02-05-2024, 01:48 PM | #111 | |
Rep 1,581
After the DIY, I am not using the OEM mirrors that come with heater and dimming glass. Instead using an aftermarket mirror glass that has heater only, but a wider view. What was your car before the DIY? 5-pin or 6-pin? I assume your car has a 5-pin 'High" now with the "High" driver master switch with folding button. What is your PF_SZT_LIN_VAR set to? (Go to "expert" mode in Bimmercode and do a search) What is your factory FA/VO and current FA/VO as far as 430 and 431??
02-07-2024, 05:21 AM | #112 | |
Rep 80
I can’t remember the FA/VO of the top of my head but I think it was 432 as I have rain sensor. I’ll have to redownload the FA/VO options again. I’ll search the code above this evening to see what I have set. 👍🏽
Bang & Olufsen Mod | 6WB | Rear View Camera Retrofit | xHP Flash | DMS Automotive Custom Map
02-07-2024, 01:17 PM | #113 |
Rep 80
fe7565
It looks like I’m set to SZT_LOW_4FACH_FH_RL I have VO 430 & 431
02-07-2024, 01:54 PM | #114 | |
Rep 593
Drives: 2018 F48 X1 xDrive 18D
Try SZT_HIGH_4FACH_FH_SPA Low = 6 pin High = 5-pin over lin 2fach / 4fach = number of doors installed Unsure about the following but I think LL / RL =LHD/RHD, but this is not relevant anymore as communication goes to LIN bus for HIGH variant. Unsure about SPA but we think it’s the dimming part. FH I think is Memory seats driver(From German Word fahrer) |
02-07-2024, 06:11 PM | #115 | |
Rep 1,581
But it’s also important to get the rest of that value correctly, like he said, or you end up with an error like I did, even though mine was already set to “high”. You could either do an FDL code or a VO code. It’s probably better to do an FDL code because it’s a retrofit and mixed original equipment with retrofit that was not part of a factory set up.
Court7.50 |
02-10-2024, 07:20 AM | #116 |
Rep 80
mrpingu and fe7565 Thank you gents! 👍🏽
Changed the code and the driver door error has gone and the heated mirror works as well! Happy days! 🥳
mrpingu180.50 |
02-10-2024, 07:11 PM | #117 | |
Rep 1,581
mrpingu is the person to really thank, he helped me on my issues and I just repeated that.
mrpingu180.50 |
02-11-2024, 04:52 PM | #118 |
Rep 593
You’re welcome
