02-14-2018, 01:14 PM | #1 |
Rep 10,473
Fs: Complete OEM Electric Rear Sun Blind Retrofit
Complete Option 415 Sunblind For Rear Window Retrofit including Driver Front Window/Mirror/Shade Switch, shelf, as well as left and right blind cap. Easy Retrofit 1) Remove Rear Shelf 2) Remove your speakers and speaker box (if applicable) 3) Install Speaker Box and Speakers in Replacement Shelf (if applicable) 4) Connect 2 wires to REM A174 pin 34 and 35 5) Unplug Front Drivers Switch and plug in included Replacement 6) Add Option 415 to coding Done At your option, if you have different color shelf you wanted to keep, you could also use your current shelf and cut out the hole for the sunblind. I just feel the above is easier. Blind known to work with F30, F35 and F80 $600 + $50 Shipping CONUS (48”x24”x8”) Box FedEx Ground Insured. See Diagram Below. Reuse parts 5,7,9 (if applicable) and 11 from current car. Yellow Highlighted parts included. New MSRP Retail over $1,550+ Preowned for about 1/3 of that. Last edited by IK6SPEED; 06-24-2018 at 10:00 PM.. |
02-14-2018, 03:24 PM | #2 |
No 55mph
1621
Rep 8,476
Nice
I'd pick this up if it were for F32/F82 Good price, couple years ago I paid $475 for Blind & Shelf only, no switch, for my E92- this is everything you need To buy these new from any BMW parts vendor is waaaaay more $$ The car end of the wiring harness w/connector was already present behind the PS rear pillar cover - it was just a simple matter to plug the blind in with no need to run new wires. IDK, if same on newer models - BMW is constantly removing 'redundant' items from their cars without options in an attempt to save $$ You would think it would save more $$/time in labor + less inventory to just make ALL the wiring harnesses the same regardless of what options car is getting...
IK6SPEED4488.00 |
02-15-2018, 12:48 PM | #3 |
Rep 138
Does the shade just stay up without the use of a hook on the pillar at the top or anything?
Also, would I be able to do the coding myself using the Bimmercode app? Thanks! |
02-15-2018, 01:00 PM | #4 | |
Rep 10,473
I’ve never used Bimmercode App, only eSys, so I cannot answer that question. My perception was Bimmercode could change parameters of installed options, not add new ones, but again, I am totally unaware of Bimmercode abilities. Perhaps ask in coding section...or a Bimmercode user looking at ad might answer. Video from YouTube (not mine) of unit in action. Last edited by IK6SPEED; 02-15-2018 at 01:51 PM.. |
03-02-2018, 03:16 PM | #5 |
Rep 1,509
The rear shade was factory installed in my F32. It's one of those things you might not really appreciate until you have it.
As well as shielding the interior from the Northern California sun, it's handy if you have an idiot with high beams behind you. I also used it a few weeks ago when some moron in the Bay Area who was hogging the fast lane tried to speed up to keep me from getting around him on the right, then started flipping me off; I think it ruined his day when I just raised the shade and blocked him. |
05-26-2018, 01:59 PM | #12 |
Rep 5,457
Drives: F30
How easy does the rear parcel shelf come out? Directions anywhere on here? Cant seem to find...
05-26-2018, 03:05 PM | #13 | |
Rep 10,473
https://www.newtis.info/tisv2/a/en/f...blind/HtJXJOS4 |
08-30-2018, 06:48 PM | #15 |
936
Rep 4,326
Drives: M340
This is a great deal. Bump for you.
I have checked the rear shade option in every BMW that I have ordered.
2020 G20 M340 xDrive - Portimao Blue - ZDA|ZPP|ZPX|1CR|1PE|6NW|6WD
2016 F10 535i xDrive - AW - Retired 2011 E92 M3 - AW……………....ED April 29th, 2010 - Retired 2007 E92 335i -Space Gray.....ED Oct 19th, 2006 - Retired |
IK6SPEED4488.00 |
08-27-2019, 08:29 AM | #22 |
No 55mph
1621
Rep 8,476
Just do it - can't take it with you
obert1781.00 |
