09-06-2018, 02:02 AM | #1101 | |
Rep 116
The producer is the same for all those screens, then each re-seller installs a different software in it.. imho IF it really works on Avin's screen, then it must also work on others.. |
09-06-2018, 02:25 AM | #1102 |
Rep 118
I think The problem with the buttons is in Android 4.4 they have less restrictions to inject keyboard/touches events.
In Android 7 permissions are tighter. Also I think it could be done with some programming trickery, but its not as easy as edit a list of strings |
09-06-2018, 02:33 AM | #1103 | |
Rep 606
wacky007 Thanks for testing! Which DAB did you use? the Zoulou version (nousb?)? I am going to try to reset the unit but it doesnt respond when I put the latest px3 file in the unit... Maybe I first need to go back a software revision and then try again. Never tried to re-install the same revision of software but my system doesnt indicate there is a software rev available... im hoping its because its the same rev... Topicstart changed with software included. |
09-06-2018, 05:22 AM | #1104 | |
Rep 132
Nothing helped until I went back to 20180703 version. Then let Play Store connect and update. When everything is working again, try to update latest 20180828 version again. DRuw I used realzoulu's app (normal version) and it worked in background play. That is strange, update should work with same revision as well. See florinbrv, he updated over 6 times already. BTW Gdrive link in your first post doesn't work. You didn't copy the whole link (it is shortend with dots...) |
09-06-2018, 05:48 AM | #1105 | |
Rep 102
I'lltry this when I get home |
09-06-2018, 06:30 AM | #1106 | |
Rep 606
Gdrive link updated... oops... Thansk for testing! Regarding the claim of Avin for the 7.1 system and idrive knob.... quote from the AVIN topic: "I have the avin 7.1 and the knob control has never worked. I have gotten ZERO support or even responses from them - let alone any software." |
indigochim12.50 |
09-06-2018, 06:56 AM | #1107 | |
Rep 118
It seems am in the same situation. Updated to last release but task killer is killing even the new whitelisted apps. Going to try with px3_reset.img |
09-06-2018, 07:06 AM | #1108 | |
Rep 606
As far as I know, there is no way to force an install but I will try to downgrade and upgrade again later today. I think that for some reason, part of the old service killer is still active... or something... |
09-06-2018, 07:20 AM | #1109 |
Rep 102
Not exactly force it, but if the memory stick is already connected to the unit before engine start, it will automatically instal the update.
09-06-2018, 07:32 AM | #1110 |
Rep 606
09-06-2018, 09:01 AM | #1111 |
Rep 689
I may be pulling my Ugode system out this weekend as I'm looking to get into a F80
I believe the only difference with mine is it has a removable dash piece so it fits in my E84. I'll probably pull it out in the coming days and throw it in the classifieds- this forum is a lot more active than the E84 one so it probably won't get much interest there. |
09-06-2018, 09:03 AM | #1112 | ||
Rep 201
09-06-2018, 09:04 AM | #1113 | |
Rep 118
Problem is with the "_reset" tag, the installer does not recognize it as an update, dont add it. Now the task killer is working using the new whitelist, tested with Youtube Premium and is not being killed. What I did is a factory reset after the update. Be prepared to navigate chinese menus |
09-06-2018, 09:09 AM | #1114 | |
Rep 116
Or the HU is only in chinese after the reset?! |
09-06-2018, 09:18 AM | #1115 |
Rep 118
09-06-2018, 09:19 AM | #1116 | |
Rep 106
With Zbox, I can neither scroll nor press. Interestingly, Zbox provides in their software an interface for mapping physical button presses to actions. It cannot, however, detect any key presses in order to map them. I expect this is an issue with the Android firmware. My reasoning is that the Android system can detect button presses and is coded to use them, such as the NAV button or the MENU button. It does not, then permit USB devices to see/use those inputs. My reasoning may be flawed. I'm curious what other people think. |
09-06-2018, 09:24 AM | #1117 | |
Rep 116
2 questions: - Can you share with us Zbox.apk? I can't find it on the web, I'd like to try it - Did you try to map the button both with TYPE_A and TYPE_B idrive (in factory setting)? |
09-06-2018, 09:29 AM | #1118 | |
Rep 209
hmm very interesting finding. Have you managed to map any key to your car or to another car?
09-06-2018, 09:40 AM | #1119 | |
Rep 118
My vision being a programer is that the MCU gets the Car button presses and sends them to the EventCenter app, EventCenter generates Intents(kind of events) that are readed by the hu specific apps, like the stock hu launcher. In android 4 these intents can be translated to key presses, but in Android 7 permissions are tighter and this is not allowed. Thats why Idrive buttons only work in the HU apps that have been coded to read these intents. But external apps are not coded to read these intents and intents are not being translated to key presses. |
09-06-2018, 09:45 AM | #1120 | |
Rep 116
09-06-2018, 09:50 AM | #1121 | |
Rep 118
If its a HU app then they should be able to do it. |
09-06-2018, 09:59 AM | #1122 | |
Rep 116
Anyway, long story short: - We are not able to open apps on CarPlay clicking the knob - We are able to scroll through apps on CarPlay using the knob I'm not an expert, I want this to be clear, but if you're saying that "knob inputs" can't be assigned to "CarPlay outputs", why turning the knob makes me navigate through the apps?! To make sure I'm explaining my issue well.. look at this video I CAN do what he's doing from 0.06 to 0.11.. but I cannot do what he's doing in the last second of the video, where he's opening the app.. |
