10-15-2020, 09:31 PM | #904 | |
Rep 212
11-15-2020, 08:07 PM | #905 |
Rep 135
Aodhan AFF7 Matte Bronze Wheels on ST-XA coilovers.
No rubbing with this setup at all 225/40 - 19x8.5 ET35 255/35 - 19x9.5 ET35 |
11-23-2020, 06:26 PM | #909 |
Rep 60
Thank you ! Wanted to try something different, I think only reason it works is because of the white
11-23-2020, 06:30 PM | #910 |
Moto Lover
187
Rep 591
Drives: '19 BMW S1000XR
11-24-2020, 02:02 PM | #911 |
Rep 133
18x9.5 ET 22 square
FOR SAE!! |
TOPOLogies71.50 BMW BRAD202.50 |
11-24-2020, 08:58 PM | #912 |
Rep 212
New to me Apex Arc-8s
itsrichierich186.50 saga boy299.50 |
11-25-2020, 02:09 PM | #913 | |
Rep 576
11-25-2020, 04:28 PM | #914 |
Rep 1,475
how'd you get your fogs and headlights blue?
11-25-2020, 04:33 PM | #915 |
Moto Lover
187
Rep 591
11-27-2020, 05:30 AM | #916 | |
Rep 60
VViViD Air-Tint Extra-Wide... https://www.amazon.com/dp/B01KGKIG7M...p_mob_ap_share |
SuperHamz742.00 |
11-28-2020, 10:10 PM | #917 |
F30 Noob
Rep 24
A lot of wheel envy as I look through this thread!!!
I've got a 2017 340 x drive and am definitely planning on a modest drop with springs or just going with KW coils sometime in the future. I see A LOT of staggered setups with 9.5" wheels in the rear. Can the front accommodate 9.5? I've seen some of you running 18x9, 19x9 square all around, which is something I'm thinking about doing. Is this the place to ask about fitments and whatnot or is there another thread for that? I've always used the tried and true "willtheyfit.com". I'm new here, and love feedback from people that actually own and drive these. Sorry if this is the wrong place to ask! |
11-29-2020, 09:54 AM | #918 | |
Rep 135
https://f30.bimmerpost.com/forums/sh...4&postcount=14 |
01-24-2021, 05:35 PM | #921 |
Rep 14
Hello. Im new here. I was wonder if this set up would cause any problem to my car as far as rubbing or ride quality
I have a 2014 328i Sport Line. Current stock OEM wheel are 18x8 and tires are 225 45 18 with default offset of 35mm Can i get a set of wheel in 19x8.5 up front 34mm offset tire will be 225 40 19 and rear 19x9 back with 40mm offset and 255 35 19. Any suggestion? |
01-24-2021, 09:10 PM | #922 | |
Rep 4,315
245/35/19-255/35/19 for best handling OR---> 235/40/19-265/35/19 for most comfortable and reduced fenderwell gap at stock ride height. none of these will have problem rubbing. |
01-27-2021, 09:02 AM | #923 |
Rep 118
Drives: 340i
Look Fantastic. Can you detail the specs out? width/offset etc
now: 2017 340i M-Sport then: 2009 E92 M3 DCT |
02-01-2021, 06:12 PM | #924 |
Rep 2
Wheel gap and thoughts
I know I know these wheels are the best looking on here and I’ll probably get crushed but I just bought it and they were on there. Looking at getting some 18s for more rubber and wanting a more aggressive stance. These are 20s with 265/30 zr20 and I like the wheel gap fine. These are supposed to be a 26.3 wheel and tire diameter. If I get 18s at the same height will that work on keeping the wheel gap the same? Any recommendations? I’d like a wheel with a lip on it as well not a flush wheel.
