BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > F30 DIYs and Coding Discussions > F30/F20 TPMS Retrofit
      01-22-2021, 03:59 AM   #353
atzebmw
Drives: Tesla Model 3
Originally Posted by Rasoul77 View Post
I have a question that I'll appreciate if somebody can help me with. I have a F30 328i with production date 2012/11 EUROPE. Which set of control unit/sensors should I use to retrofit TPMS on my car?
1. Control unit 6876227 / Sensors 6856227? or;
2. Control unit 6855180 / Sensors 6798872?
No. 1 definitely works.
No. 2 I don’t know.
      02-05-2021, 10:52 PM   #354
CARIZ
Drives: F10 MY2015
Originally Posted by atzebmw View Post
I think that only works for one in a thousand people that you only have to retrofit the sensors because you have the DSC MK100.
For most people it doesn't work that easy and you also need the receiver.
Also there are some other codings or ecus for an F10.
You can try this but i have not much hope there.
I sourced a used antenna from ebay. I have installed the RDC antenna and coded again. The head unit displays "Resetting Tyre Pressure Monitor (RDC)" message while driving. However after driving for about fifteen minutes I get a warning of "Tyre Pressure Monitor (RDC) failure".
Moreover, the parameters in DSC module ( C_funktion_RDCi_I; C_Funktion_RPA_e and C_RPA_Extra) and FEM (RC_RDC_Enable) are not present.
Any guess what could be the reason?
      02-06-2021, 07:59 AM   #355
atzebmw
If you still have installed the wheel sensors 6855539 (as you wrote 1 page before) this will not work together.
The sensors together with the antenna are different from the sensors without antenna.
Which part number has the antenna you have now installed?
If it has one of these part numbers....
36106871056
36106872026
36106872027
36106875773
36106876227
36106881474
you can use the sensors with these part numbers...
36106890064
36106798872
36106856227
Your car has no FEM, so you don't need to search for FEM (RC_RDC_Enable).
      02-06-2021, 08:18 AM   #356
CARIZ
Drives: F10 MY2015
36106871056
36106872026
36106872027
36106875773
36106876227
36106881474
36106890064
36106798872
36106856227
I have attached image of controller for reference.
      02-06-2021, 08:41 AM   #357
CARIZ
Drives: F10 MY2015
I have done the following for installation.
1. Added 2VB in SALAPA
2. Injected CAFD file in RDC through ESys 3.34 (with PSDZ lite)
3. FDL coded the following:
a. HU_Entrynav
b. ICM
c. DKombi
I am not clear why the parameters in DSC module ( C_funktion_RDCi_I; C_Funktion_RPA_e and C_RPA_Extra) are missing.
Am I doing something wrong/ incomplete?
      02-06-2021, 01:02 PM   #358
atzebmw
a. HU_Entrynav
b. ICM
c. DKombi
The module/antenna is the right for your car - you can leave it.
But your sensors 6855539 are still wrong and do not match the car/module/antenna.
For the coding you should not FDL code, because the FDL codings are different for the cars (depends on the model and built year), that's the reason why you don't find some coding values.
To be 100% sure for the codings you should VO code the car.
So add the 2VB to the salapa element and save this FA/VO.
Then load this FA/VO and code (button "Code") the DSC, ICMQL, HU_Entrynav and DKombi.
But as I said - you need other sensors first.
      02-06-2021, 07:05 PM   #359
CARIZ
Drives: F10 MY2015
Can you specify the part number of sensors needed?
      02-07-2021, 04:08 AM   #360
atzebmw
As I wrote in post #355
36106890064
36106798872
36106856227
      02-08-2021, 05:16 AM   #361
CARIZ
Drives: F10 MY2015
I will rephrase my question.
What I meant to ask is whether my antenna # 6857938 is compatible with all the sensors that you recommended?
      02-08-2021, 10:31 AM   #362
atzebmw
Yes, i already checked this.
Your antenna 6857938 is compatible with the part numbers above.
      02-10-2021, 04:19 AM   #363
CARIZ
Drives: F10 MY2015
I ran INPA and ISTA under the current setup, i.e. antenna 6857938 and tyre sensors 6855539 and I am posting the results in the attached screenshots.
Do any of these make any sense in trouble-shooting?
      02-11-2021, 12:31 PM   #364
atzebmw
No, that makes no sense, because INPA has the sensor values in bar, but ISTA apparently cannot find the control unit.
But the sensor values are transmitted via the control unit?
I don't understand.
Do you see the antenna in ISTA?
      02-13-2021, 03:49 AM   #365
F31_Denmark
Drives: BMW F31
Hi Maybe you guys could help me out coding my tpms back on again.
The story short.
In April last Year i VO coded my TMPS sensors off by erasing 2VB and vo coded DSC, HU_ENTRYNAV, ICM and KOMBI (thinks its BKOMBI) Using "F30 F20 Code Out Tpms back to RPA or RFA" - Guide
Now i want to enable my TPMS sensors again.
I havent pulled any fuses when i disabled the TPMS.
My car have had a complete software upgrade since and has got a tune.
Today i have tried using
Reverting back trying just to add 2VB to the vehicles ecu's DSC, ICM, HU and Bkombi.
But i got these errors showing then trying to write 2VB back to the ECU's
BKOMBI - File for "cafd_00000760-007_004_011" not found! [C012]
DSC - File for "cafd_000019cc-100_136_010" not found! [C012]
ICM - File for "cafd_0000067b-002_016_001" not found! [C012]
Hu - Didn't get any errors.
My hardware aren't any diffrent from April 2020 nothing has been changed.
Could anyone explain what im doing wrong og help me out, coding my tpms on again?
      02-13-2021, 03:58 AM   #366
atzebmw
Because your car got an software update you need newer/the newest psdzdata.
That‘s all.
      02-13-2021, 04:08 AM   #367
CARIZ
Drives: F10 MY2015
I don't understand.
Yes, the RDC ECU is green in ISTA. However after running the car for few minutes, a few ECUs, including RDC, turn brown (although I don't remember the exact ECUs that threw error but still I think that they were ICM/HU/ZGW).
On one instance, the RDC ECU disappeared from the ISTA after a short drive but re-appeared after I reset the RDC antenna by removing the fuse.
I removed the 2VB option in VO coding and reverted to RPA system for the time-being.
If anything needs to be done then I can retry on the weekend.
      02-13-2021, 03:43 PM   #368
F31_Denmark
Drives: BMW F31
The story short.
Ok, so i update the psdzdata and tried VO coding again, but it didn't do the job, i got the arbeitbeendet, and no errors.
But something is wrong, i get an error when resetting the tpms.
What would happen if i reset the ECU's HU_Entry, ICM, Bkombi and dsc?
Will it go back to factory or back to when the cars ecu's where updated?
Could it possibly effect the tune?
I Made a backup svt. but the backup was before updating the psdzdata can i use it or will something be missing?
Also made a FA backup, but this was also before the psdzdata update.
I want to go back and have amother try VO voding the 2VB into the ecu's.
Whats the easiest way to do it for me?
      02-13-2021, 09:28 PM   #369
ditto675
Drives: F20
Finally got RDC to work on my 2011 f20.
I had all the same issues as others (missing cafd, no rdci or safety options in dsc etc) and it still didn't work. Had control ecu working with car (after injecting cafd) but sensors wouldn't work with it.
I purchased Chinese wheel sensors originally and turns out this is the problem. I fitted 2x BMW OEM sensors and left 2x Chinese sensors on the back wheels. After resetting in idrive everything worked including the Chinese sensors. (Will fit the other 2x OEM sensors tomorrow as the Chinese ones do take about 2sec longer to show changes in readings)
So it turns out the Chinese sensors cannot initiate communication with the control ecu 6876227 but OEM ones can.
In the past I had tried to reset ecu and sensors through ista+ but nothing had worked so OEM sensors are definitely different to aftermarket ones.
At a guess after coding the ecu to your car it requires some sort of encrypted handshake from the sensors which aftermarket ones do not do. This handshake only happens once so that would explain why aftermarket sensors work for people with winter wheels or replacing dead OEM sensors.
atzebmw588.00
      02-14-2021, 05:28 AM   #370
atzebmw
You can use the FA backup because this has nothing to do with the age of the psdzdata.
The FA is always the same.
And then code the FEM too.
So code the FEM, ICM, HU, DSC, Kombi.
      02-14-2021, 12:21 PM   #371
F31_Denmark
Drives: BMW F31
Thank you very much, just coded the FEM_Body and everything turned out good, no faultys at all after coding.
atzebmw588.00
      02-22-2021, 01:30 PM   #372
eu30
Drives: bmw F34 xdrive
Originally Posted by Cruez View Post
Thx for the answers. Im now more convinced that my mechanic replaced the right part. And fingers crossed that the problem doesnt come back
Hello,I have a question. Which side of the car do you find the antenna?
thanks
      03-04-2021, 10:43 PM   #373
CARIZ
Drives: F10 MY2015
THANKS @atzebmw!
I have replaced wheel sensors 6855539 with 6798872 and now finally I got everything in working order.
      03-21-2021, 10:59 PM   #374
benjiF30
Drives: BMW F30
Could i kindly please check. I have got a F22 MY2015 and a F30 MY2015. How would i be able to find out if i have the module or it has been prewired. Just need to get the 4 wheels sensors and install it in the wheels. Thank you guys.
