BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > Heated Steering Wheel Retrofit
proTUNING Freaks
      08-18-2018, 05:00 AM   #23
teaston
Drives: X3 M40d
It does need the Kafas camera which your car will only have if if it has speed limit display or forward collision mitigation.
Hugrov423.00
      08-18-2018, 06:37 AM   #24
Witney
Drives: Tesla Model-Y LR
Originally Posted by Hugrov View Post
Just try having a look on YouTube and you should find a video of how to do it. it's hard to explain but basically you disconnect the battery first (so the car doesn't throw up an error when the airbag is disconnected). You then use a flat blade screwdriver, put it through the holes on the steering wheel at the 4 & 8 o'clock positions to depress a sprung latch that releases the airbag on each side and lift it off. You'll need to disconnect 1x connector to remove it completely.
Link to youtube for airbag removal and sprung latches with some cheesy music:
It would be helpful to me if anyone has any images of the wires for heating so I know what I am looking for as I may also have a look to see what may be hiding!
Hugrov423.00
      08-18-2018, 06:44 AM   #25
Danny Fireblade
Village idiot
England
750
Drives: Myself crazy
How easy is it to code LDW? I have BimmerCode, can I use that?
Also how would I turn it on and off as have HSW and radar cruise etc.
Thanks
      08-18-2018, 08:52 AM   #26
MarkG_M5Comp
Supreme Being
MarkG_M5Comp's Avatar
Drives: M5 Comp
Originally Posted by teaston View Post
Nice! I did the opposite, I have the heated steering wheel and when I took the trim off I realised the LDW vibrator was already there so I coded LDW!
This is interesting... my car has the heated wheel but no LDWS or vibration module. I need to do some research to see how easy retrofit would be. Although that said, it's annoyed me a bit on the X5
EDIT:
Reading RealOEM I would need to buy the vibration unit but the wiring is supposedly all the same. How can this be when I didn't notice any spare connectors on the loom I have? How does the vibration unit connect??
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring
      08-18-2018, 09:21 AM   #27
Hugrov
Drives: F36 LCI
You're looking for the wiring down at the bottom right, the item on the left is the vibration generator.
Edit: photo has uploaded on its side but you get the idea
Witney205.50
      08-18-2018, 09:30 AM   #28
Hugrov
Drives: F36 LCI
EDIT:
The vibration unit/motor connector is the little white one and that then runs to the black module with the label on it. That module is then connected to the steering wheel slip ring.
      08-18-2018, 09:31 AM   #29
mcoops
Drives: Short term lease
Thanks
+ 1
I have the heated steering wheel and speed limit display, so would love to know if this can be done in Bimmercode.
      08-18-2018, 10:11 AM   #30
DougMcL
Drives: BMW i4 40e, Honda Jazz Hybrid
Sure Bimmercode can't do VO coding... both of these are VO aren't they?
      08-20-2018, 12:41 PM   #31
Alexandru.k_24
Romania
Drives: BMW 320d 163HP
Hello dear friend. Can you please post here the OE code for the heating and for the plastic column cover?
      08-20-2018, 02:10 PM   #32
onstat
Wales
90
Drives: 335d Touring
Looks like Ill have to download bimmercode as Ive got active cruise and heated wheel
F31 335d M Sport | Estoril Blue & CR | M Sport+ | Pro Nav | Comfort Pack | Adaptive M Sport suspension | Active Cruise
      08-20-2018, 02:12 PM   #33
teaston
Drives: X3 M40d
I don’t think you have a Kafas camera for active cruise, it uses the radar in the bumper.
      08-20-2018, 02:38 PM   #34
onstat
Wales
90
I don't think you have a Kafas camera for active cruise, it uses the radar in the bumper.
Ah yes. I thought it had kafas with it having the active crash protection too
      08-22-2018, 03:11 PM   #35
TiredGeek
Old Fart
TiredGeek's Avatar
Drives: 335dx F31 Shadow EB
Well I have heated wheel, LDW and crash protection.
Can I code speed limit info?
Am I reading here that maybe I have the camera that it uses.....
The doctors said it's OK to listen to the voices..... just don't do what they tell me
      08-24-2018, 06:49 PM   #36
Quantox
Drives: 440iGC, CQ, Ivory White, MPPSK
Also interested to know if TSR and anything else (?) can be coded to a car with LDW. I'd get it coded at the same time as the HSW coding was done.
Need to check the wheel for the HSW components first though.
Cheers
Q
2018 440i Gran Coupe, MPPSK, Champagne Quartz, Ivory White, Adaptive Susp., Sunroof, Active Security, CA and a few other bits.
      08-25-2018, 03:48 AM   #37
teaston
Drives: X3 M40d
No, SLI requires an FSC enabling code which is a lot of money, or you can buy an emulator which is around $200
TiredGeek360.50
      08-25-2018, 01:51 PM   #38
TiredGeek
Old Fart
TiredGeek's Avatar
Nah, wasn't that fussed TBH, but if it's something for nothing, well.....
      09-29-2018, 06:57 AM   #39
jaydaman93
Drives: 2016 bmw 328i xdrive
Hey guys, i replaced my steering wheel with only vibration and paddles to one with heated steering, paddles and vibro. I vo coded option 248 to fem_body and kombi to make the hsw work. But now my vibration motor doesnt work. Any suggestion? Please help.
      11-03-2018, 11:28 AM   #40
N44RTT
Drives: G21 M340i
So getting inspired by this thread I opened up my steering wheel today to see if I had the right things in place to retrofit the heating function.
Not too sure what to look for? I am clearly missing the vibrator unit (as described in the pics on the post above) but not interested in LDW.
'22 G21 M340i xDrive (MHT) in DG
Gone:
'18 LCI F32 440i M Sport Plus in EBII
'15 LCI F30 330d M Sport Plus in EBII
      11-03-2018, 11:51 AM   #41
Kendo67
Kendo67's Avatar
Scotland
1099
Drives: Me - 440i , Dog - Cayenne
Looks like you are missing the heating element wiring , if you look at the pic in post 27 you can see the LDW motor on the lower part on of the pic and heating element brown + black wiring on the upper.
So it looks like you dont have the required parts (element) to make it work , on the plus side gloves are only £1.99 a pair in Morrisons garage at the moment so it is not all bad news.
Kenny
N44RTT77.50
      11-03-2018, 12:31 PM   #42
N44RTT
Drives: G21 M340i
Originally Posted by Kendo67 View Post
...on the plus side gloves are only £1.99 a pair in Morrisons garage at the moment so it is not all bad news.
Haha...very funny It was never about the actual heated wheel, it was more about being able to say I've retrofitted something on my car. It would've been a simple one...guess I'll have to find something else.
Anyway...thanks for clarifying!
Gone:
      12-25-2018, 01:41 AM   #43
MilliM3chica
Drives: Bmw M3/335
Steering
Hey guys i am new to this forum but i have owned a 2009 335 xdrive and i love it. but ive always wanted an M3 so i got one. I like mostly everything about it except the steering i love the heavy steering in my 335 and how it goes where i want it to go but the 2011 updated LCI M3 is lacking it almost seems like there is a gap in the steering when taking a hard left or right anyone feel the same or is it just a difference bc i have been driving a hydraulic steering rack vs. electric?
      12-25-2018, 04:50 PM   #44
SkyJawa
SkyJawa's Avatar
3719
Drives: F10 530d
Wrong forum, this is F series not E series....
