10-14-2021, 01:08 PM | #23 | |
1296
Rep 3,533
first off the numbers would change as the cat heats up and over time as the cat loses efficiency the numbers would change. second, the numbers would dramatically change with a dp swap. you would need custom calibrations for offsets with different dps etc. plus the narrowband window is so small it's literally only there to make sure there is a specific offset/difference from the primary 02 to know if the cat is working or not. there just isn't a place for this in the tunes, if there was and this was a thing it would be a nightmare for tuning.
BMWILUVU809.00 |
10-14-2021, 01:26 PM | #24 | |
Rep 7,606
We don't need to debate about it anymore because absent any "official" documentation for the N55 its just back and forth. I said my 2c based on everything i have seen and my recommendation against running one long term for OP (why this came up in the first place). I found the last thread i posted a few references in so ill drop that link here. Yes, its not N55 F3x, but there's no reason for me to believe something that is applicable on N54 and other modern platforms doesnt apply here... plus there are numerous reputable sources stating exactly what i have. Take it FWIW lol. No hard feelings if you dont believe me /shrug. https://f30.bimmerpost.com/forums/sh...8&postcount=17 |
10-14-2021, 01:57 PM | #25 |
Rep 7,606
FYI, i just emailed MHD and this was their response. Vague as it is, they said not to run them... But hey, ya'll can continue to believe whatever you want.
10-14-2021, 07:52 PM | #26 | |||
Rep 2,047
As I understand, coding out CEL will not sort the reason the light is on, and emissions will fail the car
440i GC with MPPSK, AP intake, 20" 624 M wheels, Wagner downpipe, Xhp stg 3, BM3 stg 2
instagram: f36_garage |
10-14-2021, 09:35 PM | #27 |
Rep 7,606
Right - the catalyst monitor will not be ready even if you code out the CEL. Whether or not you fail because of that depends on local laws.
10-15-2021, 07:45 AM | #28 | |
Rep 1,597
You are being a rear-hole. Not sure what your problem is really to say these things so you must have been slighted in some way in some other thread. I post to help fellow owners on the forum not to have some kind of ego sprint with you. "Supposedly preventing drift" BMW's ISTA explicitly says the secondary O2 is only used for catalyst monitoring. I am not sure how much clearer it has to be. So are we supposed to believe you and your one e-series youtube video from some misc guy and a one-liner from MHD over BMW ISTA used at dealership repair centers all over the globe? So you say all information you have indicates but yet when I ask you, you really don't have much beyond this and yet are giving recommendations on your "indications". I think its you who should stop spreading misinformation. Last edited by BMWILUVU; 10-15-2021 at 08:54 AM.. |
10-15-2021, 11:39 AM | #29 | |
Rep 7,606
Anyways, I merely recommended the safer/more conservative approach, which was to not run any kind of spacer or anything on the secondary O2 long term. I'm happy to take a look at ISTA information on the secondary O2, specifically if it says it is only used for catalyst monitoring and nothing else (i.e., not that it mentions catalyst monitoring and not fuel trims wherever you are looking). I posted more than just the youtube video... there are numerous threads discussing it, MHD says not to run them, and people report adverse effects from doing so long term... Like i said everyone is free to consider the information presented to them and make their own conclusion as to what they are used for and if they want to run anything on the secondary O2s. I only posted so that OP was aware of potential issues since he mentioned using a spacer. The last thing i would want is him to use a spacer and inadvertently affect his car thinking it was totally fine to do so. Again - trying to be helping, has nothing to do with ego as you falsely claim. Someone can go ahead and experiment on their car by running a spacer/minicat and see what happens, or hell just delete the secondary O2 if you are catless since it's not doing anything anyways except telling you your cat is missing |
10-15-2021, 02:45 PM | #30 | |
Rep 1,597
10-15-2021, 04:22 PM | #31 | ||||
Rep 7,606
Let's have a quick recap - first, i did not "state as fact", i have, over the course of may last several posts, presented information and very explicitly stated my reasoning and that it is not a statement of fact: Quote:
Let's also have a quick recap of the other things you said (numbers added): Quote:
2 - Custom tune is not needed for a DP when the OTS maps are specifically designed to be ran with or without DP depending on the "stage"... 3 - Not sure i follow this either... the BM3 stage 2 map is specifically designed to be ran with a DP, so it is even more "tuned" for the DP than the stock tune, which will rely on closed loop fueling (and other adaptations) to account for the DP (since it expects OEM cat in place). Please explain why running catless on stock tune is better than running on a tune made for having a DP? And why there would be a danger in either case? No personal attacks here, just responding to information. Happy to be informed if you have anything to the contrary. |
10-18-2021, 07:03 AM | #32 |
Rep 1,597
Right so BM3 OTS is tuned for every configuration of high flow and catless downpipe right?
Also, what of this drift you keep talking about? Do you have any data and information as to why there would be drift in fuel trims because of the secondary O2? You make a whole lot of non-sense and dare to come online and start posting your beliefs and insulting people when your ego was bruised because you might be wrong. I've already told you what BMW ISTA said. Take the matter up with BMW. You obviously have no idea what you are talking about. |
10-18-2021, 12:34 PM | #33 | |
Rep 7,606
(2) Plenty of articles on O2 drift over time. Also its not drift because of the secondary O2. Its using the NB secondary O2 to prevent drift from a primary wideband O2. Suggest googling O2 sensor drift and you will get plenty of informative articles and how the NBO2s are used across numerous platforms to prevent drift from primary O2s. (3) I really dont understand why you keep saying these things, seeing as how you are the one continuously being aggressive and insulting while i am doing none of that and merely presenting information. Yeah i know what you said and i asked for some references/screenshots/point me to where i can find it so i can see for myself. I have nothing to take up with BMW. You're just throwing insults and being extremely defensive because i am challenging your position |
10-19-2021, 06:37 AM | #34 | |
Rep 1,597
The only drift is from aging of the primary wideband which is going to happen overtime anyway. This is nothing to do with the spacer on a secondary O2. This type of degradation happens over time in any normal car. Stop trying to turn this around. I courteously warned you off with several posts when you were being an unreasonable insulting rear-hole now we get to check on all of your BS you've been posting. |
10-19-2021, 12:22 PM | #35 | ||
Rep 7,606
https://us.autologic.com/news/fuel-t...-faults-part-2 https://blog.fcpeuro.com/faulty-oxyg...toms-diagnosis "The signal from the second bank of oxygen sensors is used primarily to detect any problems with the vehicle's catalyst and to tune the fuel trim." bmw.s*p*o*o*l*s*t*r*e*e*t.com/threads/secondary-o2-sensors-tuned-still-needed.4877/#post-73369 (delete the *'s in the web address) I'm not turning anything around. I keep presenting additional information for everyone's benefit, whereas i don't really see you contributing anything here? Please do point out more of this "BS" i have been posting, happy to be fact-checked and read any additional information you or others may provide on this topic or any other . |
10-20-2021, 08:35 AM | #36 |
Rep 1,597
Love how you try to misrepresent everything going on to defend yourself and your crappy attitude. I also emailed FCPEURO about their comments and received no reply. I am well aware of what some of the other manufacturers do and that does not mean BMW does that and it does not mean the latest generation. And I told you in other threads your one holier than thou by some random person youtube video was on on e-series. Your article mentions the N54 engine itself. Do you drive an N54?
Meanwhile, you have created an urban legend around this. |
10-20-2021, 11:14 AM | #37 | ||
Rep 7,606
Appreciate you finally posting ISTA so we can read it in context. The sentence you underlined says its not used for mixture preparation/control - we know the secondary O2 doesn't do anything for mixture control. As discussed in the paragraphs above in ISTA that's the job of the primary (wideband O2). It's too bad it doesn't say it only serves catalytic converter diagnosis since that would have been your "smoking gun". I don't have ISTA installed but I'd like to also read what's above and below that screenshot; I'll see what i can find online. Would also love for someone to do this experiment themselves to see what really happens, which should be nothing negative if what you are saying is true Everyone with catless DPs (or most catted) should just be running spacers and minicats to pass emissions lol |
10-20-2021, 06:03 PM | #38 |
Rep 1,934
Nothing happens by running a high flow catted downpipe on an OE tune. I did it for two months. No issues.
There is nothing to tune for with catted/catless. DME tunes ask for one of the two past stage one just because of the higher EGTs we see from the increased load on the engine. With the OE dp the EGTs would likely end up catastrophic after some time. Remember what the cat is there for. It is simply there to burn off fuel in the exhaust gases. Nothing else. Nothing about that account of excess fuel is necessary for anything in the tune.
10-20-2021, 09:43 PM | #39 | |
Rep 7,606
On the flip side there are also people that run bolt ons without any tune, or with a lower stage tune that they technically could run. In that case you are essentially running more hardware than what your tune calls for, essentially the opposite as the other scenario. But again no real concern on this platform given closed loop fueling and load-based engine control. It's really on other cars that don't have the same level of DME control that run into issues with doing boltons with no tune (similar to what OP was being told earlier on in the thread about the DP). But that just doesnt apply here. |
Logicoeur991.00 |
10-21-2021, 06:55 AM | #40 | |
Rep 1,597
10-21-2021, 10:21 AM | #41 | |
Rep 7,606
The absence of information on any type of calibration/drift control/etc in your screenshot doesn't mean it doesn't exist - you showed just one part of one page in ISTA. How do we know there isnt another page that talks about fuel trims or calibration tables that doesn't say anything else? That one screenshot doesn't erase all the other evidence to the contrary from user-reported effects, tuners advice, etc. Everyone is free to consider the weight of evidence when making the decision as to whether or not they should run anything on the secondary O2. And if anyone does, or decides to delete them entirely, i am happy to look at before/after datalog and whatnot to see what happens. I appreciate you posting the ISTA screenshot for everyone's benefit, we don't need to go in circles anymore unless you find something else to share, and i will do the same if i come across anything |
