BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > Is it possible to clear check engine codes with Esys / an ENET cable?
proTUNING Freaks
      03-22-2018, 07:05 AM   #441
shawnsheridan
shawnsheridan's Avatar
Drives: 2016 650i GC M-Sport
Originally Posted by GuMiMoRo View Post
I try run lesen_provisioning_data but:
apiJob("NBT","lesen_provisioning_data","","")
Satz : 0
OBJECT = nbt
SAETZE = 1
JOBNAME = lesen_provisioning_data
VARIANTE = NBT
JOBSTATUS =
UBATTCURRENT = -1
UBATTHISTORY = -1
IGNITIONCURRENT = -1
IGNITIONHISTORY = -1
Satz : 1
RET_STATUS = 255 FF
JOB_STATUS = ERROR_ARG_TYPE
any suggestion how to solve this?
No idea. Something is wrong with the Argument you used.
Be sure to run Tool32.exe with Admin Rights too.
      03-22-2018, 07:21 AM   #442
GuMiMoRo
Drives: F31
lets see... thx shawn
      03-22-2018, 07:51 AM   #443
GuMiMoRo
Drives: F31
Argument
      03-22-2018, 07:53 AM   #444
GuMiMoRo
Drives: F31
this screen show
      03-22-2018, 09:15 AM   #445
shawnsheridan
this screen show
In the Arguments box try entering:
0x03;0;0
      03-22-2018, 01:29 PM   #446
GuMiMoRo
Drives: F31
0x03;0;0
nothing happens... the same error...
      03-22-2018, 01:53 PM   #447
shawnsheridan
I have no idea then.
      03-22-2018, 02:10 PM   #448
GuMiMoRo
Drives: F31
Well almost the same...
      03-22-2018, 03:08 PM   #449
GuMiMoRo
Drives: F31
      03-22-2018, 03:09 PM   #450
shawnsheridan
What is that supposed to mean?
      03-22-2018, 04:13 PM   #451
GuMiMoRo
Drives: F31
Without any idea how to put tool32 working!
      03-22-2018, 07:58 PM   #452
GuMiMoRo
Drives: F31
Strange behavior of the tool 32...
      03-28-2018, 03:27 PM   #453
koppermonty
Drives: BMW E90 M Sport Auto
Hi Shaun, could you send me a link to the tool 32 Please?
      03-28-2018, 03:43 PM   #454
shawnsheridan
PM sent.
      03-28-2018, 03:47 PM   #455
koppermonty
PM sent.
Thanks very much Shawn, Im new to coding BMW's but experienced IT user. I have been using the bimmercode app and when changing some options (on easy mode) to do with the seat belt chime it failed and then threw up a restraint error code. Restored the ECU from a backup and all clear but now the code still comes up.
There will be no physical error but is it simple enough to clear the codes with this tool?
Thanks, Joe
      03-28-2018, 03:50 PM   #456
shawnsheridan
Thanks, Joe
Yes, but you must have ENET Cable, not Bluetooth Dongle.
      03-28-2018, 04:21 PM   #457
koppermonty
What prg is it for an f31 2013 please??
      03-28-2018, 04:37 PM   #458
shawnsheridan
.prg files are ECU specific, not chassis specific.
      04-01-2018, 01:58 PM   #459
Variante Alta
Variante Alta's Avatar
Drives: 2017 F31 328d Black on Saddle
Link to Tool 32?
PM sent.
Hey guys - I have E-Sys installed on a Windows 10 machine - it's working fine. I'd like to use the Tool32 tool for error code reading and erasing but the earlier link to the toolkit is a much earlier version which doesn't run on this machine. I hate to bother (Shawn) - but is there a compatible version for a Win 10 machine? If so, can I bother someone for the link?
Really appreciate your help. Jim
      04-01-2018, 01:59 PM   #460
shawnsheridan
Install in XP SP3 Compatibility Mode and Run with Admin Rights.
      04-01-2018, 04:32 PM   #461
jalami
Drives: f30
I have the same fault
      04-03-2018, 01:45 PM   #462
koppermonty
You can clear with E-Sys Transmitter:
  • Click "External Applications" in the left menu.
  • Click "External Application"
  • Double-click "Transmitter"
  • Scroll to the bottom and click "14 FF FF FF,31 01 0F 06,31 01 40 00 00,31 01 40 00 05,31 01 40 00 01;Clear all DTCs (clear DTC,clear Infospeicher,ZFS DM_Lock,clear ZFS DM_Clear,ZFS DM_Unlock)"
  • Click Connect
  • Click Send
But if you want to read and interpret them in a meaningful way, then you need ISAT/D (Rheingold), which I cannot help with.
I used the above solution via Esys in the end to clear the restraint/airbag error code. It worked wonders via this method.
