verbaut and set all the eight menu entries to menue_3. I see Sport+ in the menu when I hit the rocker switch, but I cannot select it.
SAT is enabled and seems to be working as expected.
      11-02-2018, 06:28 AM   #13
stev0258
Sport+ mode
Noob here. I have a 2013 335i Luxury Line, looking to get the Sport Auto Transmission shifting. How is the 2TB different than doing an auto trans flash like XHP flashtool? Called a local Indy Mechanic here in MN and they said that changing the VO codes is not recommended and that any subsequent update would result in the VO codes going back to stock, so this would require re-doing. Can someone break down the difference between changing VO codes vs. a flash? Appreciate it!
bimmercode, coding, f30 2013, sport+
