02-18-2024, 11:59 AM | #1 |
Rep 224
Bimmerlink error codes
When I clear the error codes, once I drive again they always return, then I clear them again and the cycle repeats itself. The permanent error codes are always green, never any issues, does it matter if the codes return? The car is running faultlessly with no issues, so I don’t really get the point of continuously clearing the fault codes
Martin
02-18-2024, 01:15 PM | #2 |
AH3 Owner
201
Rep 307
Drives: BMW 335i ActiveHybrid 3
Info Memory - You can pretty much ignore these most of the time unless you have an actual problem, then they can guide you to the right area. Most of these are informational on events that have taken place.
Error Codes - If you clear them and they come back, you have an issue. Either a developing issue that will get worse over time, or an issue you have not noticed yet. Permanent Codes - An issue is present |
02-18-2024, 01:27 PM | #3 |
Rep 224
Vehicle just had a health check from a BMW main dealer, no issues whatsoever. Like I said it runs perfectly, I guess these issues are historical, I’m not sure of the quality of an app that costs £30, I have ISTA and I run a check now and then to clear any faults (none of the faults that BimmerLink throw up show up in ISTA) I just regularly clear the memory in ISTA and don’t experience any issues. BimmerLink is useful for a DPF regeneration, and I had an issue with the LED gear shifter randomly failing, BimmerLink solved it, but I don’t think it’s a serious tool for diagnosing problems
Martin
02-18-2024, 02:22 PM | #4 |
AH3 Owner
201
Rep 307
Bimmerlink shows the same error codes ISTA would, except for Info Memory which ISTA does not show. By that, I'm assuming you are seeing these codes in the Info Memory section of Bimmerlink which can be ignored. I have 20 codes in there that keep coming back.
Bimmerlink's weakness is the inability to offer descriptions and troubleshooting steps for the codes. If you are using Bimmerlink, you would then head to https://bmwfault.codes/ and see the descriptions. Bimmerlink is no ISTA, and considering a regular BMW driver doesn't even know about acquiring ISTA being a possibility, Bimmerlink can help a lot in diagnosing codes. Bimmerlink's strongest points are being able to monitor sensors easily, registering a new battery and clearing codes along with some troubleshooting capabilities if you use the URL above. |
ReMiii4021.50 |
