05-19-2018, 07:03 PM | #1 |
Rep 5,456
Drives: F30
Finally getting around to my conversion...
LED Parking - https://www.ebay.com/itm/131903750889 LED Low Beam - https://www.ebay.com/itm/2xH11-H7-H1...53.m2749.l2649 LED Fog - https://www.ebay.com/itm/New-2pcs-H8...72.m2749.l2649 High Beam - https://www.ebay.com/itm/PHILIPS-Dia...72.m2749.l2649 DRL - Coded off. *I have BimmerCode for necessary coding. Last edited by sspade; 05-26-2018 at 01:33 PM.. |
05-19-2018, 08:25 PM | #3 |
Rep 5,456
Drives: F30
Like these? Can you confirm these fit into stock housing without modification?
https://www.ebay.com/itm/HIKARI-LED-...rd!95624!US!-1 |
05-19-2018, 08:47 PM | #4 |
Rep 4,456
Just google led low beam headlights for a 2014 f30 328i
https://www.google.com/search?q=Just...Moqg8AOc-bnwAw |
05-19-2018, 08:56 PM | #5 | |
Rep 5,456
Drives: F30
Hmm... anyone else? Edit: I do see RoadSun mentioned a couple times but cannot find on eBay. I don't have an Amazon membership. Last edited by sspade; 05-19-2018 at 09:03 PM.. |
05-19-2018, 09:07 PM | #6 |
Ż\_(ツ)_/Ż
537
Rep 1,000
BEAMTECH H7 LED Headlight Bulb, 50W 6500K 8000Lumens Extremely Brigh CSP Chips Conversion Kit https://www.amazon.com/dp/B06XH38CDR..._VGnaBb7MN6DDJ
This is what I put in mine they have a lightning deal on amazon right now 8 dollars off for the next two hours they're awesome had them in for a month so far Here's what they look like |
05-19-2018, 09:18 PM | #7 | |
Rep 4,456
I personally bought some led bulbs from one of our site sponsors and just upgraded the high beam to a bright white color bulb since I don’t use it that much. Also went led fog bulbs as well. Don’t forget some coding will need to be done to keep the led bulbs from flickering. Good luck. |
05-19-2018, 09:20 PM | #8 | |
Rep 5,456
Drives: F30
I can use these for both the high beam and low beam correct? Also - what did you use for the fogs? |
05-19-2018, 09:27 PM | #9 | |
Rep 5,456
Drives: F30
What Halogen high beam did you choose, I was planning to go the same route... What LED H8 did you use for fog? |
05-19-2018, 09:38 PM | #10 | |
Rep 4,456
First post shows the led bulbs and resisters I used in one of the pics. And also list the led bulbs I bought for the high and low beams. When I switched to the retro headlights I got rid of the leds and went with HID and the regular bulbs for high beams. I used xenesis tru-match bulbs. |
05-19-2018, 09:48 PM | #11 |
Rep 5,456
Drives: F30
Bought these for the Low Beams... hoping they fit well.
Special thanks to voonoo for the suggestion. https://www.ebay.com/itm/2xH11-H7-H1...53.m2749.l2649 |
05-20-2018, 07:48 AM | #13 |
Rep 5,456
Drives: F30
05-20-2018, 10:51 AM | #14 |
Rep 5,456
Drives: F30
I'd feel guilty replacing my Fog's with these but unless someone can recommend better, Ill probably give them a shot.
https://www.ebay.com/itm/New-2pcs-H8...53.m1438.l2649 |
05-20-2018, 11:29 AM | #15 | |
Rep 68
https://www.ebay.com/itm/S2x-H8-H9-H...EAAOSwyYFaHPGI |
05-20-2018, 12:26 PM | #16 | ||
Ż\_(ツ)_/Ż
537
Rep 1,000
edit: just saw the fogs you bought i'm pretty sure those are just for look and not function Last edited by vooonoo; 05-20-2018 at 01:52 PM.. |
05-20-2018, 01:11 PM | #17 |
Rep 69
I got these for my car last month. Super bright, matter of fact it may be a little too bright lol. But pattern is good and consistent.
Lows http://www.ddmtuning.com/Products/Saber-50W-H7-LED-PR Fogs http://www.ddmtuning.com/Products/Raptor-35W-H7-CSP They’re not plug and play. Had to code out the warm and cold checks to prevent the flickering. Have been working well for about a month now. |
05-20-2018, 02:48 PM | #18 | |
Rep 16,082
http://f30.bimmerpost.com/forums/sho....php?t=1377259 someone else posted a similar tutorial. Nonetheless the same questions keep coming up on an almost daily basis, sometimes in simultaneous posts. |
obert1781.00 |
05-20-2018, 03:30 PM | #19 | |||
Rep 5,456
Drives: F30
I definitely disagree. Not saying I didn't take an $8 gamble but I believe, if they work - they will be bright and functional especially since they have both forward and side facing LEDs. I will confirm when they arrive and post pics. |
05-20-2018, 04:15 PM | #20 |
Rep 16,082
Forward facing LEDs are often the reason for a bad beam pattern and blinding oncoming traffic. Halogens don't send light forward for that reason. Preventing forward light transmission is why halogen bulbs have a dark coating on the front of the bulb.
05-20-2018, 05:52 PM | #21 |
Rep 69
They fit into the stock housing. The only trickery is getting your hands and head in the wheel well at the same time. You can either look at where the bulb goes, or you can put your hands in there, but not both. I took a pic with my phone so I could see what I was feeling in there...
05-20-2018, 07:31 PM | #22 | |
Rep 5,456
Drives: F30
Im not saying they wont be blinding - they very well could be, my assumption is that since they are low to the ground and rarely used... Ill be fine. I definitely don't want to be "that guy" blinding every car I pass in the dark. |
