BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > M-Display in Kombi
      08-27-2017, 10:18 PM   #67
wiigin
Drives: BMW F34
1: vo,remove 205\2TB
2: change fa
Entwicklungsbaureihe=F080
Typschlüssel=3C91
3: code kombi
4: change back fa type to your's , write fa
5: done
      08-28-2017, 07:26 PM   #68
Almaretto
Almaretto's Avatar
2374
Drives: Test Vehicles
2: change fa
Typschlüssel=3C91
3: code kombi
5: done
Why not just load modified FA rather than taking time to write and re-write to VCM?
      09-13-2017, 07:07 AM   #69
AVCI1
Drives: Bmw 4.28
2: change fa
Typschlüssel=3C93
3: code kombi
5: done
Please describe detailed.
      09-15-2017, 01:37 PM   #70
mhhforyou
mhhforyou's Avatar
62
Drives: F36 420da
2014 BMW 420da  [0.00]
Why so extrem complicated?
Only thing you have to do with option 205 or 2 TB :
KOMBI > GETRIEBE_ART > handschalter
KOMBI > M_VARIANTE > motorsport
D Drive malfunction problem solved....
      09-17-2017, 10:20 AM   #71
AVCI1
Drives: Bmw 4.28
The detailed codes, can you write ? To me it doesn't work.
      01-08-2018, 09:16 AM   #72
rinvnpy
My F30 retrofit 6wa m3 working good.
      11-16-2019, 10:37 AM   #73
karlmarx
Drives: BMW F30 2012
detail coding please because I have retrofited but gear number alway flashing.
bg
      09-08-2021, 08:08 AM   #74
Doublen420
Drives: BMW 335i xdrive
Anyone able to over come the driver train malfunction issue when you put it in drive all the time?
      07-04-2022, 04:24 AM   #75
gengis
Spain
Drives: BMW 335i xDrive F30
Originally Posted by Paolo73 View Post
And this is the M Hud...
View post on imgur.com
It's used kombi,the red dot will disappear once My Vin will replace the former One.
It takes to clear the eprom inside the cluster.
The kombi costs 499 euros.
I have to Thanks @Franzzz for helping me coding the Kombi.
Some little issues will be fixed soon.
My 435 with MPPK had the Ecu unlocked last month..now is nearly 400hp with no speed limiter..and is very fast and with this M Kombi I can clear watch the speed.
How did you managed to get the cluster working on the 435i? Could you provide the coding you did to not show any malfunction?
Thank you
