01-16-2020, 02:14 PM | #1 |
Rep 76
So I just got everything hooked up with the Ethernet cable - all connections were tight but for whatever reason I often received a message that it couldn't connect...essentially after just spamming the connect button it would finally connect.
I love the app and it was really simple to adjust some things but yes there are tons of options. I'm curious what changes users have made that they recommend since some of the stuff was lost on me. My only issue I need assistance with, however, was a German message which appeared overtop the M340i dash message I set up. I have no idea how to make the word go away without removing the M340i logo which I rather enjoy. Edited to add: searches show this issue is common...it seems fixes are basically to reset and not have it or to have the instrument cluster updated according to posts on forums. Of this latter suggestion it seems like there is no confirmation it allowed the emblem to still work. So I may just have to go without. In for further more recent info if people have it tho |
01-16-2020, 02:18 PM | #2 |
Rep 76
Changes I made:
Side mirrors fold up and down on lock/unlock (sort of worried long term for the motors with the excessive use but idk) Video in motion M logo in instrument cluster and M animation Screen at start up M340i displaying in gauge cluster (again with the German word overlayed) Driver and passenger front seatbelt audible alert deactivate Added tire temperature to the tire pressure info Changed the tilt to 50% on the passenger mirror when using the reverse feature to tilt the mirror Took away the messages at start up Changed lighting to Red in sport mode *I'll edit as I recall the others - also using Ethernet cable and adapter to do this through my IPhone fwiw |
F36GC_NYC159.50 BeerHerder250.50 |
01-16-2020, 04:02 PM | #3 |
Rep 1,755
I can offer no assistance other than to tell you that "Platzhalter" means "Placeholder".
2016 428ix, r, 2018 430iC, 2018 330it
BeerHerder250.50 |
01-16-2020, 04:06 PM | #4 |
Rep 76
01-16-2020, 04:30 PM | #5 |
Rep 147
I'm using the Bluetooth obd2 adapter way more solid connection and faster in my opinion. I have some of the stuff you have coded but in addition I also disabled the fog cornering lights and disabled us side markers. I also changed the chime to BMW i
I will be coding sport transmission and launch control soon I just haven't had time. Sorry don't have any help for the German thing. |
01-16-2020, 04:48 PM | #6 |
Rep 76
I didn't see any info for launch control and my car already has sport+ mode so I didn't really see much I could do with that. I saw the option to add sport+ to cars without that feature.
01-16-2020, 04:53 PM | #7 | |
Rep 147
It's sports transmission, which is the manual shifting when you put the gear in manual would be sporty (it'll have the S1,S2,etc) you need to have that enabled to be able to do launch control, also launch control is under advanced tab. Watch this video by thicf30 he explains it and shows how to do it: |
01-16-2020, 05:08 PM | #8 | ||
Rep 76
01-16-2020, 05:24 PM | #9 | |
Rep 1,755
01-16-2020, 05:28 PM | #11 | |||
Rep 147
1. You have to drive the car for at least 6 miles and make sure it's warmed up 2. Put the car in sports + mode and move the shifter to the left so you see S1 in the dash 3. You press and hold the brakes allllll the way down then press the gas all the way down 4. The car will rev itself appropriately and You should see a flag pop up in the instrument cluster saying launch control 5. Once you see the flag let go of the brakes and the car will do the rest |
BradMacklin44.00 |
01-16-2020, 09:49 PM | #12 | ||||
Rep 76
01-17-2020, 04:05 AM | #13 |
2JZ-GTE
3005
Rep 3,986
So complex, I wish it would say it is ready for launch control. Rather than going through the steps hoping it will work and it doesn't when the rear tires go up in smoke.
01-17-2020, 08:54 AM | #15 |
Rep 474
Drives: F36 440i GC
Here's my list:
2024 Porsche Taycan 4S
2017 Ducati Monster 821 |
eluded3005.00 |
01-17-2020, 09:13 AM | #16 |
Rep 76
It sounds pretty straight forward but to clarify with this "Enable door handle lights in reverse" do you find the light actually assists in reversing visibility at night or do you have that feature because it looks good? Haven't played with that one
01-17-2020, 11:06 AM | #17 |
Rep 474
Drives: F36 440i GC
It adds enough light to help visibility next to the car if you're backing into a tight space. I find it useful when backing into our garage while dodging trash cans, telephone poles, etc. in our alley.
01-17-2020, 01:28 PM | #18 |
Rep 109
by default the angle eyes as day time running lamps will be at their full brightness. When you turn on your headlights, they dim. You can set how bright you want them to be with headlights.
01-31-2020, 02:15 PM | #19 |
Rep 51
Drives: BMW 530 xdrive
hello,
allumage eclairage poignées de porte en marche arriere affichage temperature des pneus extinction de la radio à l'ouverture de la porte conducteur affichage digital de la vitesse réelle dans le bc fermeture automatique immediate des miroirs au verrouillage de la voiture deblocage de la lecture des dvd ou usb en roulant suppression du blanc dans le bc allumage des anti-brouillard suivant le coté où on tourne sonnerie du tel plutot que celui de bmw auto-zoom dans le gps à l'approche d'une intersection affichage photo des contacts dans l'i-drive mémorisation de la derniere position de la clim modifier la sensibilité du retroviseur photochromique lighting lighting door handles in back tire temperature display radio shutting out at the opening of the driver's door digital display of the new speed in the bc automatic closure of mirrors at the locking of the car unlocking the playback of DVDs or usb while driving removal of white in the bc ignition of fog-proofs depending on the side where one turns ringing such rather than that of bmw self-zoom in the gps as you approach an intersection photo view of contacts in the i-drive memorization of the last position of the air conditioner change the sensitivity of the photochromic reviewer |
01-31-2020, 02:33 PM | #20 | |
E36fiend
285
Rep 637
Drives: 2014 435i xDrive
Rear (LCI) tails on as DRL iDrive turns off when door opens (after turning ignition off) Surround/rear/side view cameras enabled at all speeds Rolls Royce sound scheme |
02-01-2020, 12:39 AM | #21 |
2JZ-GTE
3005
Rep 3,986
– kill the active sound
– change the amount of flashes when you unlock it – change the angle the mirror goes down in reverse – European brake lights – Unlock all the doors when you hit unlock - Set the rear camera to the maximum speed and distance |
04-02-2020, 05:50 PM | #22 |
Rep 1,235
Recently got a 2013 328i sportline, with lowered m sport suspension. Already had sport+ mode but here's what I did with the bimmercode app.
Added sport transmission (now it says S1 when shifter is pulled left not DS) Raised xenon brightness Made xenon always on/daytime light Removed idrive warnings Side mirrors auto in/out with lock/unlock Digital speedometer in dash Seatbelts reminder off Tire temp° on Trip averages "never" reset Passenger mirror at 50% tilt when reversing (was 70%) Windows/sunroof open/close with key fob Sport displays on (I dont think it works on my car) Auto start/stop ALWAYS OFF I think that's it. There may be a couple more but that's what I can remember. So far no issues and the sport transmission is great |
