03-02-2016, 01:54 AM | #23 |
Rep 19,982
I'll get my 330e with adaptive LEDs in a few months whilst still having my 335d with adaptive xenons, so will be able to side by side tests. How exciting!
03-02-2016, 02:46 AM | #25 |
Rep 4,935
Drives: 340i MPPSK
Am I missing something obvious here? With the pre-LCI Xenons I had TWO headlights, one either side - the 'inner' lights were just fakes - somewhere for BMW to put the second halo ring. On the LCI adaptive LEDs I now have FOUR headlights because the inner lights are actually functioning headlights as well. So even if the individual LED headlights may have a slightly lower LM rating (and a correspondingly lower LUX) compared with individual Xenon headlights, I now have double the amount of them
Personally I like the LEDs - they seem to give a much more even spread and the distance they throw down the road on main beam looks pretty good to me. The one thing I would agree with is that on dipped beam they do sometimes feel a little 'low'.
Life is a state of mind |
03-02-2016, 02:57 AM | #26 |
Rep 9,709
Light is very difficult to compare. As said, beam focus and penetration is more important than 'brightness' or light output.
I'm not sure if LED technology has improved, I'm sure it has, but an M6 F13 that I had with LED lights were not good. High beam was good in that it lit up the near world like a Castle Bravo, but didn't have good penetration at distance, which is what you want from a good headlight. Probably why they feel the need to supplement LED with Laser for long distance? Regarding Lumens and the chart posted earlier, you need to take one thing into consideration, and that is that LED's flash, whereas Xenon pulse. So LED's go from full light output to zero light output repeatedly. Whereas Xenon produce waves of continuous light. That has an effect on measuring equipment, as it usually measures average light output. The human eye sees the light at it's peak value apparently and doesn't detect the flashing on off situation. |
03-02-2016, 03:02 AM | #27 |
Rep 32,881
03-02-2016, 03:07 AM | #28 | |
Rep 32,881
Re dipped beam too low, mine were also far too low from factory so I adjusted them up myself, just need a hex bit with preferably a cordless drill. They're bloody amazing now! |
03-02-2016, 03:08 AM | #29 |
Rep 8,081
Ah, OK. I didn't even think you could get halogens any more: I thought - like the 1 series - basic LEDs were now the entry level.
What a load of shite, halogens in this day and age on a premium brand.
Ian
Current: 2021 G21 330i M-Sport Previous: 2018 A6 Avant S-Line MMI+, 2014 F31 320d M-Sport, 2013 F10 520d M-Sport, 2011 F10 530d M-Sport, 2008 320i M-Sport Coupe, 2002 325i, 2001 318i valvetronic, 1998 318i, 1996 525i, 1990 Porsche 944S2 |
03-02-2016, 03:13 AM | #30 |
Rep 32,881
03-02-2016, 03:17 AM | #31 |
Rep 8,081
I thought on the 1-series it was across the range. What you say makes more sense.
Ian
03-02-2016, 03:20 AM | #32 | |
Rep 19,982
When will you upgrade your name to LED or even better... LASER?!
03-02-2016, 03:37 AM | #34 |
Rep 8,081
When I get a car so-equipped!!
Ian
03-02-2016, 04:01 AM | #35 |
Rep 2,511
Our mini with the Cornering LED Lights uses additional LEDs to light up round corners. This could be the same on the new adaptive units and account for the max brightness being higher on the adaptive units than the standard ones.
Xenons use shutters to move the light.
Driving i4 M50 (G26)
Previous 340i Touring MSport (F31) |
03-02-2016, 05:07 AM | #36 |
Rep 831
I'm awaiting delivery of my F31 335d and haven't specc'd the adaptive option this time around, so standard LEDs for me!
I've had the E90 Xenon adaptives (left & right sweeping) and lastly the LCI Xenon adaptives (full split beam array etc) on the F10. Both were good but the F10 was massive leap in tech. I was anticipating a bit of a step back on the new car, but reading this I'm thinking even if I'd gone for the adaptives it still may have been the case. |
03-02-2016, 06:48 AM | #37 | |
Fool
1857
Rep 3,542
03-02-2016, 08:00 AM | #38 |
1989
Rep 9,498
I can only say the Adaptive LED's on my LCI M3 are very good all round and when using HBA brilliant , I hope the 435D XDrive M Sport comes with the same system.
2021 LCI M5 Marina Bay Blue/ Smoked White Leather |
03-02-2016, 10:21 AM | #39 | |
Rep 3,664
I won't be speccing adaptive again based on my experiences Rukka .
Current: M4 G82
Past: C43, X4 M40i, TTS, M4 CP, 440i, 435d, M235i, 220d, F30, E90, E87 |
03-02-2016, 11:19 AM | #40 | |
1989
Rep 9,498
03-02-2016, 12:11 PM | #42 |
Rep 19,982
About as definitive as the debate over whether a 340i was faster than a 335d or not...
03-02-2016, 12:28 PM | #43 |
1989
Rep 9,498
It is not.
03-02-2016, 12:36 PM | #44 | |
Rep 32,881
I don't know the reason, maybe because there's two lights in each headlamp, maybe because reflectors are better than projectors, but there is no doubt that they are brighter! |
