BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Wheels and Tires -- Sponsored by The Tire Rack > 428i F32 Tyre and Wheel Fitment
proTUNING Freaks
      07-09-2021, 10:38 AM   #1
kodak7
Drives: BMW 428i M-Sport
Hey guys, looking to buy a new set of tyres and wheels for F32 428i. Currently running stock adaptive suspension and looking to achieve a flush or slight poke stance.
Wheels:
DFS M223 (F) 19X8.5 +35, (R) 19X9.5 +40
Tyres:
Michelin PSS (F) 245/35 19, (R) 275/35 19
I have done a little testing on WheelSize.com and it seems to be fine, mainly worried about the fronts with turn rubbing.
Is this going to fit without rolling? I don't mind if they rub at extreme bumps.
      07-10-2021, 08:42 AM   #2
J555
Drives: F31 LCI 340iX
Flush or very slight poke would be e.g. 19x8.5" ET30 + 19x10" ET40 (or similar combination of width and ET).
245/35 would not rub at all, but it's slightly smaller in diameter than stock. On the other hand, the 275/35/19 is close to maximum suitable diameter. Any reason for that, any reason why are you looking at much bigger diameter at rear?
(guess you are not x-drive, then it would be unsuitable, no matter what)
      07-10-2021, 10:50 PM   #3
kodak7
Thanks for the reply.
The wider rear is just for aesthetics, you thinking 265 would be better?
      07-15-2021, 05:01 AM   #4
Tommi_Mav
Greece
66
Drives: F32 435dx
Wheels:
Tyres:
I use 255/35/19x9.0 +29 in front (wheel sits the same as the ones you're looking at, regarding distance from the suspension and inside of wheel well) and have no rubbing at all, so you won't have either.
On the rear I use 265/35/19x10.0 +40.
Regarding poke, I think you'll be flush with your option, since mine both front and rear poke.
I would opt for a tyre combo that I wouldn't have difference in rolling circumference front to rear. So, I think a 245/40/19 front tyre suits better the 275/35/19 rear, otherwise you can opt for a different combo.
      08-05-2021, 06:16 AM   #5
janko990
Macedonia
Drives: x3 2011 f25 and 420d f32m-pack
i agree with tommy mav
