08-03-2018, 11:44 AM | #1 |
Rep 9
Manual Tow Hitch on F20
Hi! I've added a tow hitch to my F20. Just a manual tow hitch, not 3AC or something else. I want PDC to be descativated when my bike rack is plugged. What do i have to code? I own E-SYS and an enet cable. Thanks.
08-03-2018, 03:36 PM | #3 |
Rep 2,302
That's no problem to post it here because F20 and F30 have the same ecus.
3AC is the code for the trailer hitch not specially for the swiveling trailer hitch. So you can/should code the 3AC to your car. |
08-08-2018, 01:35 PM | #4 |
Rep 9
Thank you for your answer. Have you any tuto to make this on Esys or perhaps i should install ISTA?
08-09-2018, 12:42 PM | #5 |
Rep 2,302
https://www.bimmerfest.com/forums/at...hmentid=413187
This is an instruction to VO/FA coding. In step 5 you have to add the "3AC". After step 10 you still have to code (not fdl code) the ecus FEM, ICMQL, REM, DSC, HU and Kombi. For this you have to load the changed VO/FA then mark the ecus and push the button "code". |
08-09-2018, 01:09 PM | #6 | |
Rep 9
08-17-2018, 06:56 AM | #7 | |
Rep 9
Hi. I didn't have time to work on it before today.
I've just try it but it doesn't work. When i calculate FP after adding 3AC i get this error: Quote:
08-17-2018, 07:58 AM | #8 |
Rep 2,302
Yes, i thought so, because i found out that the F20 doesn't understand the "3AC".
"3AC" seems to be only for F3x cars. The VO code for the F20 tow hitch is "235". I think this should work. Sorry for the wrong information. |
