BMW 3-Series and 4-Series Forum (F30 / F32) | F30POST > Technical Forums > N55 Turbo Engine / Drivetrain / Exhaust Modifications > PSA: Charging Malfunction, flat battery, starting issues...check your cables
      06-02-2020, 07:20 AM   #1
JaredG_F30
JaredG_F30's Avatar
1106
Drives: 2014 335i, M-Sport, Manual
Hi all,
I just wanted to share and issue that I finally resolved in case some of you experience the same things. About 2 months ago I noticed slow starts in the morning. I expected a dying battery as it was over 6 yrs old. After replacing my battery and registering it, I would have intermittent iDrive warnings of "Charging Malfunction" and "Low Battery: Charge the battery or drive for an extended period of time" errors. I thought that maybe my alternator was going out. Then the other day I went to start my car. It wouldn't turn over even with a jumper pack. Now I'm starting to think my starter is going out however I'd had this issue before on my E36 M3 and it was a bad ground cable connection. So I started inspecting all of my cables and found a loose connection at the hex nut (Item 8 in the diagram). I tightened this up and now no more starting issues and no Charging Malfunction error. You can see from the diagram that the positive cable from the alternator goes to the starter then to the connection point at items 4 & 8. Item 2 is the ground cable for jump-starting the car. So it makes sense with a loose connection at 8 that the alternator wasn't charging the battery, the starter worker intermittently and jump-starting wouldn't work either.
tldr: If you are having Charging Malfunction errors, starting issues and flat battery check your cable connections.
Cheers!
2014 F30 335i, M-Sport, 6MT, V804s, custom exhaust, CTS Turbo Intake & IC, FTP CP, VRSF DP, TMS Strut Brace, BM3 Stg 2, AEM WMI, H&R Sport Springs (381 whp, 429 wtq on Cali 91oct before WMI).
SPI Films Blog/DIY Vids
exE36M3487.50
aps335.50
      06-02-2020, 07:10 PM   #2
exE36M3
BMW CCA Member
exE36M3's Avatar
488
Drives: 2015 435i M Sport
Any idea how that bolt got loosened up?
Service guy remove the cable to do some work and never tightened it down?
      06-03-2020, 09:11 AM   #3
JaredG_F30
JaredG_F30's Avatar
1106
I have no clue honestly
      12-24-2023, 01:14 PM   #4
Fastcarpoorman
Drives: Bmw f30, bmw 335i, bmw, bmw f
I am having the same issue and battery drains fast, the car only ran for 5 minutes and drained the battery, how do I find this bolt with the engine in the way
