08-21-2023, 11:21 AM | #1 |
Rep 30
LDW Steering wheel question
Hey guys I'm looking to get the LDW retrofit done and was wondering if there's any easy way to know if i have the vibration module in the steering.
If it helps I have the heated steering wheel as well as KAFAS2 camera. Thanks ! |
08-21-2023, 12:42 PM | #2 |
Rep 15
Hello, actually quite simple, remove the airbag and see what is already installed, in some cases the vibration motors are already installed otherwise you need a few more parts and the FSC,
Required parts Since this depends heavily on what kind of SAs you have, I'll divide it up. If you have 5AD(& 5DF): 1x FSC person detection 1x switching center driving assistance systems > 9 268 478 If you have 8TH and 5AG(& 5DF): 2x FSC person detection and collision warning 1x driver assistance system switch center > 9 268 479 If you have 8TH and 5AD (& 5AG / 5DF): 1x FSC person detection 1x switching center driver assistance systems > 9 268 479 If you have 5AD and 5AG(& 5DF): 1x FSC person detection 1x switching center driver assistance systems > 9 268 479 If you have 8TH and 5DF: 2x FSC person detection and collision warning, 1x driver assistance system switch center > 9 268 4781x vibration motor, 1x clip, 1x steering wheel electronics control unit, 1x if necessary, steering column switch center > depending on which F3x and which SAs you have, i.e. rain sensor, FLA, etc. there are many different numbers. If you have 8TH, 248 and 5DF: 2x FSC person detection and collision warning, 1x driver assistance system switch center > 9 268 478(((1x vibration motor, 1x clip, 1x steering wheel electronics control unit, 1x if necessary, steering column switch center > depending on which F3x and which SAs you have, i.e. rain sensor, FLA etc .there are many different numbers.))) If you have 8TH: 2x FSC person detection and collision warning, 1x switching center for driver assistance systems > 9 268 4781x cover for driving assistance systems, 9 239 2991x vibration motor, 1x clip, 1x control unit for steering wheel electronics, 1x if necessary, switching center for the steering column > depending on which F3x and which SAs you have, i.e. rain sensor, FLA etc. there are many different numbers. 1x pull the cable to the FEM for the switching center driver assistance systems > in some vehicles the cable is not in some. 6x MQS pin without ela1x connector housing MQS 4pol without ela |
08-22-2023, 11:37 AM | #3 | |
Rep 30
05-13-2024, 09:27 AM | #4 | |
Rep 885
Drives: 2018 F48 X1 xDrive 18D
Retrofits done: 2TB, 235, 313, 430 459, 508, 5DP, 322, 674 , 6CP
Other mods: Central Locking button on both sides Other info: F48 Fuseguide, CarPlay 6CP - OEM way |
