03-02-2017, 09:31 AM | #1 |
Rep 14
MY17 HKFM2 F36 Tailgate Closing via cabin button coding
Just a quick note for anyone with the newer builds that have changed some of the ECU names and CAFD files;
I have a new 4-GC (F36) UK spec, whereby the tailgate button only opens, not closes it. Mine was pre-enabled to close via the keyfob, but wanted the button to work too. Looking around the forums, I could only find details for SCH_FBD on HKFM 3010. The newer cars have HKFM2 (mine had a [d] extension to the end also), and was the only one not allowing me to read the coding data. Given I have the latest e-sys and pszdata, I needed to find another way. Thanks to previous posts by Shawnsheridan and roxxor I was able to create a working cafd file, find the entry that would work and successfully change it, so I thought I would do a step-by-step for anyone interested. 1. Connect to your (running) car with your ODB cable and load up E-Sys 2. Read the FA and SVT 3. Navigate down the list of modules until you find the HKFM2 entry, as I said, mine was actually called HKFM2_[d] 4. Check to see if you can read the coding data in the normal way - you might be lucky, however I kept getting C012 errors (CAFD not found) - if this is the case follow the next steps 5-13 too. If it works straight away for you, skip to step 14. --- 5. Under 'Expert' mode, choose the VCM screen. 6. Click 'VCM Master' tab on the bottom section of the screen. 7. In the I-Steps section, select 'Read'. Provided you have not altered the I-Step for previous coding the values produced will be the same as each other. For example mine was F020-16-07-503. Make a note of this number as you will need it in a minute. 8. Under 'Expert' mode, now choose the Coding screen. 9. Click 'Read (ECU)' on the right. 10. Highlight the HKFM2 module and choose 'Detect CAF for SWE' - also over to the right of the screen. 11. A pop-up window will launch with a number of CAFD options - choose the one that MATCHES your I-Step version from above and click OK (the name of the new CAFD might be slightly different from the existing one that wasn't allowing you to read it). 12. You will now have a new CAFD entry with a green dot beside it. 13. I found that I needed to disconnect and close e-sys, then relaunch and re-read SVT before I could read the coding data from the new CAFD - but doing this worked fine. --- 14. When you open up the coding data you will notice that there are tonnes of options, a lot relating to button timings. I just wanted a simple close on single press of the interior button, so only needed to make one change: 3008 USER_LOG_HKL_ROCKERSWITCHPOS1, 06 -> HKL_ROCKERSWITCHPOS1_BUTTON_TYPE Right click on Werte=02 (second entry under "Ausgelesen") Choose edit and in the entry box at the bottom of the screen change "02" to "05", then click on the little page with the yellow arrow to the very right of the editing box. 15. Click the 'Save' icon in E-sys. 16. If you try to edit the first entry (wert02) there are no options to choose from, and if you do this after editing the Werte=02 to Werte=05 entry as described, the change will revert back to 02! 17. Go back to your modules, click the altered CAFD file and write it to your car. My alteration worked immediately, so you can test it right away. I have included a screenshot below of the single change needed for this option. Like I said, there are loads of options around timings etc. in this section, but doing it this way makes it an instant response to pressing the button. Hope this is helpful to some! Cheers, Andrew. |
03-02-2017, 10:22 AM | #2 |
Rep 3,540
Awesome thanks! I was looking for this function but didn't try the rocker switch since the other option names (CA and keyfob) names were quite clear/obvious while this one wasn't.
irishandrew11.00 |
06-09-2017, 11:02 AM | #3 |
Rep 1,799
This definitely works to enable the boot button above the OBD port to close the boot as well as open it on an F31 with iDrive5. I have coded mine and it works.
This is in the HKFM2 CAFD module 3008 USER_LOG_HKL_ROCKERSWITCHPOS1, 06 -> HKL_ROCKERSWITCHPOS1_BUTTON_TYPE Right click on Werte=02 (second entry under "Ausgelesen") Choose edit and in the entry box at the bottom of the screen change "02" to "05" Also to enable the key fob button to open & close the boot on an F31 with 1 press rather than keeping the button depressed to close the boot you need to code this 300B ...REMOTECONTROLLIFTGATEBUTTON...section... I went to ...REMOTECONTROLLIFTGATEBUTTON_LONGPRESS_CLOSE.. I changed the Werte value from '01' to '00' This is logical as the ...._LONGPRESS_OPEN Werte value = '00' as the boot opens with 1 press of the key fob button. Both tested & work perfectly
U06 230e Active Tourer |
Previous : 2019 F31 340i : 2017 F31 335D M-Sport |
Speed-NYC138.00 |
07-09-2017, 06:41 PM | #4 |
Rep 1
Hi all. I'm fairly new at the coding community. I cannot click on the "Detect CAF for SWE" section described in Irishandrew's post Item No. 10 (...choose 'Detect CAF for SWE'...) It is grayed out in the software I'm using and consequently I cannot click it. Any ideas that can help me out?
I'm using E-Sys 3.28.1, TokenMaster's Premium V2.7.1.135, PSdZData V.61.5 Thanks! |
10-18-2017, 03:43 PM | #5 |
Rep 324
Drives: 2018 440ix Gran Coupé
Does anyone know how to do this on a 2018 F36 ?
The HKFM2 CAFD file doesnt have the same parameters as in this post.
Speed-NYC_________________________________________________
Current: 2018 BMW F36 440ix Gran Coupe AT, Tanzanite, 2002 BMW E46 M3 Coupe 6MT, Titanium Silver Previous:1998 BMW E36 328i Coupe AT, Blue; 1996 BMW E36 323i MT, Orient Blue; 1992 BMW E36 318i MT, Slate Grey; 1973 Ford Cortina XL, Copper |
10-20-2017, 12:37 AM | #6 | |
Rep 324
Module Section Function Value Default Description HKFM2 3008 3008_1_1_255 werte 05 werte 02 FOB hatch button will also close the hatch HKFM2 300B 300B_1_1_255 werte 05 werte 02 Drivers hatch button will also close the hatch
12-09-2017, 11:58 PM | #7 | |
Rep 147
Drives: 2015 M235i EBII Coral Red
12-10-2017, 02:02 AM | #8 |
Rep 8,364
Is your ECU CAFD missing or corrupt? Why are you injecting?
12-10-2017, 12:10 PM | #9 |
Rep 147
I'm trying to code my Gran Coupe's tailgate so that when I press the trunk button or my fob button, it closes.
I can code everything else with the usual method. But when I go to HKFM2, I get the following error when I try to 'read coding data': Code:
Transaktions-Report: Aktion: Codierdaten lesen HKFM2 [d] [VIN Here] readCPS o.k. CAFD_00002098_004_011_010 Fehler: File for "cafd_00002098-004_011_010" not found! [C012] All I'm trying to code is the following but I need to generate the CAFD in HKFM2 in order for it to work: Code:
HKFM2 3008 HKL_ROCKERSWITCHPOS1_BUTTON_TYPE HKFM2 300B REMOTECONTROLLIFTGATEBUTTON_LONGPRESS_CLOSE |
12-10-2017, 01:24 PM | #10 | |
Rep 8,364
You would likely need PSdZ around P3.60.1-3. |
12-10-2017, 02:16 PM | #11 |
Rep 147
12-10-2017, 03:50 PM | #12 | |
Rep 8,364
Here. Download and place in directory (C:\Data\psdzdata\swe\cafd). |
moltenfire42.50 |
12-10-2017, 03:56 PM | #13 | |
Rep 147
12-10-2017, 07:06 PM | #14 | |
Rep 147
For future readers: I had to code these (I got these values from Speed-NYC in an earlier post in this thread): HKFM2 3008 3008_1_1_255 werte 05 werte 02 FOB hatch button will also close the hatch HKFM2 300B 300B_1_1_255 werte 05 werte 02 Drivers hatch button will also close the hatch |
12-10-2017, 09:25 PM | #15 |
Rep 8,364
09-26-2018, 07:17 AM | #16 |
Rep 198
F36 coding help in austin
apologies if this is not the correct place to ask....but does anyone know of a coding guru in austin to help with this exact function? carpooling in my F36 wold be made infinitely easier! TIA.
02-17-2024, 08:39 AM | #17 |
Rep 4
Drives: 2018 430XI grand coupe
I am looking for links to download the programming files for my BmW 430, and hear you are the coding guru. I bought a wrecked 2018 430XI and rebuilding currently. Need to code new headlight module to the car as driver side is not working. I am going to try to recode the light module and reset a lot of codes before replacing a lot of expensive hardware components. Any help as to what I need to download for this. Beginner on programming/coding on vehicles but ready to learn. See I need e-sys, pszdata, launcher. Anything else you recommend.
