01-22-2021, 01:54 PM | #1 |
Rep 13
Lumbar Support in bmw
When you adjust the lumbar support in a bmw, is it supposed to make some sort of noise? When I press the button on the side of the passenger and drivers seat, nothing happens(to my knowledge). I had assumed there would be a motor sound as it re positions the lumbar support.
This is on a 2016 340i. |
01-22-2021, 02:21 PM | #2 | |
Rep 3,752
It will cost around $500 to fix out of warranty. Just got mine fix under warranty but my SA told me that much. You can do it your self. Parts cost around $249 to 329 depend where your buying it.. it comes with relay included. They are not separate (even tho they are separate visually they are sold together. I already ask bmwparts. |
01-22-2021, 02:52 PM | #3 | |
Rep 1,452
undertaker63.50 |
01-22-2021, 03:52 PM | #4 |
Rep 13
I don't really feel anything happen when i press the different lumbar support buttons. I'll fiddle around and see if anything actually happens when I press the buttons.
01-22-2021, 03:53 PM | #5 | |
Rep 13
01-22-2021, 04:42 PM | #6 | |
Rep 3,752
If not there are plastic tab under the plastic cover behind the seat. Remove the plastic and examine yourself what is wrong. The motor aka air pump nuematic should be inside a bag with clear hose going to a solenoid. Open it and examine what is not working... Possible it's just a air tube lose on the pump. Have a go at it and post back. |
