BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30/F20 TPMS Retrofit
      08-21-2016, 07:05 AM   #23
Lancelot
France
568
Drives: 2017 m550i
Also why is this thread about rear view camera referencing the same PINs on the same connector? Confusing me.
A173*8B PIN 51 & 52 are mentionned for the rear view camera, what happens if I need them for the TPMS?
http://f30.bimmerpost.com/forums/sho...=873744&page=9
2017 M550i | Sophistograu
Previous cars: 2014 F30 ActiveHybrid 3 | 2012 f20 M135i
      08-21-2016, 09:22 AM   #24
atzebmw
Drives: Tesla Model 3
Yes that's normal.
Because these 2 wires are for the CAN-Bus.
And this can branch off multiple.
As i remember these 2 PINs are also for the trailer hitch.
So if you have a trailer hitch you also can branch off these two wires in the trunk if you find them there.
      08-21-2016, 09:41 AM   #25
Lancelot
France
568
Drives: 2017 m550i
Ah OK so I can just take the existing orange/green orange cables and do a Y with each?
Sorry for the beginner questions, first time i'm tapping into what i understand is the CAN bus.
Thanks for your help
      08-21-2016, 10:03 AM   #26
atzebmw
Yes, make a Y with each cable.
Lancelot567.50
      09-05-2016, 12:50 PM   #27
Lancelot
France
568
Drives: 2017 m550i
I made it finally thanks to the extremely valuable info from you here.
I got my ECU 6855180 (from gribouille1210 thanks !) + 4 sensors 6798872 from Ebay Germany, then wired per the instructions here + more explanations from gribouille.
+ holder 36206852245 to the bottom tank (I think it would have worked fine in the trunk too to be honest).
The wiring goes under the car through a hole underneath the combox in the trunk, power from fuse 132 (used an "add a fuse" device like this one ) and the ground from the lighter ground wire in the trunk
Then FDL coding with almost exact instructions here, one slight change:
FEM
RC_RDC_ENABLE = aktiv
ICMQL
IcmKod_B_S2VBA = verbaut
DSC
C_Funktion_RDCi_l = nicht_aktiv
C_Funktion_RPA_e = nicht_aktiv
C_RPA_Extra = nicht_aktiv
HU_NBT
RDC = aktiv
RDC_DRUCK_TEMP = druck_und_temperatur
RDC_FORTSCHRITTSANZEIGE = nicht_aktiv
REIFENUEBERWACHUNG_RDC_RPA = rdc
RPA = nicht_aktiv
KOMBI
ST_TYR_RDC_ALIVE = aktiv
ST_TYR_RDC_TIMEOUT = aktiv
KOMBI DSC_MIT_RPA = ohne_RPA
One question though, perhaps to atzebmw - I see in HU_NBT an option named RDC_SAFETY, which is set to "nicht_aktiv" - why is that? Why not "aktiv"?
      09-05-2016, 01:30 PM   #28
Lancelot
France
568
Drives: 2017 m550i
I just change d RDC_SAFETY to aktiv and RDC_FORTSCHRITTSANZEIGE to aktiv just to see the difference.
And for good measure, a photo
      09-06-2016, 07:43 AM   #29
THE_AVIATOR
THE_AVIATOR's Avatar
Egypt
Drives: F30 320i LCI M-Sport
Hi all,
I'm thinking about retrofitting TPMS in my F30 LCI. As per the above instructions and part numbers, I find that the TPMS module is not available for F30 LCI. Any one has any idea about a new part number, or if it was integrated in another module?
Thanks a lot
      09-06-2016, 07:52 AM   #30
atzebmw
Originally Posted by THE_AVIATOR View Post
Hi all,
Thanks a lot
The F30 LCI has the TPMS as standard.
It is standard since end 2014.
You can see it at the tyre valve.
If ou have TPMS you have a metal valve.
If you don't have TPMS you have a black rubber valve.
I think you only have to activate the display of the pressure and temperature.
      09-06-2016, 07:54 AM   #31
atzebmw
I think this value makes no difference.
But I must also admit that I do not know what that value means.
The codings from above are exactly the same like VO coding.
Lancelot567.50
      09-06-2016, 08:04 AM   #32
THE_AVIATOR
Egypt
I have a rubber valve
But does that mean, if I get sensors, then I'm good to go? :O
      09-06-2016, 08:13 AM   #33
atzebmw
I really wonder about this.
But maybe only in germany the TPMS is standard since end 2014.
If you want to retrofit the TPMS you need the sensors in the tyres, the control unit, 4 cables and someone to code it.
      09-06-2016, 08:25 AM   #34
THE_AVIATOR
Egypt
Thanks! This is weird, I just checked on technical document for LCI, and there's no TPMS module present, while in pre-LCI it is present.
When I check on bmwfans.info there's nothing for F30 LCI to do with any TPMS modules. So, may be the module is integrated in FEM, REM (more logical) or ICM?
      09-06-2016, 08:43 AM   #35
atzebmw
Normally the control unit for TPMS from 03/2014 is integrated in the DSC-Modul.
Before 03/2014 there was an own control unit.
In my car (and some other users here) i have a control unit from a BMW F10, which works too.
      09-06-2016, 08:54 AM   #36
THE_AVIATOR
Egypt
That's a screenshot from E-Sys of my DSC Module! This means, it has built-in RDCi, correct? If so, I guess, if I get the sensors (metal valves) and do the coding, it should work.
      09-06-2016, 09:37 AM   #37
atzebmw
No.
These codings can be found in all cars, also with no TPMS.
      11-03-2016, 12:29 PM   #38
THE_AVIATOR
Egypt
On your pic it is Nr. 9.
For coding you can VO code "2VB" in FEM, ICM, HU_NBT, Kombi and DSC.
Or here the manually codings:
FEM
ICMQL
DSC
HU_NBT
RDC = aktiv
RDC_DRUCK_TEMP = aktiv
RPA = nicht_aktiv
KOMBI
atzebmw I have a question about the DSC coding, shouldn't C_Funktion_RDCi_l be aktive?
      11-03-2016, 01:22 PM   #39
atzebmw
That's a good question.
I just checked this and am confused.
At my old F30 with retrofitted RDC this value was "nicht_aktiv".
At my new F30 with RDC as standard has this value "aktiv".
But it also worked at both cars.
      11-03-2016, 01:57 PM   #40
THE_AVIATOR
Egypt
New F30 is LCI, or no?
      11-03-2016, 03:38 PM   #41
atzebmw
Yes
      11-03-2016, 05:00 PM   #42
THE_AVIATOR
Egypt
Yes
Makes more sense, since LCI has TPMS integrated in DSC
vhs043.00
      11-03-2016, 05:45 PM   #43
atzebmw
Yes, of course you are right.
But also the pre LCI since 03/2014 had TPMS integrated in DSC.
Since 03/2014 the TPMS is built-in as standard in germany.
Did you get it to work at your car?
      11-04-2016, 02:31 AM   #44
THE_AVIATOR
Egypt
Not yet, still researching a few things
