BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > 2012-2019 BMW 3 and 4-Series Forums > General F30 Sedan / F32 Coupe / F36 Gran Coupe Forum > Telematics Control Unit Help
proTUNING Freaks
      10-18-2021, 01:19 PM   #1
Minton444
Drives: 2006 525xi e60
Has anyone taken apart their TCU and fix whatever made it go bad? I was given two and yup they are both bad so now I have three of these' including my original, so I don't care about opening one and trying to fix it. Why you ask? Why not! I have three dead ones. Any help would be great.
      10-18-2021, 05:20 PM   #2
im_an_alien
im_an_alien's Avatar
1127
Drives: 2016 340i
Maybe there is an underlying problem, all those TCUs bad? What are your symptoms?
      10-18-2021, 05:32 PM   #3
Minton444
The car won't communicate with the module. I did a multimeter test on to connector and all the fuses and Everything is great there. I then checked the green fiber optic cable and it is omitting a red light. I then checked to see if the module was sending a red light back but it's not. I then connected ista and the amp and the cdc is showing no communication. I then put a fiber loop onto the green cable and then checked ista and that fixed the problem with the amp and the cdc but the tel/mulf still showed no commutations. Now I did that with all three modules which were given to me for free. With all that being said I have determined that the modules are bad. I figured if someone had fixed one before if they would talk me through it I would try to fix it.
      10-18-2021, 06:17 PM   #4
BimR
Drives: 2016 328
I think the 3 free ones might be the problem 🤣. Hopefully someone has taken them apart and can help. That is one finicky module.
      10-19-2021, 07:07 AM   #5
dmaxdmax
dmaxdmax's Avatar
Drives: 2016 M235i 6-spd
Did you replace the battery? That's all mine needed when it went bad...this was in a 2016 340i xd. You're not talking about your 2006, or are you?
'92 325i, '99 328i, '16 340i, '16 M235i all manuals
dmax on FB
My last pre-covid standup set
      10-19-2021, 07:21 AM   #6
Minton444
It's in my 2006 and no I didn't replace the battery
      10-19-2021, 08:05 AM   #7
dmaxdmax
dmaxdmax's Avatar
That might be a good place to start, assuming yours, like mine, has a battery. It should--it's made to call someone in the event of an accident, where the battery of the car would be cut off by the bst.
No idea where yours is--was in the TIS for mine while the TIS was still up...
dmax on FB
      10-19-2021, 12:27 PM   #8
2017F30
Drives: 2017 330iX AT
My vehicle’s telematics control unit failed and was replaced at 14,251KM (8,900 miles) which is shockingly premature.
