BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Using different tire sizes.
      07-17-2018, 06:52 PM   #1
bigraisinuts
Drives: 2019 Alpine White 440i Coupe
Hi guys. I'm driving a 2019 440i coupe M sport package. I have 19 inch rims and am running with 225/45 R19 tires on the front and 255/40 R19 tires on the back. Now the car actually calls for 225/40 R19 on the front and 255/35 R19 on the back. Could there be any side effects or damage by using the tires i'm using now? Besides extra noise, if that's a possibility? There seems to be no sign of rubbing or wear on anything. Thanks!
      07-17-2018, 07:07 PM   #2
Gr-Racing
Gr-Racing's Avatar
181
Drives: E46, F30 335i, 1986 K75
your alright with the tires you got is only a small diff in side wall height.
      07-17-2018, 07:37 PM   #3
bigraisinuts
Thank you for your reply. Would this small difference in side wall height be a cause for any extra noise? Or, if you know, can there be noise coming from the used run flats I am using?
      07-17-2018, 07:40 PM   #4
oonowindoo
Drives: 2018 340i
Ok so you have a 2019 and you got used runflats with wrong size? What i am missing here?
The noise you are hearing is probably from the runflat tires themselves. They are loud. There is a reason why everyone hates runflats.
Go get a nice set of summer tires in the correct size and the noise will go away and the car will feel MUCH MUCH better. The best mod you can do to your car is to ditch those runflats.
      07-17-2018, 08:06 PM   #5
bigraisinuts
Perhaps I should have given the whole story. The car came with 18 inch OEM BMW rims with brand new run flat tires on them. I wanted to upgrade to bigger rims, since they would look nicer, and bought the used 19 inch OEM BMW rims I am using now that came with the exact same size tires of the 18 inch rims that were originally on the vehicle (225/45 front and 255/40 back). It was after this upgrade that I started hearing noise. I started to research what size tires the 440i with 19 inch rims calls for and saw that the correct sizes are 225/40 for the front and 255/35 for the back instead of the 225/45 front and 255/40 back that I am currently using (Yes, I should have done my research beforehand, I am new to this). Since the tires are still decent (although used) I didn't want to buy new tires just yet, I wanted to use them up before buying new ones (Yes, I know it sounds cheap). That's what lead me to asking my original question. Are run flat tires really that noisy?
      07-17-2018, 08:42 PM   #6
Agent99
Covert
Agent99's Avatar
Drives: 2017 340i
Yes, runflats can be noisy but there are non-runflats that can be noisy, too. You've probably noticed that the surface condition of the road you are diving on can contribute as well.
2001 530i/5 (E39), Topaz Blue/Stone Green/Black (sold) *very rare interior/exterior color combo*
2005 545i/SMG (E60), ED Order, Titanium Grey/Grey (lease over)
2014 335i/Auto (F30), Mineral Grey/Black (lease over)
2017 340i/Auto (F30), ED Order, Estoril Blue 2/Black
      07-17-2018, 09:31 PM   #7
nissanite
nissanite's Avatar
22
Drives: 340i M-sport
2016 BMW 340i  [0.00]
I worked for Bridgestone as a High Performance marketing and education specialist for 11 years.
The only difference in a runflat tire is a banana shaped insert in the sidewall. Many people have jumped on the bandwagon. The original runflats were heavy and crude. Just like your iphone, this technology has improved over the years. Runflats play an important part in today's automotive technology.
the noise comes from the tread pattern and possibly irregular tread wear.
That said, the post was about an incorrect size. With today's cars including ABS and DSC the overall diameter is important. With a different ratio than OE front to back, the driver nannies may operate at different thresholds. With an additional 25ish mm in overall diameter the system may not work as the engineers designed. Example, the ABS may see the front brake lock early and release some brake pressure.
      07-17-2018, 09:37 PM   #8
Billfitz
Billfitz's Avatar
Drives: '15 328iX GT
My RFT are no louder than the Michelin MXM I had on my last car, and by no means does everyone hate them.
OP, the rear tire is maybe a half inch larger in diameter than the front. That won't cause any problem in and of itself. However, by going with a smaller aspect ratio in the 19s to compensate for the change from 18s the tire sidewalls are shorter, and that can result in more noise and a harsher ride. That's always a trade off to consider when you increase wheel size. Rubber absorbs both noise and road shock, aluminum doesn't.
      07-18-2018, 11:53 AM   #9
oonowindoo
Drives: 2018 340i
I dont know about MXM but if you are telling me that RFT are the same as summer tires, which i recommended. Then i guess one of us is imagining things.
I assume MXM is all season, i am not sure since i have not used all season tires for decades.
I have not met anyone who Loves runflat for their performance, quietness or durability.
      07-18-2018, 11:57 AM   #10
oonowindoo
Drives: 2018 340i
the incorrect size will not cause noise. the car might or might not feel weird but they dont cause noise.
Do you know how many miles did the used tires have?
There is 1 way to know for sure, put your stock 18s back on and see if there is any noise and you will know if it is the used tires.
If you wanna use them up, that is fine. Just have to live with the noise until they are worn. I assume there is no vibration, just noisy?
      07-18-2018, 01:34 PM   #11
bigraisinuts
Unfortunately no, i'm not sure how many miles are on the used tired but they have like 60% of tread life left. And I don't have the 18s anymore so I can't experiment. No vibrations at all, just noise. They are Continental Conti Sport Contact tires and they were on a 2015 335i GT. Could the noise just be from the tires being unevenly worn?
      07-18-2018, 01:44 PM   #12
oonowindoo
Drives: 2018 340i
Yes unevenly worn tires will cause weird noises, especially at higher speed or when you start accelerating from dead stop.
I am not sure what kind of "noise" you are hearing, but if it is just noisy in general, then it is probably "normal" but if it is the "weird noise" only at certain speed, then it could be other things like balancing.
But you can inspect the worn pattern. If it is obvious enough for your eyes to see, then it is most likely the reason.
But based on my personal experience with Runflats, they are louder than summer tires, especially when they are somewhat worn.
      07-18-2018, 01:45 PM   #13
chiefneil
Drives: 2014 335i M-Sport
Iíd just use up the tires and switch to the correct size once theyíre done. Itís hard to comment on the noise since itís so subjective, but in general unless thereís something mechanically wrong at the wheel level (e.g. bad bearings) then tire noise can/should be ignored.
With the slightly taller height your speedo will read a touch high. BMW speedos already read 2-3 mph high anyway, though.
      07-18-2018, 02:15 PM   #14
Billfitz
Billfitz's Avatar
The OP made no mention of summer tires, so neither did I. BTW, RFT are available as summer, A/S and winters. My RFT are A/S, so were the Michelins I had on my last car, so I made an apples to apples comparison. Not having tried RFT versus non-RFT summers I can't make any comparison there.
      07-18-2018, 05:23 PM   #15
oonowindoo
Drives: 2018 340i
OP's RFT are staggered, that means they are performance summer RFT (not A/S or Winter)... so Summer tires are the direct apple to apple comparison.
440i, coupe, size, tire
