BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F34 3-Series GT (Gran Turismo) Forum > 320d GT M sport Active Rear Spoiler
proTUNING Freaks
      06-29-2020, 03:38 PM   #1
Jamesfwillis
Drives: BMW 330d
Evening All,
Not new to BMW but new to the GT i've just bough and I have a question which i'm hoping somebody can answer for me.
the rear spoiler you can control with a button on the drivers door however id like to know the following if possible.
should it raise and lower automatically
and should it lower etc when to park up and lock the car ( if so how do you set it )
currently i have the green light on the button drivers door.
Many thanks
      06-29-2020, 03:49 PM   #2
pdxdbo
pdxdbo's Avatar
331
Drives: G20 330i xDrive M-Sport
Hi James,
If the light is green that means it's been manually deployed, and it will remain so until the button is pressed again (while the vehicle is on). Otherwise the the spoiler will deploy at roughly 67mph and retract around 50mph (off the top of my head so I may be a little off). These values can be customized by coding via something like Bimmercode if desired.
      06-29-2020, 04:03 PM   #3
Torquey
Drives: 335i GT | 550i 6MT
^^ just like PDX said.
I did try to change the limit when the spoiler goes down from 70 to 40Kph and goes up from 110 to 120Kph via Bimmercode and the module kept erroring... so I set it back to default.
      06-29-2020, 04:15 PM   #4
Jamesfwillis
Drives: BMW 330d
Originally Posted by pdxdbo View Post
Hi James,
Perfect thanks so I need to turn green light off is that correct
      06-29-2020, 05:30 PM   #5
pdxdbo
pdxdbo's Avatar
331
correct
      06-29-2020, 10:45 PM   #6
JinksF34
JinksF34's Avatar
Drives: BMW 330D GT M Sport
Also you will have to hold the button down slightly longer to bring the spoiler down
      07-04-2020, 06:13 AM   #7
parmap
Drives: BMW 320D GT
Hi James,
Hello you weren't miles off at all! The spoiler deploys at 68mph and retracts at 48 mph (well mine does) I'm also new to the GT model so looking at modifying as funds allow over the next few months.
Regards Parmap
