BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Is it possible to clear check engine codes with Esys / an ENET cable?
      12-17-2018, 09:00 AM   #485
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by pirrup View Post
Hi shawn,
Can you please send me the link to tool32 also?
Thanks!
PM sent.
2016 650i GC M-Sport w/ 20" 373M Wheels; Alpine White; Individual Opal White Full Merino Leather; Gray Poplar Wood Trim
Anthracite Alcantara Headliner; Ceramic Controls; Executive Package w/ B&O Sound System; Integral Active Steering, etc.
      01-31-2019, 07:00 AM   #486
Hege01
Drives: BMW 320d GT XD, BMW 120d XD
tool32
Hi Shawn,
can I please also get the link?
Thanks.
Marek
      01-31-2019, 07:01 AM   #487
shawnsheridan
Originally Posted by Hege01 View Post
Hi Shawn,
Thanks.
Marek
You cannot Send or Receive PM's yet. Send me one when you can.
      01-31-2019, 01:18 PM   #488
Hege01
tool32
Hi Shawn,
could you please, try now?
Thank you.
Marek
      01-31-2019, 03:39 PM   #489
shawnsheridan
Hi Shawn,
Thank you.
Marek
I said send a PM.
PM sent.
      03-08-2019, 11:19 AM   #490
thekoukimonster
Drives: Bmw f30 320d
Hi there, could you please send me a link to tool 32 also, will be appreciated.
      03-08-2019, 11:59 AM   #491
shawnsheridan
PM sent.
      03-24-2019, 01:42 PM   #492
jeppe777
Drives: F30 335i
Hi, please can you pm the tool
      03-24-2019, 01:43 PM   #493
jeppe777
Drives: F30 335i
Can you also send me the latest esys
      07-18-2019, 09:20 PM   #494
Ali0056
Drives: 2013 335i x-drive
Can I please get the link to Tool32?
Thanks!
      07-18-2019, 10:49 PM   #495
shawnsheridan
PM sent.
      07-18-2019, 10:49 PM   #496
shawnsheridan
Thanks!
I replied to your same PM.
      08-27-2019, 07:04 AM   #497
joq3
Sweden
74
Drives: BMW 328i F30 M/T -13
Can you PM Tool32 too?
Thank you!
      08-27-2019, 08:53 AM   #498
shawnsheridan
Thank you!
PM sent.
      09-21-2019, 04:44 PM   #499
Stef80
Drives: F20 120i msport auto
Good evening Shawn,
I have an old 2015 enet cable. Do you think it is ok or do I have to get a new one?
Also, could you sent me ways an tool32 links please?
Thank you very much.
      09-21-2019, 04:47 PM   #500
shawnsheridan
Originally Posted by Stef80 View Post
Good evening Shawn,
Cable is unchanged. PM sent.
      09-21-2019, 05:02 PM   #501
Stef80
Thank you again. Do you also have esys link? Do I need esys to clear errors or only tool32?
      09-21-2019, 05:03 PM   #502
shawnsheridan
Either can clear errors. PM sent.
      09-22-2019, 05:41 AM   #503
Stef80
Can I ask for a little more help?
I installed everything and did the rearm procedure, set the right series vehicle (f20), changed the date within the suggested timeframe (27/12/2018) but as can be seen in the photo I can not connect in the ECU, although the vin in the corresponding cell is correct.
What might have done wrong?
https://www.imageshack.us/i/pma1FYTEj
      09-22-2019, 09:15 AM   #504
shawnsheridan
You have no Connection Targets.
If the "Open Connection" window under "Target" is empty (no targets), verify the following:
  1. That the "psdzdata" folder is installed properly (From the PSdZData_Lite or PSdZData_Full extraction, copy the "psdzdata" folder to "C:\Data" (i.e. "C:\Data\psdzdata")
  2. That the psdzdata chassis folders each have an empty "dist" folder. Make sure that there is an empty "dist" folder in each of the psdzdata chassis folders, and if missing, create as needed, e.g.:
    • C:\Data\psdzdata\mainseries\F001\F001_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\F010\F010_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\F020\F020_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\F025\F025_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\F056\F056_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\I001\I001_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\K001\K001_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\KE01\KE01_xx_xx_xxx\od x\dist
    • C:\Data\psdzdata\mainseries\RR01\RR01_xx_xx_xxx\od x\dist
  3. The the E-Sys "Options" => "Settings" => "Directories => Data: path" is set properly (e.g. "C:\Data")
      09-23-2019, 11:42 AM   #505
Stef80
In the main series list, for the f20 1 series I choose f010?
      09-23-2019, 11:43 AM   #506
shawnsheridan
No. You would choose F020.
