BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30 2016 LED Headlights retrofit.
proTUNING Freaks
      08-26-2021, 03:18 PM   #199
siknautojas
Drives: F30
Originally Posted by freespirit View Post
You need to teach turn signals using ISTA service functions.
Go to ISTA - service functions- body - lighting- teach turn signal.
I believe your car is euro spec and your fem is also euro coded.
I forgot to mention that I successfully did it, but nothing changed. My car is from USA, headlights EU.
      08-26-2021, 04:05 PM   #200
freespirit
freespirit's Avatar
83
Drives: f30 2016 BMW 328i
Aah there you go … my car is US too and I have installed ECE headlights. You need to change your type in FA to euro spec car (example 8E97 to 8E91) and then code FEM, FLE modules. However doing so will popup some FEM errors. You need to compare FEM cafd files coded with US spec vs Euro spec and set some properties back to US spec car like LIN variant, universal garage door opener etc.
Click appreciate if this post has helped you
Retrofits: NBT evo ID6, 6wb cluster, heated steering wheel, HUD, Kafas2 with LDW, SLI, HBA, FCW and pedestrian warning, LCW, Surround View, Parking Assist and ACC with Stop
      08-27-2021, 01:53 AM   #201
siknautojas
Drives: F30
Thanks for reply.
I have changed VO from 853 (Language version English) to 851 (Language version German) coded FEM and both FLE's without any faults, tryed to teach turn signals with ISTA again and ... no luck.
EDIT: both turn signals malfunctioned -_-
      08-27-2021, 07:43 AM   #202
freespirit
freespirit's Avatar
83
Thanks for reply.
I guess language version is different from the type code I am referring to. After you connect in esys, read FA and expand all the folders under it, you will something called Type or Type code above or below SALAPA elements. Sorry I don't have access to my car for next couple of weeks else I would have sent you a picture.
If you go to realoem and search in serial number with last 7digits of your VIN, you will see the type code of your car. Then change market to euro, prod date to something close to your actual car prod date, then u will see euro spec cars type code. You have to use the euro type code in your FA type code section.
All of the above is assuming your issue is at coding not in wiring
      08-27-2021, 03:24 PM   #203
siknautojas
Drives: F30
It worked! Did everything as you said all faults are gone and turn signals started working as they should. Thank you for your time, you really helped me out!
      08-27-2021, 05:15 PM   #204
freespirit
freespirit's Avatar
83
Excellent… enjoy the adaptive headlight show
Run the car for couple of days and then scan again with ISTA to see if there are any errors reported. You may have to FDL code few properties back to US values in FEM.
      01-15-2022, 04:22 PM   #205
SharkGrogu
SharkGrogu's Avatar
Romania
Drives: BMW 320i F30 LCI
Hello guys,
I'm about to code non-Adaptive Led Headlights on my LCI F30 that has halogen right now.
Do I have to remove any option from FA, or just to add 5A2?
      01-15-2022, 04:27 PM   #206
Jhnblckwood
Drives: F30 2014 320i xdrive
Originally Posted by mbogdan21 View Post
Hello guys,
For my pre lci f30 I just added 5A2. I had to run ista and initialize the led’s. If it doesn’t work after coding run ista.
      01-19-2022, 11:27 AM   #207
SharkGrogu
SharkGrogu's Avatar
Romania
Hi guys,
Please some answers to a brother in need.
1. Shouldn't I disable some functions from ICM since I didn't install level sensors?
LED Headlights are non-Adaptive, so I get an error: Headlamp vertical aim control malfunction.
2. FLE coding should remain with USA or EU specs?
- USA F30 LCI with halogen to EU LED Headlight
- first I changed FA -> code for car type from USA to EU
- recalculated FA and recoded FLE43 & FLE44 with EU specs -> LED headlight brought to life
- FA changed -> from EU type back to USA
-recalculated FA and recoded FEM with USA specs
Signals aren't working properly
Both are blinking normally two times, fault appears on idrive and turn signal disappears.
This is the only problem for them.
With INSTA I taught them, operation successfully, but still not working.
errors in ISTA
- 480069 - ICM: Ride-height sensor, front left, measured voltage
- 48006F - ICM: Rear left ride-height sensor, measured voltage
- 480116 - ICM: Carrying out ride height adjustment
- 8041B6 - LWR system faulty
- 805C80 - Turn indicator: Voltage outside of tolerance range
- 805CAB - Side marker light: Open circuit
- 805E00 - Turn indicator: Voltage outside of tolerance range
- 805E2B - Side marker light: Open circuit
      01-19-2022, 11:37 AM   #208
gameson
Drives: 2015 BMW 320i N20
How much is the ece headlight for a set? Does the adaptive function work after coding? Thanks.
      01-19-2022, 12:23 PM   #209
Jhnblckwood
Originally Posted by SharkGrogu View Post
Hi guys,
errors in ISTA
I believe my turn signal didn’t work correctly until I coded the rem also. As far as the level warning that can be coded out in the fem. LWR_AHL_TYP to "ohne" and LFC_AKTIV to "nicht aktiv" should sort that out.as far as switching regions I can’t help u there.
      01-19-2022, 12:53 PM   #210
freespirit
freespirit's Avatar
83
I have paid 2500usd all oem modules. Yes it's working perfectly after coding and I still have it on my car.
      02-25-2022, 06:42 AM   #211
Patje
patje
Netherlands
Drives: BMW F34
Hello Guys,
I'm a newby here and like to read these threads.
I live in the Netherlands and drive BMW for many years. Love the way they drive and reacts.
I Like to do some small codings but never replaced any modules and then code this.
I would like to have your opinion as I'm thinking to upgrade my BMW F34 2014 with adaptive Xenon to adaptive Led.
I use the FLA option often when driving in the dark, will this be the same usable as with Xenon without any problems, like blinding other users of the road?
How can I check if the components like FEM are usable / compatible with LED headlights.
Does some have experience that a F30,F31 will be the same as F34 in regards to wiring?
As for adjustment for headlights view is this done automatically of do you need to adjust this manually first? Like the garage do with normal headlights.
I still have a lot of reading to do of course but would apreciate your input / point of view.
Thanks and regards.
      02-25-2022, 11:34 AM   #212
dv8ed
Drives: 2013 F30 328i N26
Why are ECE headlights cheaper on eBay? Can't seem to find US headlights at a good price.
2013 F30 328i N26
      04-05-2022, 09:49 PM   #213
Vdubz
Vdubz's Avatar
Thailand
Drives: 320d lci
I have upgraded from standard LED to Adaptive LED so my experience may not be same as yours. But yes you need to inject new cafd files into FLE module and code them using your new FA with updates VO options.
Hi there!
Thisnis exactly what i am planning to do. Standard led light output is very poor so i am planning to convert to adaptive led without HBA as I don’t have KAFAS installed. I am wondering if i can use ledrl modules, indicator modules, and main led module from standard led in adaptive led. I noticed the the main module has some variett - one says FLE2, another says FLE2max
Thank you
      04-05-2022, 10:59 PM   #214
freespirit
freespirit's Avatar
83
Originally Posted by Vdubz View Post
Hi there!
Thank you
Are you trying for US led to US adaptive or ECE led to ECE adaptive or US led to ECE adaptive?
I did US led to ECE adaptive and based on my experience led module and adaptive modules are different and may not work interchangeably.
Vdubz0.00
      04-05-2022, 11:20 PM   #215
Vdubz
Vdubz's Avatar
Thailand
Drives: 320d lci
It is ECE led to ECE adaptive. I checked module on realoem and couldn’t tell difference
Based on realoem
For vehicles with
Adaptive LED headlight
or
LED headlight
S552A=Yes
S5A2A=Yes
01 Control unit for front light electronics FLE2 2 63117457875 ENDED
01 Control unit for front light electronics FLE2 2 63117492028
01 Control unit for front light electronics FLE2 2 63118494844
If i have either of the above module in standard led, does it mean i can plug and play to my adaptive?
      04-05-2022, 11:25 PM   #216
freespirit
freespirit's Avatar
83
Based on realoem
For vehicles with
or
LED headlight
S552A=Yes
S5A2A=Yes
You may have to do more than that. Pm me your VIN so I can check.
      04-06-2022, 12:12 AM   #217
Vdubz
Vdubz's Avatar
Thailand
Drives: 320d lci
It will definitely involve decoding but i want to make sure that hardware works. How do you find standard led compared to adaptive led? I will pm you VIN asap
      04-06-2022, 08:19 AM   #218
cedchung
Mauritius
64
Drives: 2011 F25, 2014 F30
Does anyone know what happens if Adaptive LED headlights are retrofitted on a car without kafas camera or FLA?
      04-06-2022, 08:42 AM   #219
freespirit
freespirit's Avatar
83
How will your car know when to turn on/off the auto highbeams?
If you are looking for glare free high beams, tunneling etc like in euro cars then it won't work. May be what works will be side to side beam movement based on your steering wheel position.
Hope it makes sense 🙂
      04-07-2022, 01:37 AM   #220
Vdubz
Vdubz's Avatar
Thailand
Drives: 320d lci
I am very new to this forum. I think I am required to make 4 post replies before I can use PM system
