BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > 5AC HBA Activation on KAFAS2
      04-29-2019, 06:17 AM   #1
erickarlborg
Sweden
Drives: E91 320d -08
Post 5AC HBA Activation on KAFAS2
Hi,
Could anyone perhaps provide the required FDL codes for activating HBA on a F20? I have only found info about this for the F10 with FRM. I want to avoid VO Coding because of the loss of other codings already made
The car is equipped with Kafas2 and FLE lights.
I guess it would be something in FEM_BODY, KOMBI & KAFAS2?
Any help is appreciated, thanks!
      05-09-2019, 01:17 AM   #2
erickarlborg
Sweden
Originally Posted by erickarlborg View Post
Hi,
Anyone, please? Sensible_ maybe?
      05-09-2019, 01:37 AM   #3
Sean750
Sean750's Avatar
Netherlands
22
Drives: 420iA High Exec M Sport Editon
Have you also the HBA switch at the cluster steering column? Because without that, you can't make it get to work (as far as I know).
Previous bimmers: E30 318, E34 524TD, couple of E32 750i, E38 750i
      05-09-2019, 07:47 AM   #4
erickarlborg
Sweden
No it has not, but as I understand you can set it to "automatisch" and it will work.
The only thing is it won't work when you start the car in Auto mode when it's already dark, then you will have to flip the switch back and forth for it to enable
Do you know the parameters to change?
      05-10-2019, 12:28 PM   #5
Sean750
Sean750's Avatar
Netherlands
22
Again, as far as I know, you need the stalk with the hba switch in order to make it work on a f3x. Maybe read this:
https://www.bimmerfest.com/forums/sh...644297?page=11
      05-14-2019, 01:24 AM   #6
erickarlborg
Sweden
Yes that is the thread I've read regarding FRM. But I can't find those values in FEM_BODY...
      04-20-2021, 12:44 AM   #7
chrbmw
Drives: BMW F31 and BMW Z3 M Coupe
Did you get it to work?
I am also looking for info about coding the HBA on my F31 with FEM module.
5ac, f20, hba, high beam assist, kafas
