03-28-2018, 08:40 AM | #23 | |
Cheapskate
4447
Rep 4,993
ignoring articles or whatever else you want to reference, all you need is a technical understanding of how tires work to realize that an all-season tire like the A/S3+ is designed to be ran in temps below freezing without losing a significant amount of traction. OP said that temps were 40* which is nothing to an all-season. even if it was wet, the A/S3+ will still do as well as many other summer tires. It's only downside is performance in snow/ice. |
03-28-2018, 08:46 AM | #24 | ||
Rep 891
328i RWD | MW on CRed Slick Top | 6MT | BM3 | MPE | GPlus FMIC | CSF Radiator | Millway Street Camber Plates & Monoballs | KW V2 6k/18k Swift Springs | F80 LCA/TS | SPL Bump Steer Kit | APEX SM-10 | R-S4 | DS2500 | RBF600 | SS Lines | Past: E36 328is & E38 740i |
03-28-2018, 09:46 AM | #25 | |
Cheapskate
4447
Rep 4,993
i live in an area where it snows 4 times a year, and the snow doesn't stick around for more than a day if it does stick. but it has been in the single digits for weeks at a time, and i never had any issue with all-season tires losing grip or feeling unexpectedly dicey. if you really have experienced this or can show evidence that it's true, please share the tire brand and model. the whole purpose of an all-season is to use a compound that doesn't get significantly harder in sub-freezing temps. so if a rep from michelin told me that their all-season is only made for summer temps, i'd call bs. sounds like they just want to sell winter tires to people that don't need it. |
03-28-2018, 09:59 AM | #26 | |
Rep 891
03-29-2018, 05:34 PM | #27 | |
Cheapskate
4447
Rep 4,993
I never said it was a scam. I said that it's not needed just because temps drop below 50 degrees like the article said. They are important for snow and ice, and could perform better in negative temps (Fahrenheit) depending on the tire. But the conditions that the OP described (40 and dry) would probably go worse with winter tires due to the knobby tread that actually reduces grip. Ask anybody, you can tell that they don't perform as well the moment you put them on and have to adjust your driving. If you go buy whatever a salesman tells you too, have at it. But no need to make OP think there is an issue with driving his tires when it's cold outside. |
03-29-2018, 06:43 PM | #28 |
2020 Z4 M40i - 2022 M4C Convt
3127
Rep 5,264
Drives: 2020 Z4 M40i - 2022 M4C Convrt
Garage List 1965 COBRA (FFR rep ... [8.57]
2023 Jeep Wrangler ... [9.50] 2009 Yamaha V-Star [0.00] Cars 2-BMW, 2-FORD, ... [0.00] 2023 Ford Expeditio ... [0.00] 2020 Z4 M40i [10.00] 2022 BMW M4C [7.25] 1998 FORD Ranger 4X4 [0.00] |
Agree with kern417. A/S should be good for most places in the US that are not in the snow belt.
I drive summers 365/366. It can get into the low 20's here, snow on occasion & have never had issues with the summer tires grip. On snow days I take one of the 4X4, my Ranger has snow rated off road tires, because the summers will not get out of the driveway. Only rubber I felt go away under 40*F are the 100 treadware NITTO 555R on the COBRA. They are drive-able but sudden inputs will cause an Oh!! S**T moment. Since the car had no roof it does not see much if any 32*F weather but it has been tested in it. Did not crash & burn.
Kevin
Dravit Gray, Black Leather, Moonlight Roof, Red Calipers 2022 M4C - 2020 Z4 M40i - 2023 FORD Expedition XLT Max 4X4 400BHP - 2009 V-Star - 1998 Ranger 4X4 5MT - 1965 Cobra (R) 5MT - 2023 Jeep Wrangler Sport S 6MT Last edited by BEAR-AvHistory; 03-29-2018 at 06:48 PM.. |
kern4174446.50 |
03-29-2018, 07:04 PM | #29 |
Rep 5,995
Warm temps here in SoCal. Did have my tires lose grip on some concrete but that's more slippery than black asphalt. Traction control came on but the car is balanced and no torque steer with rear drive. Still had enough traction to get a solid launch. Usually traction control keeps the tires just at the limit so you still can get a good launch except in the worst conditions or if you have a hellcat.
04-04-2018, 06:24 PM | #30 |
Rep 4,876
They market it was the "science of 7 degrees" in Canada. (That's 45F).
It's why they recommend winter tires in colder climates. I used to run high performance all seasons on my Acura, and when it hit 5C, there was a night/day difference in the amount of grip. It's not that you cannot drive them in winter, but the traction on dry pavement is substantially lower when it's cold. |
uncleruckus129.50 |
04-04-2018, 06:58 PM | #31 | ||||
Cheapskate
4447
Rep 4,993
I have never experienced that with any economy all-season or high performance all-season. every car manufacturer sells cars with base all-season tires because they work across the seasons in most regions. i've had summers that grip fine down to 40F and my current bridgestones still grip fine at 30F. My all-seasons remain pliable down to the single digits and never felt a drop off like driving summer tires in sub-freezing temps. So like I said, idk what all-season tires you guys are using but there's a problem if an all-season tire only grips well in warm temps. Especially the AS3 that the OP has.
Like isn't it crazy that Michelin would recommend removing their all-seasons at 50F, but they go through the effort of improving traction in the snow? http://www.bmwblog.com/2016/01/15/mi...at-2016-naias/ Quote:
http://www.bmwblog.com/2013/01/22/bm...ot-sport-as-3/ Quote:
04-06-2018, 03:32 PM | #32 |
Rep 1,064
I'm the OP... i appreciate everyone's comments
I did autocross my first few times with all seasons (Conti DW06). They squealed a lot, and I learned after 2 days that all-seasons suck for autocross. But I guess it falsely set my expectations that squeal would always occur at the limit. FYI One reason you don't want all-seasons for auto-cross (besides lack of summer grip) is that the tires chafe terribly. Like cheese on a cheese grater. My next car (2020) will either be the new M3 or the new M5, and I will go with winters and summers. For my current 340, I have the AS3+ and a set of mediocre summer times on 17" wheels (Firestone Firehawk). I don't want to put money into more tires and wheels for this car... |
04-06-2018, 07:46 PM | #33 |
Rep 4,876
I'm a little confused why you'd bother with summer tires on 17" rims. Only reason for summers is to toss the car around on dry pavement. With large sidewalls with the 17" rims, it almost seems pointless. You might as well AS3+ all year around....
04-06-2018, 08:59 PM | #34 |
Cheapskate
4447
Rep 4,993
sidewall isn't that bad with the proper tire. it's usually better to go with a smaller wheel for performance driving. it weighs less and you can run less pressure in the tire to get more grip on warm days. there's a reason race cars run with a good amount of sidewall.
04-07-2018, 01:28 AM | #35 | ||
2JZ-GTE
3038
Rep 3,992
So the other thing I didn't like in the video is during his braking test you can see his steering wheel going all over from his warped rotors. And finally, yellow. Why? Why? |
