01-23-2021, 03:51 AM | #2685 | |
Rep 15,858
This morning the 'experts' were discussing the possibilities and suggest either the higher mortality is due to the variant changes, or there is much more virus about. (I interpreted that as viral load, more than just the numbers). If it is just more virus and not viral load, there must be something else in the mix, if the mortality rate goes up. Does indicate we need to be more vigilant now, than ever. Using all means we have to protect ourselves. The other point of discussion was catching the virus again. Latest controlled study indicates something like 15 - 20% in the study who had antibodies have got it again. Antibody 'drop off' being the suggested cause. This suggests to me, if the vaccines do get this virus under control, we'll likely be in a rolling vaccine program well into the future. |
Hooded1669.00 |
01-23-2021, 08:17 AM | #2686 | |
Rep 7,703
The middle ground for the transmission increase for this is 50%, so increase the current deaths from 100,000 to 150,000m because more people would have caught it. Then add 30% more deadly onto that and you’re only just shy of 200,000. Just a good job it didn’t appear months and months pre vaccine, let’s hope they're still effective against it and we can control this version as well in the next few months. |
MashinBenzin8450.00 agentorange1504.50 |
01-23-2021, 08:20 AM | #2687 | |
Rep 2,273
01-23-2021, 08:28 AM | #2688 | |
Rep 3,967
If immunity does start to wane over time (say 6-9 months), it would also make it prudent of me waiting until Autumn to get my own Jab (although that isn’t the main reason I’m actually delaying it) as it’s likely virus levels in the community would still peak during winter like the flu. |
01-23-2021, 08:33 AM | #2689 |
Rep 3,967
Yes I’ve been reading up on that today and the person behind the research is surprised Boris made the announcement. Also Quoting there’s a 50-50 chance it is actually the case!
01-23-2021, 09:15 AM | #2690 | |
Rep 5,681
Having said that, if that's what they'd done - and it had later emerged there had been data to suggest a higher level of mortality weeks before they'd announced it - they'd then have been accused of a cover-up. So to be fair the government is probably in a no-win situation and have therefore perhaps decided transparency is the better option? After all, if people are worried about increased mortality with the new virus that's only likely to encourage compliance with the restrictions (which is no bad thing!). |
01-23-2021, 09:35 AM | #2691 | |
Rep 6,938
If they had tightened the lockdown instead, they would face some flak from the far right of their party, so this is an easier option. Perhaps even quite sensible... |
Hooded1669.00 JNW13122.00 pmgreenwood483.00 ZedsRedBaby1762.50 Ennoch2257.00 Ronstein416.00 Blacktemplar3457.00 |
01-23-2021, 10:15 AM | #2692 | |
Rep 12,228
01-23-2021, 01:29 PM | #2693 |
Rep 2,273
01-23-2021, 07:16 PM | #2694 | ||
Rep 1,641
So the question is why do the mutations in the spike protein in the UK B117 variant cause increased transmission? It seems that this virus more effectively binds to cells via the receptor (such as ACE2). If so that likely means you need less virus per dose to initiate an infection. This would mean more infections and a corresponding increase in hospitalizations and deaths. But there is a second issue that could happen, by changing binding ability because of these mutations, it could also change what respiratory tissue it infects - that is perhaps these mutations favor deeper infections in the lungs (so more lower respiratory infections). I will be curious if that is what the ICU Docs and Pulmonologists are seeing right now. That would negatively influence patient outcomes even in the presence of better drugs and treatments. If the data is real it would be bad and for us, since this virus just starting to zip around the various states now, we could be seeing some bad news in a few weeks. |
01-24-2021, 02:51 AM | #2695 | |
Rep 3,279
Steroids have helped, and IL6 blockage in some patients appear to be a 'miracle" - though the stock of Tocilizumab is very sparse now, our pharmacy is trying to source nationally with barely 48hrs of stock at current usage rates so its use is now in effect rationed due to supply. This new strain is very different from the first, where isolation of a patient in a ward was enough before it now just spreads and spreads. Am pretty sure the fact any patient can test 'negative' after exposure is more to do with the test than infection. Pretty much all the nurses on our 'clean' ward now have COVID antibodies and thats not due to the vaccine! I do half think about the inevitable mutation that will come that will side step all the current antibodies generated by the vaccine/current infection- but I don't understand enough about antigen recognition/T cell responses to really think about that depressing scenario. What I am doing though is stopping planning for anything beyond 7 days time, so much seem to change so quickly with the situation. Stay safe and healthy, I do fear for the first time in decades the average life expectancy of the western world will start falling - wiping out decades of preventative healthcare work in less than 12 months, with no real end in sight as this virus is now endemic. Our inpatient hospital mortality is currently around 25-30% for all patients, I suspect that is an underestimation as time to death from admission is at least 7 days with us seeing more admissions than death daily so we haven't reached steady state yet interms of mortality rate. Our normal inpatient mortality rate is around 5%. Last edited by gangzoom; 01-24-2021 at 02:57 AM.. |
01-24-2021, 03:52 AM | #2696 | |
Rep 15,858
They are overwhelmed as we likely know, but it is not just the extra deaths, it is the way and speed that many with Covid are now dying. Something does appear to be different, not what we really want to be hearing. |
01-25-2021, 08:00 AM | #2697 | |
Rep 3,211
but you can enjoy your bloody lockdown over there cross the pond mate |
01-25-2021, 08:09 AM | #2698 | ||
Rep 8,772
Grammar. Punctuation. The irony of an American stating that not all the world exists within one country. The World Series baseball when it's on. Functioning brain cells.
Drives - 2020 LR Discovery HSE-L Previous - 2019 LR Discovery HSE-L // 2016 F36 440i // 2009 E90 320D SE |
Blacktemplar3457.00 Hooded1669.00 Grant_72020.50 Goneinsixtyseconds4278.50 ZedsRedBaby1762.50 CajunBMW1288.50 Lincoln61746.50 isleaiw18747.00 Ennoch2257.00 DougMcL787.00 |
01-25-2021, 08:30 AM | #2699 |
Rep 3,967
01-25-2021, 08:31 AM | #2700 |
Rep 3,665
MashinBenzin8450.00 |
01-25-2021, 08:39 AM | #2701 |
Rep 1,926
The first post in this thread to make me laugh!
F31 340i | GS with CR & Ash Grain Trim | M Sport+ Pack | Prof Media Plus Pack | Interior Comfort Pack | Leather Dash | Folding Mirrors | Pano Roof | Elec Mem Seats with Lumbar | Adaptive Suspension | Comfort Access | Reverse Cam | Surround View | SLD | Rear Sunblinds | Folding Headrests | Model Designation Delete | Trim Designation Delete | MPPSK
01-25-2021, 08:43 AM | #2702 |
Rep 1,641
Some of us over here like grammar,;:,;: and punctuation too.!?.!?
01-25-2021, 08:48 AM | #2703 |
Rep 1,641
But yes flu levels are low worldwide and this is definitely due to masks, distancing, and lack of large crowds. That is certainly the official view of folks in the Infectious disease field. Not sure we need to confirm this point, but that is the word on the street.
01-25-2021, 09:43 AM | #2704 |
Rep 8,772
Don't worry, all aimed at the poster of the comment (I think that's what it was). Got a lot of good friends over your side of the water and plenty of respect for Americans. I did enjoy the World Series irony though
01-25-2021, 11:15 AM | #2705 | |
Rep 1,641
01-25-2021, 11:28 AM | #2706 |
Rep 941
You say 'wet' and 'Louisiana ' and I've got Randy Newman's 'Louisiana' playing in my head
2019 640i GT MSport & 2016 X3 3.5D X-Drive MSport
Previous - 2016 530D MSport - 2016 335D Touring M Sport X-drive - 2014 335D GT X-Drive MSport |
