07-26-2023, 03:19 PM | #111 |
Rep 8,636
Yeah I have VO coded all the modules in the guide, was just checking FDL settings in Bimmercode. However I still have RDC error/failure, I’m leaning to the thought that there are other modules in the F10 which need VO coding too….
I’ve seen mention of just needing to unplug the tpms module once the VO coding is done, so might try that first…. Last edited by SkyJawa; 07-26-2023 at 03:25 PM.. |
07-27-2023, 10:44 AM | #112 |
Rep 8,636
So to put this to sleep I rechecked all the FDL coding via BC and the VO coding had changed everything required, but on the F10 you do indeed need to pull out the RDC module fuse, no 139 in the boot/trunk.
With that removed, no errors on start up and iDrive now showing Flat Tyre Monitor instead of RDC. Result |
08-03-2023, 10:07 AM | #113 |
Rep 1,201
Yes, I did a 6 series a few years back and the only way that would work was pulling the fuse.
Current - 2021 G20 330i M Sport+
Gone - 2017 F30 335d M Sport + in San Marino Blue Gone - 2015 F30 LCI 320d M Sport+ Step Auto Gone - 2012 F30 320 ED Gone - 2011 E87 118d |
