BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > Navigation, iDrive, Audio, Video, Bluetooth, Phone, Cameras, Electronics > Is It Possible to "Code" CarPlay Into My iDrive 6.0
      10-16-2020, 10:23 AM   #1
hunginator
hunginator's Avatar
Drives: 2012 BMW 135i E82 DCT
Just wondering if there's a way to code in Apple CarPlay into my 2018 F30 330i.
It has the premium package so the bigger screen with CIC NBT, I believe it's also the same as iDrive 6.
Thanks!
Andrew
      10-16-2020, 10:36 AM   #2
drdino
drdino's Avatar
135
Drives: BMW 330i
2019 BMW 330i  [0.00]
Depending on your current setup, you can either activate it over the air from BMW or add a WiFi antenna and enable it via FSC activation. If you have WiFi hot-spot prep and wireless charging, you can buy it from the BMW store. If not, you need to reach out to a local retrofitter to install the antenna and get the FSC.
      10-16-2020, 01:17 PM   #3
hunginator
hunginator's Avatar
i definitely do not have the wireless charging pad.
is the wireless antenna/fsc code route complicated or should i actually consult with a retrofitter?
      10-22-2020, 11:16 PM   #4
XanderX
Drives: F36
Hi
yap you have nbtevo id 6 if your car is 2018 and you can get carplay fullscreen
go to Select Navigation -> Select Options -> Select Settings -> Select Position & Version History -> Select Check Version
      10-23-2020, 09:16 AM   #5
hunginator
hunginator's Avatar
Originally Posted by dragosv6 View Post
Hi
i'm a little confused by this post. is this supposed to "hack" and enable carplay on my 2018 330i?
      10-26-2020, 02:43 AM   #6
tbrazil
Drives: 16%E2%80%99 340i
I have ID5 and I’m also wondering if I can code CarPlay
      10-26-2020, 06:11 AM   #7
Wibbles
Coding ECU's remotely
Wibbles's Avatar
445
Drives: M3LR
Carplay can be added as long as you have Pro Nav with the Tile menu - option 609.
Depending on the firmware version, it can be activated via USB stick or Enet cable via 3rd parties or you can buy the official FSC code from BMW.
If your car has 6NW or 6CP then it can be activated from the connected drive store.
      10-26-2020, 08:11 AM   #8
hunginator
hunginator's Avatar
This makes more sense to me and it sounds like I have the Pro Nav (tile menus).
However, I don't believe it has 6NW or 6CP... do you know who can help me activate via USB/Enet?
      10-26-2020, 09:36 AM   #9
tbrazil
6NW/6CP?
      10-26-2020, 12:50 PM   #10
Wibbles
Wibbles's Avatar
445
Drives: M3LR
Originally Posted by tbrazil View Post
6NW/6CP?
They are the options for Enhanced Bluetooth and Carplay Prep.
Send me a PM, I may be able to help with activation.
      02-25-2022, 06:50 PM   #11
shadowspawn1201
Drives: 2016 BMW 328i XDrive
Hello all, how do i enable carplay on 2018 340xi id6?
      02-25-2022, 09:38 PM   #12
chowser51
chowser51's Avatar
Drives: F33 430 and F39 M35i
My ‘18 430 F33 has carplay.
Run your vin through a vin decoder and look at your option packages
