03-25-2020, 07:43 AM | #1 |
Rep 115,980
www.n54Tuning.com - Dorch Engineering N55 Stage1/2 HPFP Upgrade - FREE SHIP!!
N55 Stage 1 HPFP Upgrade SKU: DE-55-1001 Categories: BMW, N55 ORDER LINK https://www.n54tuning.com/dorch-engi...grade-kit.html This is a complete plug-and-play kit to support up to 550whp (this number can vary quite a bit depending on tuning strategy and the blend of ethanol). There’s no cutting, no bending, no crimping, etc. This kit drops right in with full control from the DME, just like the OEM pump. All of the safety and sophistication of the stock DME remain in place. N55 HPFP Flow Capacities The table below serves as a reference for maximum fuel flow in cubic centimeters per camshaft revolution for various N55 fuel pump options. These calculations are based on the N55 cam lobe. Each engine will have varying fuel flow capacities depending on the lift and number of lobes on the camshaft. Pump Model Fuel Flow (cc/rev) HDP5 (Stock N55) 0.837 HDP5 Evo (Stock B58) 0.897 HDP6 (Stock B58TU) 1.107 Dorch Engineering Stage 1 1.221 Dorch Engineering Stage 2 1.465 Software changes are required to run this pump. If using MHD or Bootmod3, simply check the box for our pump upgrade when flashing (coming soon). Otherwise, please send your .BIN file to tuning@dorchengineering.com for the appropriate software changes. This change is free of charge for all of our customers. Kit Contents: HPFP w/ Hardware High Pressure Line Low Pressure Line Low Pressure Line Bracket Plug-n-Play Adapter Harness Kit Fitment: F87 – M2 F20/21 – 135i F22 – 235i, 235xi F30 – 335i, 335xi F32 – 435i, 435xi F10 – 535i, 535xi E92 – 335i (ONLY 2012+ models originally equipped with Bosch HPFP) E82 – 135i (ONLY 2012+ models originally equipped with Bosch HPFP) |
04-03-2020, 08:36 PM | #3 |
Rep 115,980
04-13-2020, 04:18 PM | #4 |
Rep 115,980
04-16-2020, 02:00 PM | #5 |
Rep 115,980
04-18-2020, 05:05 PM | #6 |
Rep 115,980
04-21-2020, 12:38 PM | #7 |
Rep 115,980
04-23-2020, 07:38 PM | #8 |
Rep 115,980
04-27-2020, 08:38 PM | #9 |
Rep 115,980
05-04-2020, 07:25 AM | #10 |
Rep 115,980
05-06-2020, 12:12 PM | #11 |
Rep 115,980
05-09-2020, 05:06 PM | #12 |
Rep 115,980
05-15-2020, 07:56 PM | #13 |
Rep 115,980
05-22-2020, 07:44 PM | #14 |
Rep 115,980
05-25-2020, 08:29 AM | #15 |
Rep 115,980
05-27-2020, 09:57 AM | #16 |
Rep 115,980
05-30-2020, 07:16 AM | #17 |
Rep 115,980
06-01-2020, 06:37 PM | #18 |
Rep 115,980
06-04-2020, 07:43 AM | #19 |
Rep 115,980
06-08-2020, 05:35 PM | #20 |
Rep 115,980
06-10-2020, 05:20 PM | #21 |
Rep 115,980
06-13-2020, 05:16 PM | #22 |
Rep 115,980
