06-12-2017, 12:57 PM | #1 |
Rep 1,127
TPMS and the Track
Hello
I was at the track this weekend and I dropped my tire pressure down to about 30F/34R. At any rate I went out on the track and I started getting warning messages and got forced down to comfort settings and it ruined my session. I like the idea of TPMS but I don't like the idea of it being so rigid. A tire at 31.9 psi is not flat. Is there a way to change the threshold to something more reasonable. Even as the tires warmed up and pressure was at 33F 38R it was still going nuts with messages, it's very distracting. It only went away when I did the TPMS reset. It's a 2015 F30 N55 Manual Msport |
06-12-2017, 03:02 PM | #2 | |
Rep 16,081
https://www.tirerack.com/tires/tiret....jsp?techid=58 Instinctively one might assume that lower pressure = wider footprint = better traction, but that's not necessarily the case. In any event, once you decide on where you want your pressure for the track if it's lower than for the street reset your TPMS at that pressure and leave it there. The system never complains if your pressure is higher than nominal. |
06-12-2017, 09:25 PM | #3 |
Rep 1,127
To be clear I was lowering my pressure over 2 lbs increments to try to see how handling changed, I didn't just do that out of the gate, I didn't assume that going from 34F/39R to 30F/34R would would cause the car to ruin my fun. I started my day at stock pressure and my instructor mentioned I should probably drop the pressure due to the way the car was handling.
Thanks for the tip, that is exactly what I ended up doing in the end. |
06-13-2017, 01:28 PM | #4 | |
Rep 740
Did my post help? Click "Appreciate!"
FOR SALE! Sport line Steering wheel with heated, paddle shifter, vibration motor, no airbag | EDM Bi-Xenon adaptive headlights (SOLD) | surround view retrofit kit (sold) | KAFAS2 camera and ECU | FLA camera(sold) | 6WB cluster (SOLD) |
06-13-2017, 06:13 PM | #6 |
Rep 740
The f30's came with different wheel sizes which means different pressure. So I'm 99% sure it just checks the threshold more than the actual value.
06-13-2017, 10:28 PM | #7 | ||
Rep 16,081
