04-02-2018, 09:07 AM | #111 |
Rep 1,348
See post 106!!!!!!! Was told 17 to 18psi his car 15 psi big difference!!
Do you find the torque numbers to be kind of low?
2k15 335i Msport xdrive 6spd
04-02-2018, 09:11 AM | #112 |
Rep 2,989
Drives: 2019 M2 Competition
EWG on my car.
Check out my BMW DIY Channel on YouTube! E, F and G series projects from Active Autowerke, Bimmertech, Kies Motorsports, AvinUSA, Karbonius Composites and more!
** YouTube BMW DIY Guy ** 'Nimona' G87 M2 Build Thread 'Lillith' F87 M2 Competition Build Thread |
04-02-2018, 09:13 AM | #113 | |
Rep 2,989
Thanks David!
04-02-2018, 09:14 AM | #114 |
Rep 526
BMW DIY Guy3001.50 |
04-02-2018, 09:19 AM | #115 |
Rep 1,499
18-19 psi on stage 1+!?!?!?! That seems high based on what I'm logging running bm3 stage 2. My boost is maxing at about 17 psi with timing between 5-11 degrees. Granted boost will be a function of altitude, load, and timing so it's not really apples to apples.
04-02-2018, 09:21 AM | #116 |
Rep 1,499
Unfortunately, I can't modify the log parameters post log. I'm hoping bm3 gets pulled into datazapp. I like how you can choose parameters in those logs.
04-02-2018, 09:42 AM | #117 |
Rep 2,989
Great to know thank you.. I will start research today on how to test for a possible boost leak as a place to start, barring other suggestions. Thank you for the excellent support!
ceedawg466.00 |
04-02-2018, 09:56 AM | #118 |
Rep 1,499
Did you share the logs? How do you know you have a boost leak? Does the log show a deviation between target boost and actual boost? If actual boost meets target boost, or close to it, then you don't have a boost leak.
04-02-2018, 10:04 AM | #119 |
Rep 2,989
Shoot me a PM with your email and I am happy to send you the full logs. That said, I have Torque Pro for the logs, so I dont have boost target values.. I wish I did.
04-02-2018, 10:10 AM | #120 |
Rep 1,499
PM sent. Does AA not have a logging tool like MHD or bm3?
04-02-2018, 10:16 AM | #121 |
Rep 190,132
Simon cable 2 offers datalog feature
04-02-2018, 10:21 AM | #122 | |
Rep 1,206
Also i dont how these are low. They advertise 80 gain with a catless dp. He is up 60 and has stock cat. Seems dead inline. |
04-02-2018, 10:23 AM | #123 |
Rep 1,206
he just upgraded his DV but i will bet he doesnt have a leak.
04-02-2018, 10:26 AM | #124 |
Rep 2,989
REALLY!!! I didn't realize that.. so the simon3 I have plus the app, will do better logging? Looking into that right now.
04-02-2018, 10:49 AM | #125 |
Rep 1,499
bm3 leverages timing advance over boost to make power, so you will see the bm3 logs showing lower boost. I also think they low ball the power gains. I had gains of +100 hp/+150 tq with catless dp, stage 2 on 91 octane and some corn.
04-02-2018, 11:00 AM | #126 | |
Rep 1,206
Key word though is corn |
04-02-2018, 11:23 AM | #127 |
Rep 5,334
It's my understanding that the Torque app won't really give you true boost numbers as it's reading the boost data directly from the DME. Since the DME is being tricked by tunes and piggybacks into seeing lower than actual boost, the boost being reported is lower than actual.
As for dyno numbers, there is VERY little difference in variability between Dynojet numbers. That's what makes the Dynojet so great for comparing dyno numbers. Assuming 1) the car isn't have an issue (i.e., heat soak, some sort of tuning or mechanical issue, other drivetrain changes); 2) the correction factors are the same (i.e., SAE and STD); and 3) the correction factors aren't extreme (i.e., excessively low or high ambient heat/humidity), you can compare the numbers on two different Dynojets and draw some realistic conclusions if something is gaining power or not. Using the same Dynojet is ideal, but the dyno is incredibly simple in it's design. As the operator, you cannot manipulate the power readings like you can with other Dynos. You can mess around with correction factors, but that's easy to see as the user. Now what I've noticed be the stock runs and current modded runs is that stock was corrected to SAE and the modded to STD. It's a fact that STD numbers are a bit higher (~3-4%) than SAE corrected numbers. I will say that raichen's stock numbers are pretty high for a non-MPPK equipped EWG N55. Most EWG non-MPPK cars make around ~280whp and ~300twq on the Dynojet. Most MPPK EWG N55s see ~300whp and ~320wtq on the Dynojet. The 6MT cars will see fractionally higher numbers.
The forest was shrinking, but the Trees kept voting for the Axe, for the Axe was clever and convinced the Trees that because his handle was made of wood, he was one of them.
04-02-2018, 11:35 AM | #128 | |
Rep 1,499
That is the case for piggybacks but not flash tunes. Flash tunes actually change DME target parameters.
ceedawg466.00 |
04-02-2018, 11:49 AM | #129 | |
Rep 2,989
GREAT feedback and absolutely open to suggestions for better logging. I am looking into Simon2 now etc.
04-02-2018, 01:27 PM | #130 | |
Rep 600
Before buying a product you need to verify if it will match your expectations. Mine for the tune where: - No piggy back tune - Tune of experienced BMW specialist - No to low risk of getting into limp mode - Driveability of the car as with stock. (No nervous behaving/shifting in the drinving modes) - Good sound without being ridiculous - Better throttle response, and more torque up to around 5000 rpm - Easy flash back to stock - Overall: a bit more power than with MPPK for a reasonable fair price. And time will show: - Durability For me it is more important of how the tuned car behaves form like 1000 to 5500 rpm compared to the stock car. So it's not so much the top numbers of power and torque that counts for me, as I don't spend much time driving around at 6000 rpm. It's about what I get in the range I use the car at most and for what price/consequence. (i.e. driveability, durability) For the short time I drive the AA Flash tune (rest is stock) I'm very satisfied with what I got. It's matching my expectations!
335i F31 RWD in SB || Powertrain: Active Autowerke Flash Tune Stage 1 | AA Charge Pipe | AA FMIC | GFB DV+ | xHD Trans-Flash | Quaife LSD | Cyba 3.5" Carbon tips || Chassis: 20" 405M | Wiechers Strut Bar | Rear M-Diffusor || Brakes: 18" M-Perf Brake orange 370/345 | EBC YellowStuff pads all around || Various: LED bulbs: Fog-L. front | Turn Signal f&r | Brake L. | Reverse L. | Rear L. | Rear Fog L.
04-02-2018, 03:03 PM | #131 |
Rep 2,989
I just wanted to share the STELLAR support from AA. I have already gotten a detailed response and a new ECU build. My goal is to pull a new set of logs (non dyno) with the current build to pull some additional info, and then the same with the new build. I hope to get this done probably tomorrow afternoon.
04-02-2018, 03:19 PM | #132 | |
Rep 1,348
Did you order their Simon2 datalog cable?
