01-15-2020, 12:26 PM | #287 | |
Rep 5,457
Drives: F30
If they find a warrantee-able issue, you wont have to worry about it. But based on your comments thats unlikely to be the case. |
01-16-2020, 10:17 AM | #288 |
Rep 68
Drives: F30 328i Sport
Happened to my 2012 328i n20 with 83k miles right before new years. Mechanic says the cam journals are damaged along with the cams. Timing chain failed which broke the guides which blocked the oil which caused a bunch more damage. Cheaper to replace with similar mileage used n20 which is around $9-10k.
So right now I'm not sure what to do. I know that I don't want to put $10k cash into a car that's worth somewhere around that much. Do I need to be in the class action law suit to realize the benefits of the outcome? For instance if I scrap the car and take the loss could BMW pay me back as part of the settlement? Would I need to contact an attorney to be part of the suit? I'm just at a loss. My car was well maintained and in good condition. But now I'm talking about giving it to my mechanic so I don't have to pay his labor of pulling apart the engine!?!? I'm in shock. TIA |
01-16-2020, 10:30 AM | #289 | |
Rep 13
Dealership didn't charge me for anything either visit and I didn't even buy my car from them. Guess it's dealer dependent. |
01-16-2020, 11:40 AM | #290 | ||
Rep 5,457
Drives: F30
Its the middle of the road... nothings wrong but I want you to bring it in and check anyway... that will be charged at least an hours labor. As it should in my opinion. They cant diagnose cars for free or their businesses would not survive. |
01-16-2020, 11:48 AM | #291 |
Rep 5,457
Drives: F30
@ntalekt
You need to take a deep breath before you make a bad decision. If your mechanic is quoting 10k for a used motor with around 80k on it... you need to run. Have the car towed to your driveway and reevaluate. Used motors are as cheap as $2500 depending on mileage, year and location. Install should be well under $2k. Im telling you that you can put a motor in your car for $5k on the lower end to $6-7k on the higher end (lower miles/newer year). Pay your current mechanic the few hundred you owe him and tell him you are going to think about what to do next. Paying him $10k or giving him your car are the two worst choices you could make, trust me! |
exE36M3487.50 |
01-16-2020, 12:49 PM | #292 | |
Rep 68
If I can walk away from the car now knowing that I might see a settlement from BMW in the future...why wouldn't I? And the question still stands about being part of the class action suit. Thanks. |
01-16-2020, 01:57 PM | #293 |
I can haz cheezburger?
6799
Rep 3,677
Drives: 14 Sahara/08 335xi/22 Maverick
Sooo, the used engine being installed in my 428 (got hydrolocked) has 87-89 k miles from a 2015 x1 28i. I’m still waiting for a VIN number to determine the built date (I’ll assume it’s prior to 03/2015). The engine will have a 1 year warranty and I still have Maxcare warranty as well. Right before they end I’ll have to have the TC/guides replaced, only this time it’ll be on my dime as I was fortunate to have it done prior to my engine being hydrolocked.
For the member who mentioned about bringing it in and having the same luck I did, try to schedule an oil change and mention to your SA about a whine/rattle. They shouldn’t charge you a diagnostic fee since it’s in for a oil change. Also, check your dealers website for oil change specials ($89 for N20’s near me) and also check if they have complimentary vehicle inspections as well so you won’t have to spend a penny. |
mike_MAN20.50 |
01-16-2020, 04:45 PM | #294 | |
Rep 5,457
Drives: F30
01-16-2020, 04:52 PM | #295 |
Rep 5,457
Drives: F30
@ntalekt
You can get a used motor with well under 50k on it and revised timing chains for under $4k shipped. Dime a dozen. Plus $1500 install. Your at $5500 back on the road. Your guy wants $8300. You need a new guy or stay away from the truth that you find on this forum. I would not pay more than $6500 tops. And thats a bit high. Depending on your financial situation it could be silly to start over for this kind of money. You'll end up in a go kart unless you are willing to take a bath. Happens all the time to a lot of people, wouldnt be the end of the world. Just trying to help point out some options before you make a decision. Keep us posted on what you do... As for the lawsuit, Im interested to hear the answer to your question also. Hope someone who knows chimes in. |
F30lolz6798.50 |
01-16-2020, 09:39 PM | #296 |
Rep 660
Drives: 2014-320Xi / 2017-330Xi
Was the time chain issue effectively solved on most recent models years N20, such as 2015 and up?
What are the differences? Was the plastic material modified to get more oil & temperature resistance? I wonder if the number of cases on models after 2015 has significantly reduced giving me assurance to buy a 2016 CPO? Any thoughts? |
01-16-2020, 09:47 PM | #297 | |
Rep 147
sspade2464.50 |
01-16-2020, 10:31 PM | #298 |
Rep 17
I saw in a different thread that sludge and the Start/Stop are the main culprit - warming ur car up, 5000-6000 mile oil changes, and coding out or keeping Start/Stop are going to be the biggest helps you can do prior to warning signs.
01-16-2020, 10:31 PM | #299 | |
Rep 660
If you are really a smart ass, then provide links as many do around here. In my view, if you have nothing to answer, beyond telling someone to read, then you better ignore the others post. The search engine here is not the best. Go mind your business! Last edited by Pauloxxi; 01-16-2020 at 11:08 PM.. |
bmalbert223.00 Jonny354.00 |
01-17-2020, 06:45 AM | #300 | |
6799
Rep 3,677
Pauloxxi339.00 |
01-17-2020, 07:20 AM | #301 |
Rep 660
Yes! I know that. My question is if the new parts constitute an effective solution.
From 2015 the issue dropped significantly to none? Does anybody know what changed in the plastic rails for the time chain? Funny is that another guy told me to read, like the answer was obvious. |
01-17-2020, 07:23 AM | #302 |
Rep 2,664
It's a 20+ hour job + fluids + gaskets. $1500 install is probably a little light. |
01-17-2020, 07:59 AM | #303 | |
Rep 145
Just let me know. |
01-17-2020, 09:17 AM | #304 |
Rep 1,607
This is all just speculation on the forums. There are some who posted saying they did 5-6 OCIs and didn't use start/stop, yet their timing chains whined/failed. No one knows for sure what caused the old parts to fail and what changed in the new parts. That is the bottom line despite hundreds of posts on this topic. It is a coin toss...if your engine exhibits the whine, get it addressed. If it doesn't, keep on driving on.
2020 M550i (G30) | Carbon Black/Black Nappa | DHP | DAP | Executive | Luxury Seating | Park Asst | Ceramic Controls | Front/Rear Heated Seats | 20" 668M wheels
2021 X3 (G02) | Dark Graphite Metallic/Cognac | Premium | DAP | Front/Rear Heated Seats Sold/Retired: 2012 328i (F30) |
01-17-2020, 10:03 AM | #305 | |
Rep 212
Pauloxxi339.00 |
01-17-2020, 12:20 PM | #307 |
Rep 660
F30lolz6798.50 snakechild0.00 |
01-17-2020, 03:26 PM | #308 |
6799
Rep 3,677
Man everyday I’m beating myself with a drum about my engine getting hydrolocked AFTER getting the dealer doing this job for me. Before my warranties expire I’ll spend the $2k and have an indy do the job on my replacement engine (assuming it was built prior to 03/2015).
And still don’t have my car back. Maybe another week or two |
