02-20-2020, 03:20 PM | #1 |
BMW Enthusiast
Rep 16
Best Mods for track day
Hey everyone, I'm curious about tracking my F30 335i for the first time and was wondering what would be the best mods for it. I'm already FBO and have KW coilovers with SS brake lines and EBC pads. Is there anything else I should look into? Thanks for the help
2013 BMW 335i xDrive: [Sold]
02-20-2020, 05:22 PM | #2 |
Rep 3,540
Which EBC pads, what brake fluid, and what tires do you have?
FlorinQCK-2.50 |
02-25-2020, 10:55 AM | #4 |
Rep 3,540
You'll definitely want different brake pads for the track. EBC reds are fine for spirited street/canyon driving, but won't hold up to repeated threshold braking at the track. I found what their limit was when bedding my street set, and that strongly convinced me they aren't to be used on the track.
The next "mod" I'd do is dial in your suspension damper settings so that the ride is smooth but controlled. That means not going too stiff, where you're actually decreasing your tires' grip.
RedSectorA37.50 FlorinQCK-2.50 |
02-25-2020, 11:05 AM | #5 | |
BMW Enthusiast
Rep 16
FlorinQCK-2.50 |
02-25-2020, 10:54 PM | #6 |
BMW CCA Member
488
Rep 808
Are you going as part of a school like the BMW CCA or Bondurant? Or is it just an open track day?
If the former, just make sure your tire pressure is to spec and maintenance is up to date. You WILL find your car will do more than your skillset allows. If the latter... see if you can get a more senior driver (like an A-class person) to ride along with you and give you seat feedback. I've personally found that just exploring a track can be fun, but you hit a threshhold pretty fast in the day. But with an instructor, your skill level improves dramatically. |
FlorinQCK-2.50 |
02-26-2020, 08:10 AM | #7 | |
BMW Enthusiast
Rep 16
FlorinQCK-2.50 |
02-28-2020, 06:39 PM | #8 | ||
Rep 14,115
Drives: G82 M4C X-Drive
2022 G82///M4 Competition X-Drive - KW-HAS, EBC Bluestuff, Millway Race Camber Plates, Cup2 Connect*, PSI High Flow Midpipe, Lightweight Front Lip, M Perf Flow Through Wing Previous • 2018 F80 ///M3 CS • 2016 F80 ///M3 IG: Raging_G82 |
FlorinQCK-2.50 |
03-03-2020, 10:53 AM | #10 |
Rep 14,115
I would definitely look into upgrading your tires. Those Hankook's are decent for the price, but you're not getting all the power to the ground you could be.
If you don't want to get dedicated track tires, in the least, get better street tires like MPS4S. RE71R's are currently the hot tire for track use and occasional street use. They wear faster but perform just as well as NT01's but are still good in the wet. I'm currently on MPS4S but I am looking to get RE71R's on my M3 CS for track use. On the flip side, if this is just an open track day and your first time, just use what you got! The Hankooks will do just fine and the most important thing is to work on you as a driver before you start thinking of dumping money on mods. Tires would be my NEXT move however if you continue to attend track days.
FlorinQCK-2.50 |
03-03-2020, 11:20 AM | #11 | |
BMW Enthusiast
Rep 16
FlorinQCK-2.50 |
03-03-2020, 10:31 PM | #12 |
Rep 1,127
stock is 100% fine for a track day, you will have a blast just enjoy it.
03-04-2020, 10:08 AM | #13 |
Rep 891
For the first couple of track days you won't be pushing that hard so stock is a good place to start.
As Farkle mentioned, once you start getting faster the RedStuff will not keep up. Once they overheat they wear extremely fast and can totally screw your rotors. My car is several hundred pounds lighter than yours and that was my experience. I lost about half the material on one track day.
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
FlorinQCK-2.50 |
03-04-2020, 11:01 AM | #14 | |
Rep 3,540
FlorinQCK-2.50 |
05-15-2020, 10:46 PM | #16 |
Rep 262
Drives: 2013 BMW 335i M-Sport
After tires I would get an LSD to compliment your suspension setup. The lack of LSD has a serous impact on lap times in tighter courses. Also camber plates if you get really serous about the track.
FlorinQCK-2.50 |
06-04-2020, 03:24 PM | #17 | |
Rep 3,947
FlorinQCK-2.50 |
06-04-2020, 03:49 PM | #18 | |
Rep 14,115
Guaranteed the Hankooks are going to get greasy, not that MPS4S won't either, but at least you will better good grip up until that point. The Evo2's won't performa as well and still get greasy. They are a good bargain performance street tire, but they simply aren't a track tire. Of course RE71R's wear faster than street tires, you're not going to get a sticky track tire that's gong to last 20k miles. Gotta pay to play and compared to the Yoko A052's they last longer. RE71R's are not slicks, they have a much more progressive break away and don't require as much from the stock brakes as slicks, but you are pushing your car much harder and for longer than on the street and your car will have more wear and tear, wear and tear is just part of the sport. In the end, though I defer to what zinner posted–OP should just go with what they have for now, have fun and think about upgrades after they get more seat time.
FlorinQCK-2.50 |
06-04-2020, 07:29 PM | #19 | |
Rep 3,947
I would like to see some more reviews of the S007A. Won't be as stick as RE71s but maybe last a bit longer... idk. |
FlorinQCK-2.50 |
06-05-2020, 11:30 AM | #21 |
Rep 14,115
All depends on your budget. 8 track days is about right for what you get, which is NT01 levels of performance you can drive to and from the track even in the wet.
FlorinQCK-2.50 |
06-05-2020, 12:41 PM | #22 | |
Rep 3,540
I'm at 5 days on NT01s right now. Lots of life left, but I'm not convinced it's a faster tire than the R-S4s were. That could be due to just how wide of a tread width the R-S4s have in 245/40-18 though. It's definitely easier to overdrive the R-S4s before NT01 though.
FlorinQCK-2.50 |
