11-12-2019, 03:30 PM | #2553 | |
Gettin It Figured Out
1820
Rep 2,669
How many peddles do you see in the footwell? .
11-12-2019, 05:04 PM | #2554 |
Rep 1,286
What’s a “peddle”?
2024 BMW M4 Competition XDrive - Tanzanite Blue/Kyalami Orange - AST HAS - RaceChip
11-12-2019, 05:13 PM | #2555 |
1820
Rep 2,669
damn, my bad...should've verified spell check . 🍻 "Pedal" .
11-16-2019, 06:39 AM | #2556 |
Rep 11
Well, unfortunately, after driving the X3 F25 a full day I got the Crank Torque codes with the transmission flash even after the paddle fixes from Serge.
Would be nice to get this fixed PTF. |
11-17-2019, 04:59 PM | #2557 |
Rep 384
Hi,
Has anyone has any idea about this error? Get this error after driving on the highway on around 100mph, 3-4k rpm in sport mode already try to clear code, but no luck the car is now vibrating last week, i went to BMW, and upgrade the i-level to the newest version the checked the cyl 3 and 4, and replace with the new one, but said the problem still exist and the car still vibrating the decided to upgrade the i-level and said the problem is gone, but now i still get the same problem Thank you |
11-17-2019, 05:10 PM | #2558 | |
1820
Rep 2,669
1. Take it back to dealer, have them re-pull codes for same issues 2. When was the last time your plugs were changed? 3. Are you bm3 tuned? .
11-17-2019, 05:58 PM | #2559 | |
Rep 384
2. I never change my plugs, still factory plugs, running on 59k km right now 3. Yes, stage 2. I try to flash back to stock tune, but the error codes still the same. |
11-17-2019, 06:06 PM | #2560 | |
1820
Rep 2,669
I'd pull a few plugs and inspect. Chances are, they're done .
11-17-2019, 06:08 PM | #2561 |
Rep 384
11-17-2019, 06:12 PM | #2562 | |
1820
Rep 2,669
Damn....what engine? .
11-17-2019, 06:38 PM | #2563 |
Rep 384
11-19-2019, 04:00 AM | #2564 |
Rep 2,354
New spark plugs and a compression test is BEFORE new engine on the tjek-list!!!
(A Dane in China) |
11-19-2019, 05:03 PM | #2566 |
Rep 816
Drives: Bmw 335i f30 N55 ( sold)
Here we go again lol. Google it man. There's few comparisons, you'll always get more with custom tune from either. Just gotta check pro and con if each tune
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
11-21-2019, 02:40 PM | #2567 |
Rep 741
11-21-2019, 03:56 PM | #2568 |
Rep 407
Can anyone please take a look at my datalog? I am not happy with the performance.
Running Stage 2H 91 on N55 EWG. Thanks http://www.bootmod3.net/log?id=5dd7002bae729b42866354c1
11-21-2019, 08:35 PM | #2569 | |
Father of Frankenfold
299
Rep 531
Drives: Yo daddy's 2014 X3 M Sport
F25 X3 35i M Sport | Frankenfold 6662 | VRSF Race IC | FTP CP | BM3 tuned | XDI-35 HPFP | Stage 2 LPFP | Ethanol mixed | WMI | Oil cooler | xHP | X5/550i brakes
11-21-2019, 10:02 PM | #2570 | |
Rep 2,639
Go fill with Petro 94 and run the 93 OTS map.
11-21-2019, 10:05 PM | #2571 | |
Rep 2,639
11-22-2019, 12:22 AM | #2572 |
Rep 100
Just switched over to the Stage 2 91 ACN91 AGG map and did a 3rd gear pull.
Few things: -13.6 psi pre-boost throttle when target is 15psi -Timing looks funky -Wastegate is in the 90's Mods: VSRF catless downpipe, CP, G-plus IC, CTS intake, NGK spark plugs. Car was running rich on Stage 2 91 ACN91 map. I never had misfires so I'm not to sure what cause the car to run rich. I've had leaks before mainly from the CP to IC connection. My only assumption is that its leaking again. Anyone care to check out my log and give me some input? https://datazap.me/u/dmontes86/11211...log=0&data=6-8 |
11-22-2019, 01:30 AM | #2573 | |
Rep 7,591
Check out the Oring thread and boost leak thread for info on finding and fixing leaks, specifically with that connection. |
11-22-2019, 05:10 AM | #2574 |
Rep 407
I'm not in Montreal anymore. Back in Mauritius. We only get crap fuel here
