BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > Regional Forums > UK > M4 brakes on my F33 (420d SE from 2015) adapters needed?
Studio RSR
      09-27-2019, 02:59 PM   #23
dizzy619
Drives: F31 340i
How impressive do your brakes need to be? Are you doing some serious track work? If not its not worth it just get the blue 370/345 combo with decent pads
      09-27-2019, 05:45 PM   #24
Busted
England
91
Drives: F31 335d
Tbh i thought this. Those wheels dont show them off and there's no way a 420d would ever need them......
      09-28-2019, 04:00 AM   #25
TopperXP
TopperXP's Avatar
Drives: BMW F30 320i m sport / BMW F40
What sizes would be required to upgrade an F30 320i with standard brakes to the blue caliper option , i have 19" 403M wheels , thankyou
      09-28-2019, 10:17 AM   #26
dizzy619
Drives: F31 340i
https://rover.ebay.com/rover/0/0/0?m...2F163822644467
Anything like these..
      09-28-2019, 12:51 PM   #27
R99
Drives: 2016 330d F31 Touring
A 20i would have 340mm fronts if equipped with the M Sport brakes from factory.
I have a set of 340mm calipers available for £329 delivered if interested
      09-28-2019, 01:50 PM   #28
IK6SPEED
Drives: BMW M3 / AH3
The master brake cylinder in the F82 is stronger than in the F3x.
      09-28-2019, 01:56 PM   #29
R99
Only if the car didn't come with M Sport brakes from factory...
Otherwise the part numbers are identical.
      09-28-2019, 02:37 PM   #30
IK6SPEED
Might want to double check that. I speak from experience
https://www.realoem.com/bmw/enUS/sho...diagId=34_1966
      09-28-2019, 02:50 PM   #31
R99
No need to double check it.
The part number you have posted is for cars WITHOUT option S2NHA (M Sport braking system)
F3x cars optioned with WITH S2NHA get part number 34337849878 (that is the LHD part no) which is the same as the ///M master.
      09-28-2019, 02:53 PM   #32
IK6SPEED
So arrogant you will not even check the link.
And since when are UK BMW's LHD :LOL:
      09-28-2019, 03:02 PM   #33
R99
I posted LHD part number as reference for you, as I could see you were in the USA.
No arrogance on my end. Simply referring to my experience when looking into the masters for my own project which involved retrofitting F10 M5 calipers to my car.
See below - F31 - 330d optioned with M Sport brakes:
https://bimmercat.com/bmw/en/search/...0d/ECE/34_1966
Part number for the master is the same as ///M cars.
      09-28-2019, 03:03 PM   #34
teaston
Drives: X3 M40d
But your link is for the 420i, the OP's car is a 420d, smartass!
      09-28-2019, 03:03 PM   #35
IK6SPEED
No difference!
*sigh*
      09-28-2019, 03:05 PM   #36
teaston
Drives: X3 M40d
No difference!
Look again!
      09-28-2019, 03:06 PM   #37
R99
That link literally shows part number: 34337849879
Which is the same as the ///M master
      09-28-2019, 03:36 PM   #38
IK6SPEED
And where does the OP state he has M Sport Brakes on his 2015 F33 420d?
The OP pic doesn’t show that.
The OP states it came with 17” wheels.
Why is he trying to change a F33 Blue Caliper for a F82 Blue Caliper?
The fact still remains that the Master Brake Cylinder in the OP’s car will not sufficiently power the F82 Brakes, which is what I originally stated.
      09-29-2019, 02:15 AM   #39
R99
I never said that the OP had M Sport brakes?
It was you that stated:
"The master brake cylinder in the F82 is stronger than in the F3x."
This is not true, as evidenced by the links on the thread, where many cars optioned with M Sport brakes from factory share the same master.
However, it would seem (from looking further since this discussion) that some of the lower powered petrol models do indeed not have the ///M master even when optioned with the ///M brakes. However, this is further proof that the M brakes are compatible with either master!!
I also assume you are aware that BMW sell the M Performance brakes for the F3x range? These are the 370/380 4 pots and 345 2 pots, identical to the ///M calipers.
This retrofit kit does not include a master cylinder upgrade from BMW....
      09-29-2019, 02:26 AM   #40
IK6SPEED
The OP pic doesn't show that.
The OP states it came with 17" wheels.
The fact still remains that the Master Brake Cylinder in the OP's car will not sufficiently power the F82 Brakes, which is what I originally stated.
The subject of thread was an OP asking a question.
I gave the correct information for his retrofit he needed to know, no matter how you try to justify your response.
I did not have MSport Brakes on my 2013 and upon retrofit, the brakes have severe fade as the Master Cylinder does not have the power needed. This was corrected by retrofitting the Master Brake Cylinder and Brake Servo Unit from a F8x vehicle.
Real first hand experience.
      09-29-2019, 04:05 AM   #41
dizzy619
Drives: F31 340i
Maybe you just had a duff master cylinder.. I run the 370/380mm calipers on my 2007 1 Series coupe track car it definitely doesn't have an f80 master cylinder.. Works great... 1st hand experience....
      09-29-2019, 04:14 AM   #42
teaston
Drives: X3 M40d
That is a smaller lighter car though, wonder if that's reason that 320i's with M Sport brakes doesn't get the F80 master cylinder.
      09-29-2019, 07:43 AM   #43
Wills2
Barge driver
Wills2's Avatar
Ukraine
8656
Drives: 730d
Don't BMW do an M performance upgrade for the normal 3 series with slotted disks and red calipers, I'd just get that rather than faffing around trying to make things fit that aren't meant to.
730d/Z4C
      09-29-2019, 08:49 AM   #44
R99
They do - and you can also choose orange or yellow.
Surprisingly..... it doesn’t include a master cylinder upgrade....
Wills28656.00
420d, brembo, f33
