01-09-2024, 07:45 PM | #1 |
Rep 1
XDrive Tire Difference
Hello, I know this topic has been discussed before, but I do have a question. I’ve heard a rule of thumb is 1% tire circumference difference. I’ve also heard of people running up to 3-4% without issue. If I get a setup that is for sale currently that is about 1.9-2.1% difference would that cause any issues with the Xdrive/transfer case? Thanks
01-12-2024, 03:22 PM | #3 |
Rep 16,669
Agreed. The 1% figure is spot on with old totally mechanical AWD configurations, but the electronic xDrive has more wiggle room. But I wouldn't be going much beyond 2%.
02-05-2024, 07:22 PM | #4 |
BM3 Tuner
731
Rep 527
I’m at 2.7 and you can definitely tell it’s not perfect
2019 BMW X3M40I
Paul Johnson Tunes/ACX Solutions Shop/Development Car, XHP stage 3 with custom settings, CTS Downpipe, intake, Chargepipe, turbo inlet, coils, Nostrum Stage 1 Injectors and Nostrum Big Bore HPFP, Vargas PCV and Oil cap, HnR springs, ACX Rear poly bushing, ACX Intake scoop |
03-21-2024, 02:52 PM | #5 |
Rep 1
2018 340i xDrive msport. Currently everything stock.
Thinking of purchasing some TE37 SL 18x9.5 et35 squared set. Would run 255/40/18 or 245/40/18 to keep similar rolling diameter. Think I’ll probably have to put some spacers for the fronts. Anyone else run a similar setup or know more? |
