03-24-2018, 09:54 AM | #1 |
Rep 216
Drives: F30 335i PWG
Rain light sensor retrofit coding HELP!
Hello everyone, I have an issue trying to code my retrofitted rain light sensor and I was wondering if anyone can help. I am supposed to change
FEM: 3060 FLC_AKTIV from nicht_aktiv --> aktiv, but I do not have that option in the drop down menu on esys. I tried changing the werte value to 01 instead of 00 and it still wont work. Any ideas? the rest of the codes work fine, and the sensor is installed correctly as its seen in ISTA/D Last edited by Dfahmy; 03-24-2018 at 11:34 PM.. Reason: fixed the title |
03-27-2018, 10:19 AM | #2 |
Rep 216
any ideas??
03-30-2018, 06:57 AM | #3 |
Rep 106
I'm facing the same problem with a car that I had retrofitted before but went to replace something and Bavarian Auto updated it. Also, tried to VO code it, but didn't work. I'm trying different things, the problem is it's a friend's car and I don't have much access on it to keep trying.
03-31-2018, 10:52 PM | #4 | |
Rep 216
2013 335i BSM ~ Stage 3 turbo, forged internals and more check out my build thread https://f30.bimmerpost.com/forums/sh...7#post23789807
04-01-2018, 06:32 AM | #5 |
Rep 2,302
The VO code for the rain light sensor is the 521.
The manual codings are: FEM_01 > LceConfiguration 3064 > LCE_BEL_LIN_VAR = nicht_aktiv [Default] FEM_01 > LceMaster 3060 > FLA_AKTIVIERUNG = nicht_aktiv [Default] FEM_01 > LceMaster 3060 > FLC_AKTIV = aktiv FEM_01 > LceMaster 3060 > LDS_MIT_STELLUNG_A = aktiv FEM_01 > PfLinSteeringWheel 3140 > LIN_VARIANTE_SPARE_SZL = szl_aic_4Band FEM_01 > PfLinSteeringWheel 3140 > LIN_VARIANTE_SZL = szl_aic FEM_01 > PfRainLightSensor 3130 > REGENSENSOR_INTERVALL = nicht_aktiv [Default] FEM_01 > PfRainLightSensor 3130 > RLS_LIN_VAR = RLS FEM_01 > WipeWashMaster 3080 > WW_REGENSENSOR = RLS_Verbaut KOMBI L7_MID > ERM_Konfiguration 3004 > BRIG_SURR_APPL = aktiv KOMBI L7_MID > ERM_Konfiguration 3004 > BRIG_SURR_TIMEOUT = aktiv KOMBI L7_MID > ERM_Konfiguration 3004 > STAT_FAHRLICHT_TIMEOUT = aktiv KOMBI L7_MID > KI_Dimmung 3007 > DIM_RLS_NACHT_AUS = mit_rls KOMBI L7_MID > KI_Dimmung 3007 > DIM_RLS_NACHT_EIN = mit_rls |
THE_AVIATOR15.00 |
11-06-2019, 06:47 PM | #6 | |
Rep 67
automatic lights, coding, rain light sensor, retrofit |
