11-15-2019, 08:43 AM | #1 |
Rep 819
Drives: Bmw 335i f30 N55 ( sold)
Replace your stock charge pipe
For anyone who is new with a bmw or wants to upgrade and hasn't. Just do it. My 335i has a down pipe and Intake and I planned to do more just haven't gotten a round to it. During regular driving yesterday I had just downshifted so I could go around a car and as soon as I hit the gas, POP. Charge pipe blew off. Lasted until 78k miles on my car. So if you have a stock one and debate this, just get a new one. Just an FYI for anyone unfamiliar with this stuff
2012 bmw 335i sedan
VRSF catless DP VRSF 5? HD IC Stock intake(had open before and was sick of noise) BMS CP 550i 351m rims with 275/245 set up. No tune as of yet. |
11-15-2019, 01:51 PM | #2 |
Rep 351
I just blew mine apart 2 weeks ago. Went to change lanes, hit the gas in 6th, and POW it blew. 86k miles and totally stock. Taking a closer look at it, I think it had been cracked for a while and I was leaking boost. Ordered a VRSF cp and 5" intercooler from mike at x-ph. The car is much much happier, healthier, and pulls nice and hard. Tune is next now that the CP is replaced.
2013 335i M-Sport 6MT, MPE, VRSF CP and IC, BM3 Stage 1
2006 330i 6MT, Sport Package - sold |
Tpriest7893215.00 |
11-15-2019, 05:06 PM | #3 | |
Rep 741
Tpriest7893215.00 |
11-15-2019, 05:14 PM | #4 | |
Rep 7,598
11-15-2019, 06:55 PM | #5 |
Rep 417
I changed mine at 24K miles so I can have a happy and heavy foot.
Tpriest7893215.00 |
11-15-2019, 07:06 PM | #6 | |
Rep 819
2012 bmw 335i sedan
torkles198.00 |
11-16-2019, 04:56 AM | #7 |
Rep 73
Can always look forward to it failing with any spirited driving after 60k. Bought my car from the dealer and mine went the next day. Took it back for them to replace it while I ordered VRSF cp and intercooler
11-16-2019, 06:35 AM | #8 | ||
Rep 3,947
torkles198.00 |
11-16-2019, 03:50 PM | #10 |
Rep 819
Did bmw continue to use plastic pipes for the newer models cars?
2012 bmw 335i sedan
11-16-2019, 10:15 PM | #11 |
Rep 1,934
The boost tract is not the same anymore since there is no intercooler. Water to air on the B58.
11-17-2019, 09:01 AM | #12 |
Rep 351
Do you want to elaborate on that? Obviously I ordered it in the last 2 weeks.
11-17-2019, 09:03 AM | #13 |
Rep 351
New thing at a time. but yes a catted VRSF downpipe is on the list. I live in a place where emissions inspections are required so I have to be careful of that.
11-17-2019, 11:45 AM | #14 | |
Rep 7,598
https://f30.bimmerpost.com/forums/sh....php?t=1659611 I wrote up in this thread how you can boost leak test: https://f30.bimmerpost.com/forums/sh....php?t=1621695 You can also typically see in your datalogs if you have a boost leak, especially if it is as substantial as mine was. As of right now the VRSF catted DP will not pass emissions. They are apparently developing a new one that fixes the O2 wire length issue and MIGHT pass, but no response from VRSF on that recently. If you order the catted one right now you will get the 90 degree O2 extension for the secondary O2 sensor. |
11-17-2019, 02:40 PM | #15 | ||
Rep 351
I had mine installed at a reputable shop here who noted their sensitivity to boost leaks and had done these installs many times before, so I'm sure they would have mentioned if there was a fitment issue. Based on how the car pulls I don't think I'm having an issue. One thing on the data logging, I'm not sure I've seen a log yet where boost actuals matched the target, but I'm also no expert on the topic. You were obviously having an issue leaking from that connection but did you ever solve the issue and get actuals/target to match or can someone chime in here on how that should work? Quote:
11-17-2019, 03:46 PM | #16 | ||
Rep 7,598
As far as boost target goes, the general rule of thumb is +/-1 psi from target is normal. The other main consideration is WGDC. If you are reaching target but WGDC is excessively high, that could also suggest a leak. In general what i have found and seen is that you probably will not reach targets in 1st gear (with 8AT at least) because there isnt enough time or load. By 2nd you should be close, and by 3rd and higher you should be basically right on target. Here are some of my most recent logs. MHD stage 1, VRSF 5'' IC + VRSF CP (after all leaks fixed): 1-4:https://datazap.me/u/thejeremyman9/1...=0&data=5-6-25 4-5: https://datazap.me/u/thejeremyman9/4...=0&data=5-6-25 Basically just look at boost target and boost mani. The difference with the leak was most noticable in 1-3. With the leak the car felt laggy in the low gears. With it fixed i can easily spin 1st even from a slow roll (Stage 1 tune with stock cat and just a drop in filter). Quote:
I have been doing a lot of research on catted DPs recently with the intention of buying one with upcoming sales. I don't have to do emissions until 2023 so i really just want one that eliminates the smell (i already have a catless car and dont want it for my DD). The price of VRSF is tempting, but i probably dont want to buy any more of their products. I may just end up getting CG Precision or fabspeed. I dont want to run into a situation like with my IC+CP where i have to remove and reinstall; might as well just spend the extra money and do it right the first time. |
11-17-2019, 04:44 PM | #17 | |
Rep 351
Post 14 - VRSF says 'cel free operation for the majority of members who stay under 450whp'. I know that's not a guarantee but sounds pretty good, and 450whp is a lot more than I'll ever get to. Regardless, there's apparently an updated version on the way. But if no CEL shows up, what would prevent the car from going to ready status? You have me curious about my boost target vs. actuals. I think I can log that in carly, so I'll take a look on the drive home from work tomorrow. It'd be nice to confirm I don't have an issue. I assume you're running the stage 1 OTS map from mhd? How do you like that? I'm torn between bm3 and mhd - mhd is appealing, I'v heard great things about their pwg maps and they are cheaper than the bm3 option.
11-17-2019, 05:03 PM | #18 | |
Rep 7,598
I would definitely log. You really just need boost target, boost in the manifold, and WGDC for this check. Make sure you are looking at boost in the manifold and not boost pre-throttle. Yes, OTS stage 1 from MHD. Its a solid tune. Pretty significant gains over stock. I could technically go stage 2 with the IC+CP, but decided to just do stage 1 and then go to 2+ after a downpipe for another big jump. Absolutely no issues with driveability, flashing, etc. The car drives and behaves exactly like stock but faster; only positive feedback from me on the tune. The monitoring and logging module with MHD is also great (ive done at least 25-30 logs while chasing boost leak issues and spent hours scrutinzing them). |
11-18-2019, 11:15 AM | #19 | |
Rep 190,750
Tpriest7893215.00 |
11-18-2019, 01:37 PM | #20 |
Rep 205
Couldn't agree more. As soon as I flashed my stock car to BM3 Stage 0+ (thought it couldn't hurt...), stock CP blew off on the very first pull
Like others have mentioned, I'm pretty sure it was leaking boost for awhile - it had multiple cracks when I pulled it out. Went w/ a CTS Turbo CP and couldn't be happier. Installation was a bit of a sore but well worth it. |
11-18-2019, 02:06 PM | #21 | |
Rep 819
2012 bmw 335i sedan
11-19-2019, 09:18 AM | #22 | |||
Rep 351
Engine speed (1/min) Boost pressure setpoint (psi) Manifold Absolute Pressure (psi) 1245.5 14.614252 13.866968 3764.5 20.973818 21.041237 5428.5 21.46332 20.805552 Quote:
