10-29-2018, 08:44 AM | #24 | |
Rep 92
"Specifically designed for use with an impact driver in high torque applications." But then say "Socket adaptors not suitable for impact drivers or drills with a torque rating higher than 80Nm." My Impact driver is rated at >250Nm |
10-29-2018, 08:46 AM | #25 |
Rep 725
10-29-2018, 09:44 AM | #26 | ||
Rep 90
Do not buy what is pictured which is indeed an impact driver. That is basically a powered screwdriver used by mainly joiners, diy enthusiasts etc. What your after is an impact wrench. These come in various flavours depending on the torque required. You'd have to check the figures as you might get away with a 3/8" drive gun but most would use a half inch drive for use on wheel bolts. Again best practice is to use a breaker bar like the one pictured to crack the bolts first as a powerful gun could easily round the bolts if the socket slipped. Never use a gun on the security bolt as easily damaged. |
10-29-2018, 04:46 PM | #29 | |
Rep 15,858
As we are only spinning bolts 'off and on' with a power tool, a decent battery screwdriver/drill will do that job very well, with a 1/4" hex' to 1/2" socket adapter bought for a couple of quid. I use a breaker bar and sleeved socket to loosen, a Dewalt screwdriver to do the tedious bits, torque wrench to finish the tightening. |
kiwifiz10.50 |
10-29-2018, 04:55 PM | #31 |
Rep 2,444
Drives: 2018 630iGT sport
Can't seriously believe people are considering buying a powered hand tool to save 10 secs tops per bolt, to spin it out by hand (well, using the socket and maybe an extension if you find it easier to grip).
I'd much rather do it by hand, you have much better control of the bolt on its way out and less chance of damaging the wheel.... Which I thought was the concern in the first place? |
Alice Coupe156.50 |
10-29-2018, 04:55 PM | #32 | |
Rep 1,894
10-29-2018, 05:00 PM | #33 | |
Rep 2,444
I do hear what you are saying about the angle and socket slipping (to prevent that, you simply have one hand at the pivot point whilst the other is at the handle end) , but ironically, the only time you're likely to fuck bolts up when manually undoing them with any kind of bar and socket, especially the security ones, is when they've been utterly overtightened with a rattle gun / impact wrench. This is because they've been done so tight, you have to have both hands yanking on the end of the bar (or worse still, jump on the end of the bar!) in a desperate attempt to undo the bloody thing. So without any support by the wheel bolt end to keep the socket square on and fully sat home on the bolt head, yes, the socket is likely to come off and damage the nut or wheel. Last edited by Russbmw; 10-29-2018 at 05:08 PM.. |
10-29-2018, 05:09 PM | #34 | |
Rep 15,858
Limit any greasing to the hub location spigot, which is fine, (that stops the seizing), but do not grease the wheel or hub clamping faces. |
10-29-2018, 05:15 PM | #35 |
Rep 2,444
Absolutely, and if the wheel was that hard to get off, clean the mating spigot face/circumference with a wire brush first.
10-29-2018, 05:19 PM | #36 |
Rep 1,894
I ended up just replacing the alloys with regular bolts....touch wood they are still on the car. I did buy a replacement set of security bolts with the older patterns, rather than the newer wobbly looking ones.
I spoken to my local dealer, they said the 14x1.25 bolt will fit the G3x cars, so I'll save them for that. |
10-29-2018, 05:20 PM | #37 |
Rep 15,858
I'll add another tip. It is best practice to go around the car and loosen all security bolts before you even attempt to jack/change any wheels. Ensure all security bolts can be eased off. You then know you are set to go...
A 450mm breaker bar with one hand at the socket, one hand gently pushing down, (at 9 o'clock), should easily loosen a security bolt if not over tightened. 140Nm is not a high load. |
10-29-2018, 05:20 PM | #38 | |
Rep 487
I can't believe for a minute, as a chap, you are dismissing the purchase of a power tool??? |
Tengocity8566.00 |
10-29-2018, 06:42 PM | #39 | ||
Rep 19,982
10-29-2018, 06:51 PM | #40 |
Rep 19,982
I totally get why folk would want to do it by hand, but really I can't be arsed. I've taken my wheels off and on umpteen times for winter, swapping to my track day tyres, playing around with spacers etc. I'm careful, and have a set routine which I stick with, so it's security bolts off first by hand, then setting 3 on my de Walt for removal. Takes a few seconds.
Then I'll do each bolt up slowly on setting 1, then finish off by hand, and then use the torque wrench. However, the best tool I have is a professional quality SGS low profile jack. So smooth, quick and powerful, and utterly rock solid. It's big and hefty so you need a bit of space and garage to roll it in and out of, but well worth it.
t5pilot977.50 |
10-29-2018, 06:55 PM | #41 | |||
Supreme Being
1804
Rep 5,425
I also removed the wheels more than a few times a year to keep the spacers moving - learned that lesson from leaving them on the 335 for 2 years! Zippee - have those tools ever been used though?
Current: F90 M5 Competition
Gone: F80 M3 Competition Pack / M135i / F15 X5 M50d / Saab 9-5 Aero HOT / F30 335d xDrive M Sport / E92 LCI 320d M Sport / E46 320d M Sport Touring / E46 318i Touring |
kwak2433.50 |
10-29-2018, 08:08 PM | #42 |
Rep 487
Yes exactly. Had to pull my front two wheels off the 435D yesterday to remove LED fogs back to standard (pick up the M4 on Monday!). Quick break with the 17inch bar, whizz, rattle and off in seconds and in complete safety with the plastic 17mm. Back on again, hand fed then whizz, rattle and torqued to 140nm. Tie that with a nice little Makita power driver to remove the 9 or so 8mm retainers on each of the forward wheel liners and the job was simple as opposed to a bit tiresome (dull) doing it all manually. Plus its power tools
2JPW55.50 |
10-29-2018, 08:19 PM | #43 |
Rep 487
Yes! Although I'll be honest, I corralled all my tools recently as they were spread across four winds and decided to splash out on a couple of new chests and complete my kit. 3x Torque wrenches (1/4, 3/8 and 1/2 covering everything up to 200Nm). My original Britool torque last saw action against a set of Alfa 33 Sportwagon wheels back in the mid 90s so its now retired. Furnished with a full set of Teng 1/2inch sockets to go with some Halfords Advanced 1/4 and 3/8, ratchets from 1/4, 3/8 and 1/2 and a lovely set of De Walt screw drivers (as well as the great Makita bit set as recommended by Watsey ). All in time to receive the M4. Couldn't possibly expose that to some of my old 'Bodge it & Scarper' tools plus Im not sure there are many Whitworth or AF fixings on BMWs?
10-29-2018, 08:26 PM | #44 |
Rep 49
My t bar didn't survive the seriously overtightened fronts after performing gallantly on the rears:
Had to resort to the torque wrench which I didn't want to do but whacked it up to 192Nm beforehand so shouldnt cause too much problems. Maybe I shouldn't buy cheap Chinese stuff from Amazon 🤣 Last edited by meatballs; 10-29-2018 at 08:31 PM.. |
