05-02-2022, 11:30 AM | #287 |
Rep 79
you are precious.
many thanks! Last edited by LikeNo1; 05-02-2022 at 02:41 PM.. |
10-19-2022, 11:41 PM | #288 |
Rep 7
I got my car from the dealer and they had reset the software.
Now when trying to VO code to reset the HU_NBT it says File for "cafd_00001ef6-006_055_013" not found! [C012] Can you let me know which version of PSDz should be used, or it would be great if you could share the missing file. |
10-19-2022, 11:43 PM | #289 | |
Rep 40,774
10-20-2022, 03:48 PM | #290 |
Rep 10
hi,
I just retrofitted power folding mirrors to my 2016 BMW f36 as per the instrutions, but when i try to code 430 using esys i get an error that cafd_00000794.caf.012_035_117 is missing/cannot be found after coding finishes. im using e-sys version 3.33.0 with v.63.3 psdzdata lite and cafd_00000794.caf.012_035_117 is located in the cafd folder. i have tried deleting psdzdata and updating it but still same error. do i need a more up to date e-sys/psdxdata? any help appreciated. thanks, Gerry |
10-20-2022, 03:58 PM | #291 | |
Rep 40,774
https://mega.nz/file/FxYRASxb#7H9iAY...a2ea8yW6vlEZZk
10-20-2022, 05:47 PM | #292 |
Rep 10
Cheers shawnsheridan !
I will replace the one I have with this one in the morning and try again, then report back. Just curious, but what is the difference between this file and the one i currently have? Cheers again! Gerry. |
10-20-2022, 06:04 PM | #293 |
Rep 40,774
Not sure. You say CAFD is present, error says otherwise. You are sure you have cafd_00000794.caf.012_035_117 and it is in C:\psdzdata\swe\cafd folder?
10-20-2022, 11:07 PM | #295 |
Rep 7
10-23-2022, 06:59 AM | #296 |
Rep 10
Hi again shawnsheridan
I tried again from fresh with the file you supplied which was newer and larger than the one i already had, but problem still persists. I have D:\Data set in E-Sys settings and the file was put into D:\Data\psdzdata\swe\cafd. if I try to Read (ECU) and then Read coding Data i get the following errors: when i first try to read the ECU: then when I try to read coding data for the ecu: if i try Read SVT actual from VCM then then select the ECU and try to Code i get the following error: During coding: After Coding Finishes: I don't have a token/launcher for E-sys but was under the impression this wasn't necessary for what I'm trying to do which is code in the power folding mirrors (430) I have retro fitted? although 430 has saved to the FA on the car even with the errors, as it shows up when I read VO, but nothing works. any help much appreciated! Cheers, Gerry. |
10-23-2022, 07:01 AM | #297 |
Rep 40,774
What E-Sys version are you using, and what PSdZData version?
10-23-2022, 07:03 AM | #298 |
Rep 10
sorry the images from my drobox haven't displayed on the post, the 3rd attachment is the first image for the first read ecu error, the 1st attachment is for when I try to read coding data, the 2nd and 4th are from when I try to code.
sorry about that! Gerry. |
10-23-2022, 07:04 AM | #299 |
Rep 40,774
10-23-2022, 07:11 AM | #300 | |
Rep 10
E-Sys version 3.33.0 / PSdZ version 5.07.01 with v.63.3_PSdZDats_Lite cheers, Gerry. |
10-23-2022, 07:14 AM | #301 |
Rep 40,774
63.3 PSdZData is way too old for E-Sys 3.39. You need to update your PSdZData. Your Receive PM function is disabled. PM me when working.
GerryDollso0.00 |
10-23-2022, 07:21 AM | #302 |
Rep 10
10-23-2022, 07:26 AM | #303 |
Rep 40,774
Yeah, need account for 7 days and a minimum of 10 posts. You can always PM me on Bimmerfest too.
GerryDollso0.00 |
10-23-2022, 08:58 AM | #304 |
Rep 10
cheers shawnsheridan
I got v.4.38.11_PSdZData_Lite and everything went smothly this time, or appeared to anyway, no errors. used BimmerCode to code in auto power fold and tilt, still nothing works, in Bimmercode Vehicle Information the 430 option shows, with no discription, i could have a faulty master switch/mirrors, or is there anything else I would need to code? Cheers, Gerry |
10-23-2022, 09:04 AM | #305 | |
Rep 40,774
GerryDollso0.00 |
10-25-2022, 07:35 AM | #307 |
Rep 40,774
11-18-2022, 12:29 PM | #308 |
Rep 3
Hi guys, I'm new to coding and using e-sys and I'm trying to learn! But I need help, can someone explain to me what's going on? When I try to encode FEM_BODY I always get this error:
Thanks! |
